Old 12-02-2009, 08:04 PM   #1
Aaron Pfadt
Pfadt Race Engineering
Aaron Pfadt's Avatar
Drives: 7.0 Liters of Fury
Check Out Pfadt's New Control Arm Stiffeners
Stiffening you suspension components is an important factor in getting the most out of your Camaro. Our strong lightweight brace is an inexpensive way to stiffen your weak factory rear toe link. We have designed this brace to slip in place on your existing toe link and box it in for maximum stiffness.
Simply push out your factory bushings, weld the brace to your toe link and re-install your bushings. In the coming weeks we will have a polyurethane bushing set to replace those factory rubber bushings also.
Give us a call if you have any questions.
-Aaron
Aaron Pfadt is offline   Reply With Quote
Old 12-03-2009, 01:02 PM   #2
Aaron Pfadt
FEA on control arm
At Pfadt, we are not just content with building products that look pretty. We design all of our pieces to take care of problems and needs that your Camaro has. There has been a lot of talk about fabricated control arms for the rear suspension for these cars. As is typical for Pfadt, we started by looking at the factory pieces to see where the deficiencies are.
Here is a rear trailing arm (the toe link) shown with a 1000 lb tension force in it. A realistic cornering load. The deflection in the steel arm itself is 2.4mm. That is obviously not conducive to good handling and cornering feel. The deflection amount is almost exactly the same in compression. The shadowed arm in the photo shows the displacement (multiplied for visualization).
Armed with this information, we decided that we could stiffen up that arm with a simple, inexpensive DIY brace.
With the brace installed on the part, the deflection is reduced to less than 1mm with the same load.
Here is the same analysis of the toe link with the brace in place.
Look for more fabricated control arm pieces from Pfadt in the near future, complete with the analysis to back them up.
-Aaron
Old 12-03-2009, 01:13 PM   #3
Windy City
Windy City's Avatar
Drives: Not enough room here!
Any word on a graphite drive shaft for the Auto Camaro?
BEWARE OF THE LPE BROTHERHOOD!
Remember: You can sleep in your car, but you can't drive your house!
Windy City is offline   Reply With Quote
Old 12-03-2009, 02:32 PM   #4
SSchase
SSchase's Avatar
Drives: 2010 camaro SS/RS LS3
thats awsome might have to get a set. hey are you guys gonna come out with some sort of chassis brace? im very impressed with what ive been reading about pfadt.
SSchase is offline   Reply With Quote
Old 12-03-2009, 04:48 PM   #5
Aaron Pfadt
We've got both a strut tower brace and a set of undercar braces in the works.
Here is the Strut Tower brace. This one is the revised design from the unit shown at SEMA. It now clears the Magnuson supercharger with ease.
Here is one of our series of undercar chassis stiffening braces. This unit is much larger than it looks in the rendering. We'll post some photos of it on a car in the next couple of days. The unit is almost 30" square and weighs 8 lbs. It is super light and stiff.
-Aaron
Old 12-03-2009, 05:13 PM   #6
Windy City
Windy City's Avatar
I guess not!
Old 12-03-2009, 05:22 PM   #7
Aaron Pfadt
I guess not!
We're actively working on driveline solutions. We think that the weakest link right now is not the shaft assembly itself, but the rubber flex joints. We will probably have a solution for those very soon and follow that up with a complete driveshaft solution. It is not a trivial solution to put a 1-piece carbon shaft in these cars. You must have a point of axial takeup (the spline section does that on the factory shaft) for engine and differential relative movement and chassis tolerances.
We're working on it, but it'll be down the road a little while.
-Aaron
Old 12-03-2009, 06:04 PM   #8
Windy City
Windy City's Avatar
Thanks for the reply!
I'll be ordering sway bars, are they in stock?
Old 12-03-2009, 07:10 PM   #9
Aaron Pfadt
We had a bit of a run on the sways. We have the Balance bars in stock, but the Pfadt Sport kit is out of stock temporarily. We'll be shipping them again before Christmas.
-Aaron
Old 12-03-2009, 07:20 PM   #10
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
Got my sways on order. Pfdat makes awesome products. Can't wait for more.
Nationwide Turf
"artificial turf factory"
lawdogg149 is offline   Reply With Quote
Old 12-03-2009, 07:25 PM   #11
eynigush
SoCal C5 Family Member
eynigush's Avatar
Drives: 2010 Camaro SSRS Rally Yellow
Great looking product.
Kooks 1 7/8 headers w/high flow cats
Magnaflow Cat-back Competition Series
Cold Air Intake by CAI Inc.
eynigush is offline   Reply With Quote
Old 12-03-2009, 08:15 PM   #12
SSchase
SSchase's Avatar
thanks for the info. looks like ill be ordering your sport package and the brace when its out.
Old 12-03-2009, 11:41 PM   #13
6liter
6liter's Avatar
Drives: BLK
I need to order some to finish my setup. how much and when will you have them in stock?
'10 Camaro 2SS/RS 6spd - Mods: Kenne Bell 2.8, Kooks, Wortec Bi-Modal Exhaust & Big Brake Kit (12piston front), MTI Shifter, BC Racing Coilovers, CCW Thunderbolt, Hotchkis Sway Bars, Carbon Fiber and satin wrap. Thanks to Hartely Automotive for helping with this build.
6liter is offline   Reply With Quote
Old 12-04-2009, 11:29 AM   #14
Aaron Pfadt
I like the CCWs. I'm thinking of calling John to get a set for our new Silver SS.
If you are asking about the braces, they are in stock and ready to ship right now. They will be shown on our website in a matter of minutes. I'd tell you the price, but then I'd get banned by the Camaro5 mods.
Call for any info.
-Aaron
Camaro SS Launch Control jdpickering Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 35 12-23-2009 10:29 AM
Transmission output shaft hiller72 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 267 12-02-2009 09:39 PM
Those who are on hold for Quality Control check in logan1080 Camaro Price | Ordering | Tracking | Dealers Discussions 3 07-06-2009 07:03 PM
U.S. plans to require stability control on all new cars KILLER74Z28 General Automotive + Other Cars Discussion 3 09-14-2006 07:08 AM
