HeadlightArmor
Old 12-01-2009, 04:13 PM   #1
ravensjeff
100% Chevy & Harley Man
ravensjeff's Avatar
Drives: 2010 2SS: Blown LSX 376-B15
Paint/Assembly Defect
Taking car in Friday to get Service Bulletin done (HVAC/Spoiler,etc) and PDIM software update (ipod not being recognized all the time). Dealer-no problem, see you Friday.
I then mentioned (I actually almost forgot about it) about the paint chipping on the right rear corner of the car where the 2 body panels meet (Assembled with little or not enough clearance I believe was the issue). You have to look for it, but it's there.
The dealer seemed to already know about the problem and said it is a 1-3 day fix (If it is what they think) and that I would get a rental (No Accord !!).
Has anyone actually had this paint repair done? And what it actually consists of? I am thinking that the parts are disassembled, repainted and re-installed with some kind of spacer fix? Just repainting seems like the problem would re-occur. I just wanted to know what to expect since it appears my dealer is actually on top of this. I was actually happy when they said 1-3 days since it came off as quite responsive, versus dismissive.
They'll look at the car Friday when I take it in for the other stuff and let me know how to proceed.
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
ravensjeff is offline   Reply With Quote
Old 12-01-2009, 04:21 PM   #2
philthy
philthy's Avatar
Drives: 1971 Monte Carlo/2010 Camaro 2LT
Had mine done about a month ago....you would never know it was touched up. They did a great job on it.
2LT Victory Red w/ Black leather interior, automatic trans, polished 19" wheels, R6P (Early Order)
Factory style spoiler, Magnaflow axleback exhaust with resonated x-pipe, Injen CAI, RX catchcan, ABL dash mod,
Drake billet shifter with leather boot, GM splash guards, Toyo Proxes4 tires for summer, Blizzak tires with Moda rims for winter driving
Pre-ordered November 17, 2008
Delivered May 14, 2009
philthy is offline   Reply With Quote
Old 12-01-2009, 04:38 PM   #3
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Drives: 2SS/RS Oct 2009
Mine goes in this Thursday - very minor, can just see the black in the crease. The TSB does call for new parts that I believe widens the gap between fender and body. So fender is taken off, repainted and re-installed. TSB is also for a "refinish" - interpret that as repaint .
Anyways will let you know outcome of mine. I'm hoping they can touch it in rather then full refinish, body shop manager seems to be a good chap, once removed he'll know if its retouch or repaint and if its acceptable or not (as will I when I see it )
This is the first one they've had, and had no idea about the TSB until i gave them the details - straight from this forum!
Thinking about it --- do you think 'touching in' will be ok? -- as long as it looks like its never been done? - no underlying problem in that area?? it really is very minor and need to look closely to see it....
Thoughts??
markmass is offline   Reply With Quote
Old 12-01-2009, 05:02 PM   #4
philthy
philthy's Avatar
Thoughts??
Mine is touched up as you described and no issues. I was ready to put the gloves on and come out of my corner swinging when they said the whole bumper would not be repainted. The body shop manager put my mind at ease and assured me the repair would be flawless....and it is!
Old 12-02-2009, 12:19 PM   #5
ravensjeff
ravensjeff's Avatar
philthy- Sounds like they only touched up the paint blemish. Did the body shop guy give you an explanation on why the problem wouldn't re-occur since no parts were replaced?
In line with Markmass's question- touch up paint can look flawless-but that is not the worry. If you are "Touching Up" the paint, it means you did NOT replace the defective parts that caused the problem in the first place?
Old 12-02-2009, 12:54 PM   #6
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
I find myself looking at all kinds of makes and models for this. A lot of cars have this type of assembly with a plastic front section, then sheet metal middle or whatever. I did actually see some other makes with some paint problems at the joint. For the most part I have looked at several now, it was a couple that seemed to have rust forming, but they were older. I will be watching mine like a hawk!
HeavyD is offline   Reply With Quote
Old 12-02-2009, 12:58 PM   #7
wow, that's not good.
Old 12-02-2009, 01:45 PM   #8
philthy
philthy's Avatar
Yes, they touched up....did not replace the panel. They did mention shimming the joint slightly so the fender and fascia would not rub. They were not sure if it was caused by too tight of a joint, or due to the factory smacking the upper lip of fascia against the lower lip of fender when assembling the car.
The part was not defective...two parts rubbed together and the paint wrinkled a bit.
No rust possible...the fascia is plastic.
Old 12-02-2009, 04:01 PM   #9
anthonybyram
anthonybyram's Avatar
Drives: 1972 Z28, torch red,454
Thanks for the heads up and also including your VIN, I went and looked at mine just to make sure same problem wasnt happening to mine, thank goodness its not! Im wondering if this was an early production problem, possibly overtightening the rear facia? just a thought, still a problem none the less. Love your Harley, sharp bike! Good taste in cars too! (see my sig) Im still riding my shovelhead.
anthonybyram is offline   Reply With Quote
Old 12-02-2009, 04:15 PM   #10
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Not early production - mine was made in September. I've owned 5 weeks. The problem is over-tightening where the fender contacts the body, both sides. The solution is to take off fender and put new parts (washers/shims - not sure if these are modified parts or simply replace - the dealer had to order the parts - will ask him tomorrow when I take it in -- they do not supply a new fender) paint then put fender back on, ensuring correct spacing. The problem is obvious when you see it. I looked at a couple of other Camaros and they have a 'healthy' space between body and fender. Hopefully front fender is ok, looks pretty tight, but so far so good
Old 12-02-2009, 09:39 PM   #11
sixty9fordkiller
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
if im not mistaken, i read somewhere that this problem was only appearing in yellow camaros. Can anyone confirm if this is accurate? Or are yellow camaros indeed the only ones having this problem?
sixty9fordkiller is offline   Reply With Quote
Old 12-03-2009, 12:13 AM   #12
ravensjeff
ravensjeff's Avatar
Mine is Silver. VIN 6125 Made 4/28/09.
You really have to look hard to see this paint issue. At first, it was a little easier to see it when the paint was flaking. Washing knocked the flaking off, making appearance much smoother.
And thanks for the fix info-just what I was looking for.
Old 12-03-2009, 08:19 AM   #13
philthy
philthy's Avatar
Mine is victory red
Old 12-03-2009, 08:46 AM   #14
BUMBLE-B-TUNA
BUMBLE-B-TUNA's Avatar
Drives: 2010 SS
Anyone have any pictures of this?? Was it there at delivery or occur over time?
BUMBLE-B-TUNA is offline   Reply With Quote
Wavy Rear Fender Defect? efpardo Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 56 02-23-2012 04:39 PM
Radio Head Unit Defect ravensjeff Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 4 08-22-2009 11:37 PM
