Rick@Livernois
Old 01-22-2007, 06:29 PM   #1
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
Making Modern Horsepower the Old-Fashioned Way
The New york Times
January 14, 2007
By DON SHERMAN
AT a Detroit auto show press conference last week, Dodge announced that for 2008 the Viper SRT10 would get a boost of 90 horsepower ó to 600, from a mere 510. Some reporters in the crowd might have thought that DaimlerChrysler engineers had at last modernized the Viperís brute-force V-10 engine with dual overhead cams and four-valve cylinder heads.
They would have been wrong.
Instead, they learned, the monstrous Viper engine would continue to breathe through two valves in each cylinder, and those valves would still be opened by pushrods, a venerable mechanism that has all but vanished from modern cars. Still, the Viper V-10 would have a full complement of technology tricks inside, like variable valve timing, which makes it possible to tune the engine for both high power and low emissions with a few computer-controlled adjustments.
High horsepower and high technology usually march in lockstep, advances in performance arriving whenever mechanical innovations permit. Fuel injection, turbochargers and four-valve-per-cylinder designs have all made it possible for automakers to deliver the power that makes drivers reach for their checkbooks, yet remain in compliance with air-quality regulations and often with little penalty in fuel economy.
After the energy squeezes of the 1970s, the future of automobiles seemed to be small ó downsized cars and trucks powered by engines with fewer cylinders and smaller displacements. To compensate for the reduction in brawn, engineers set out to fine-tune the coming generations of engines. Inevitably, producing V-8 power from a four- or six-cylinder engine pushed the engineers in the direction of higher engine speeds ó more revolutions per minute to extract equivalent performance on less fuel.
Of course imports from Europe and Japan, where gasoline has long been expensive, were already using overhead cam engines to extract the best performance from their small size. Moving all the mechanical parts that open and close the valves to the top of the engine ó thus eliminating the pushrods ó yields a stiffer valvetrain that in turn makes it possible to spin the engine faster, a key to maximum power.
Stacking the cams on top of the cylinder head also clears the way for larger, more efficient ports, the pathways that direct gases into and away from the combustion chamber. A third benefit is that operating four valves for each cylinder is impractical with pushrods but a cinch with overhead cams. Doubling the number of valves can improve combustion, lower exhaust emissions and increase mileage.
But bucking this prevailing wisdom has long been a Motor City specialty. Wouldnít you know it, Detroitís seemingly old-tech pushrod engines, also called overhead valve designs, have become horsepower heroes. Itís as if the 505-horse V-8 that lets the Corvette Z06 run with Ferraris, the engines in G.M.ís bread-and-butter full-size trucks, Chrysler Groupís Hemi V-8, and the Dodge Viperís thundering V-10 never got the memo that pushrods are obsolete.
So why do pushrods persist? Because they are superior in certain areas and inventors keep coming up with fresh ideas to keep them in the game.
Packaging is where the overhead valve engines trounce the overhead cam alternatives. Extra camshafts, and the chains or belts needed to drive them, increase weight, cost and complexity ó but especially size. Pushrod engines, notably V-8ís, can fit in spaces that may be too small for an overhead cam design. Because the top of a pushrod engine is so compact, engineers can load the bottom half with larger pistons that sweep through a longer stroke.
As an example, consider two current cars with V-8 engines of about 500-horsepower, the 7-liter Corvette Z06, a classic pushrod design, and the 4.3-liter Ferrari F430, a high-tech dual-cam engine. While the horsepower is similar, the Corvette V-8 produces 470 pound-feet of torque compared with the Ferrariís tepid 343 pound-feet. Torque is what spins the tires when a rambunctious driver tromps the gas pedal, and itís what helps pull a heavy trailer over a mountain pass.
The Viper holsters a magnum V-10 under its low hood. Along with the arrival of new technology deep inside, this engine grows to a strapping 8.4 liters for 2008. Extra camshafts arenít necessary when youíve got 10 huge pistons answering every nudge of the throttle.
The challenge is to make large engines seem small and economical at the gas pumps. To do that, G.M. and DaimlerChrysler disable half of the cylinders in some of their V-8s during cruising, when all their muscle isnít required. Cylinder deactivation is easy to accomplish with pushrods, but more difficult with overhead cams.
To coax their pushrod designs to rev higher without running out of breath, engineers have designed lighter, stiffer, lower-friction valvetrains. Pushrod V-8 engines racing in Nascar routinely rev to 9,000 rpm. Thanks to natural trickle-down, the lightweight valves, low-friction lifters and high-tension valve springs made of exotic steels have filtered into production pushrod engines, giving them the speed and stamina to compete with Ferrariís V-8. While the F-430ís screaming 8,500 r.p.m. maximum speed is still out of reach, the 7,000-r.p.m. redline of the Corvette outdoes the 6,600-r.p.m. maximum of the Porsche 911 Turbo. The new Viper engine revs to 6,200 r.p.m., 200 more than before.
To fill the cylinders with the air and fuel needed to sustain high-speed operation, Detroit engine designers have packed larger intake ports into the space available between the pushrods. Lacking the room to go wider, engineers increased the capacity of the intake passages by making them taller.
Variable valve timing is another emerging technology that engineers employ to minimize emissions, improve smoothness and enhance power. Changing the timing of specific operations ó when valves open and close in relation to each other and to the position of the pistons ó is not difficult in a dual-cam engine, which controls the intake and exhaust valves independently.
Accomplishing variable valve timing with a single camshaft is a different matter entirely, because the lobes that lift the valves are locked in relation to each other.
Engineers at Dodge, working with the British firm Mechadyne, redesigned the camshaft to create two concentric shafts, one inside the other. The hollow outer tube holds the exhaust lobes while an inner shaft drives the intake lobes.
This allows continual adjustment of valve operation, according to the needs of the engine at different speeds.
The cam-within-a-cam concept has existed for decades, but perfecting it for production might just add another decade to the life of the pushrod engine.
KILLER74Z28 is offline   Reply With Quote
Old 01-22-2007, 10:19 PM   #2
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Good info...a lot of stuff I didn't know.
Old 01-23-2007, 10:40 AM   #3
LowRider
LowRider
LowRider's Avatar
Drives: 1992 Camaro Z28 & 1996 S-10
Send a message via AIM to LowRider Send a message via Yahoo to LowRider
I can't agree more Tag there is a lot of stuff I just found out. But also very helpful to me to.
LowRider is offline   Reply With Quote
Old 01-23-2007, 10:46 AM   #4
boxmonkeyracing
juggernaut
boxmonkeyracing's Avatar
Drives: VRSCF, 2011 SS vert
Send a message via AIM to boxmonkeyracing Send a message via Yahoo to boxmonkeyracing
good old american innovation
We do not want to use the Z28 moniker on a car that does not deserve this hallowed name.
boxmonkeyracing is offline   Reply With Quote
Old 02-01-2007, 11:09 AM   #5
unkillsam
Drives: 2012 Camaro LT
Once GM get's the technology from the XV8 engine into a production car this will be a moot point. OHV V8's are here to stay.
http://www.acarplace.com/brands/gm/xv8-engine.html
With an aluminum block and head, the 4.3 liter XV8 has three valves per cylinder with an air-assisted direct fuel injection system and two camshafts in the block. Power ratings are 300 horsepower (224 kW) and 295 lb-ft (400 Nm) of torque.
Other features include variable inlet systems (currently the main feature of Chrysler's Magnum engines), cam phasing, and displacement on demand (first seen on the ill-fated Cadillac 4-6-8 engines), variable inlet valve timing (common to Toyota and Honda engines), a narrow 75-degree bank angle, twin oil pumps, and an integrated air compressor. A GM spokesman said this combination was possible, in its best form, because of the engine's clean-sheet design: there was no need to compromise new features to co-exist with existing designs. That was especially important for direct injection.
The XV8's compression ratio of 10.75:1 is achieved with regular gasoline.
unkillsam is offline   Reply With Quote
Old 02-01-2007, 11:16 AM   #6
WMCC Gary
Camaro Addict
WMCC Gary's Avatar
Drives: 1987 IROC-Z
Interesting read. I learned a few thing that article.
Western Michigan Camaro Club ~ President
1987 Camaro IROC-Z Pearl White & Black w/ Red Pearl, 355 TPI, A4, 3:42, AirRide,"GOMARO"
2004 Tahoe Z71 Sport Red Metallic, 5.3, Auto, 3:73, "SASYZ71"
WMCC Website www.wmcamaro.org
Michigan FBody Association www.mifbody.com
WMCC Gary is offline   Reply With Quote
Old 02-01-2007, 09:27 PM   #7
IROC'em
IROC'em's Avatar
Drives: Chevy 1500 5.7L Vortec
Speakin of muscle I say GM drops their 572 in somthin and puts it on the market.
IROC'em is offline   Reply With Quote
Old 02-02-2007, 06:03 AM   #8
unkillsam
Not gonna happen. The carburator died 15 years ago.
Besides, no car platform is big enought to fit a big-block under the hood.
Now a 427 small-block, that will do nicely. Or a supercharged 6.2 LS3
Old 02-02-2007, 07:25 AM   #9
Calvinball
Calvinball's Avatar
Drives: 98 Grand Prix GTP, 99 Camaro
pushrods FTW!
Calvinball is offline   Reply With Quote
Old 02-02-2007, 10:12 AM   #10
TAG UR IT
TAG UR IT's Avatar
Who says you can't stuff a 572 into a 4th Gen??? Check out the ZL1 that Scott brought along w/ him to the Dallas show. This was quite an experience to hear this thing start up...my God it was loud!!! Who knows what they do w/ the 5th Gen...after all, you do know that the vehicle is 5 1/2 inches wider than any other Camaro ever made. Usually, that means more room between the wheel wells. Easier to drop in some hefty big blocks!
Old 02-02-2007, 12:03 PM   #11
OverAnxious
OverAnxious's Avatar
Drives: 1967 RS/SS L78 Coupe
Send a message via AIM to OverAnxious Send a message via Yahoo to OverAnxious
If my buddy can built BBC Fox Mustangs, anything is possible
Joe
Over Anxious - 1967 Camaro RS/SS L78
5th Gen Camaro BLOG // My eBay auctions
OverAnxious is offline   Reply With Quote
Old 02-02-2007, 12:46 PM   #12
WMCC Gary
Camaro Addict
WMCC Gary's Avatar
Drives: 1987 IROC-Z
That Camaro Is just BAD AZZ! here are some action Pics of it.
Old 02-02-2007, 12:56 PM   #13
TAG UR IT
TAG UR IT's Avatar
...daddy wants to drive....daddy wants to drive...
That is a sweet ZL1. I sure hope they bring back the old ZL1 and make a monster out of it.
Old 02-02-2007, 01:45 PM   #14
WMCC Gary
Camaro Addict
WMCC Gary's Avatar
Drives: 1987 IROC-Z
That makes 2 of us. LOL
