Old 12-01-2009, 05:21 PM   #1
chevyss
SS/RS
chevyss's Avatar
Drives: 2010 SS/RS IOM w/blk stripes A6
Predator
I know that this issue has been beat to death, but I'm back asking for member help. I've purchased the Prediator tuner and want to complete my tune, but, I'm a novice when it comes to all this computer stuff. I'd like to know from someone who has done the tune any information that I might need prior to pluging in. I've read the booklet that comes with the tuner. I'm sure my concern is not warrented, but before I screw something up and have to buy a new ECM I coulds use some help. Thanks in advance.
Mods so far: ARH exhaust w/free-flow cats, 3" exhaust back to axle and a Airaid CAI kit.
chevyss is offline   Reply With Quote
Old 12-01-2009, 06:24 PM   #2
JohnForeman
Drives: 2010 2SSRS
I have the Diablo tune on mine. Its pretty straight forward. Go to the Diablo forum and do some reading. The main thing to remember is to pull the Onstar fuse. Its in the fuse block on the drivers end of the dash
2010 2SSRSA6 - GFX
35% Window Tint
93 Octane Diablo Predator Tune
JohnForeman is offline   Reply With Quote
Old 12-01-2009, 06:26 PM   #3
BlownSS
BlownSS's Avatar
Drives: 2010 Camaro SS/RS
does the fuse need to be pulled and left out as long as you have this tune in the ecm?
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger. 3.4 Pulley. Kooks long tube headers / high flow cats. GHL Full exhaust. ZL1 Fuel Pump/ADM FPCM. MSW Bap. JRE ZL1 Race cam with new springs/pushrods/Trunion Upgrade. FIC 850cc injectors. ZR1 Map sensor. CAI Induction. JRE Tune.
BlownSS is offline   Reply With Quote
Old 12-03-2009, 01:10 PM   #4
ZombieEatsYou
ZombieEatsYou's Avatar
Drives: "Bmblbee" 2010 RY 2SS/RS. VIN 12043
no, after you've put the tune in put the fuse back. The fuse pull is just make sure you don't have a voltage drop while you're connected to the ecm because onstar is sending a diagnosic report.
ZombieEatsYou is offline   Reply With Quote
Old 12-14-2009, 11:36 PM   #5
chevyss
SS/RS
chevyss's Avatar
OK! I've had my tuner for several months now and have not installed the tune yet. Does anyone know if there has been upgrades? I'm not a computer Guru, so I've been aprehensive in doing the tune. Is there some place to go to that I can get help on the tune? Thanks in advance. I found the receipt. Sept 09 is when I got it.
Old 12-15-2009, 07:01 AM   #6
steeleshark2
steeleshark2's Avatar
Chevyss, pm me your problems and I can try to help you out. I have a tune in my car and its not bad. If you want a custom tune other then the one in the tuner then I can recommend a couple people on this forum.
Old 12-15-2009, 07:14 AM   #7
I think I'm almost ready to buy a Diablo
Old 12-15-2009, 07:14 AM   #8
steeleshark2
There is software updates out of the tuner however, I do not recommend going above 9R10. If you have anything less, I can email the file for you to load onto the tuner. Do you have a cable to connect the tuner to your computer? This following forum thread tells everything you need to do to fine tune the car.
http://www.diablosport.com/index.php...iewtopic&t=917
Old 12-15-2009, 08:22 AM   #9
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
so we have to poull the fuse??? never heard of that before
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 12-15-2009, 08:46 AM   #10
06MonteSS
Drives: 2006 Monte Carlo SS
nah, you should be fine...
they say to pull the fuse for onstar because if there's a transmission between them and your vehicle while you're writing/flashing the tune to the ECM, it would interrupt the communcations with the ecm and could cause an issue...
but you should be fine... when I first started using mine 4+ years ago, I used to pull my onstar fuse all the time, but then after a while, I just stopped and still never had any problems...
06MonteSS is offline   Reply With Quote
Predator Programmer - $299.99 - Weekend Special! tbyrne V8 Bolt-Ons & Tunes 5 11-23-2009 08:24 PM
Diablosport Predator and Trinity Programmers Available! tbyrne Tuning / Diagnostics -- engine and transmission 41 11-20-2009 05:00 PM
Predator Programmer Package With Connection Cables and Free Shipping - $369.99! tbyrne V8 Bolt-Ons & Tunes 8 09-21-2009 05:17 PM
