HeadlightArmor
Old 12-02-2009, 09:28 PM   #1
CBH
VETT 4 5
CBH's Avatar
Drives: Yellow 1SS/RS w/ Clutch
Backwards Calipers
My car came in today, but I won't get it till Saturday.
I did notice why it's so hard to get wheels that fit. The calipers are backwards !! Why the heck are the pistons on the OUTside of the rotors ? I've never seen this on any other car. The brake lines are hanging out there to get sheared at the first sight of road debris.
What advantage could there be for this design ? Better cooling perhaps, but how much gain could there be.........
CBH is offline   Reply With Quote
Old 12-02-2009, 09:36 PM   #2
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
the pistons are on both sides of the rotor, 4 piston calipers(mounted solid)
you do not have to worry about the brake lines connecting the caliper 1/2's,, many performance cars are set up the exact same way
Old 12-02-2009, 09:41 PM   #3
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Bingo! Brembo 4 piston calipers and vented discs at all four corners.
Why do my front Brembo Calipers have stick on wheel weights on them? 55Designs Suspension / Brakes / Chassis 10 04-14-2014 01:07 AM
colored brake calipers ? BELLSS Suspension / Brakes / Chassis 5 12-29-2009 11:46 PM
Painted calipers. alfie43 5th Gen Camaro SS LS LT General Discussions 3 11-28-2009 10:46 AM
POR-15 for brake calipers? navyflyer72 Wheels and Tires Talk Sponsored by The Tire Rack 1 06-24-2009 02:46 PM
Glossy Black Calipers ChevyBoiSS Wheels and Tires Talk Sponsored by The Tire Rack 7 02-17-2009 09:05 AM
