Old 07-25-2008, 01:33 PM   #1
Rocks RS
Rocks RS's Avatar
Drives: 2010 Camaro 2LT/RS
Premium recommended?
When Gm says this, what do they really mean?
Do they mean you should only use 92+ octane?
Do they mean you should use 92+ octane when possible, but the car will "live" on 89?
or does it mean you can run it on 87 octane and occasionally put the good stuff in it or put in a octane booster?
I had a 2006 Impala SS with the 5.7L and it recommended the Premium and that is all I used. I always wondered though.
Rocks RS is offline   Reply With Quote
Old 07-25-2008, 01:57 PM   #2
Jak
Jak's Avatar
Drives: 03 Dodge Dakota
Yeah, I'm interested in the answer too. To me it sounds like they'd rather you use 92+, but you can use a lower grade with a slight loss in performance. Now it seems if they only wanted 92+ they'd say high grade only. Least that's my take on it.
Jak is offline   Reply With Quote
Old 07-25-2008, 02:00 PM   #3
willisit
Drives: Vauxhall Monaro VXR
This conversation has already been had elsewhere - but the compression ratio on the LS3 (V8) needs premium. Same as the LS2 (the '1 could run on crude oil though).
Dan
2005 Vauxhall Monaro VXR. Sport pac - Road Response Pac - Ripshifter
2005 Vauxhall Astra 1.6 Sport (ug)
2001 Honda CBR 600 F
willisit is offline   Reply With Quote
Old 07-25-2008, 02:50 PM   #4
jmliptak
Drives: D
Its like the Vette in the stats, recommended but not required...The compression on the v6 is higher(11.3 vs 10.7), but does not require premium...You will lose some top end power as the computer dials things back, but lots of Vette guys are running regular right now with no ill effects other than the loss of some top end...Sorry tried to copy the table from the press release, the spacing did not come over well....
http://wilsonniblett.wordpress.com/2...press-release/
jmliptak is offline   Reply With Quote
Old 07-25-2008, 03:05 PM   #5
Rocks RS
Rocks RS's Avatar
Thanks. That is what I was looking for. I am fine with losing a little top end, since all I see where I live is the weak V6 'Stangs. I just did not want to do any major damage.
Old 07-25-2008, 03:13 PM   #6
jmliptak
Drives: D
There has been a lot of confusion, but it appears to be like the Vette in that regard...
Old 07-25-2008, 07:43 PM   #7
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
you will lose more than just top end.
lower octane fuel will hurt your gas mileage in a car that is made to run premium and it will also pull from your power. yes you can run regular, but you are better off running at least 89 or higher or the manufacturer's recommendation.
i run 93 octane unless i cant find it then i will run 91 and ill add a bottle of STP octane boost. ive run 89 on one fillup but i only put 3 gallons in to get me to a place with higher octane gas. 87 has never touched my tank.
another thing to keep in mind is that a 3 pt octane booster will not bump 89 up to 92 octane. Under the North American octane system AKI (Anti-Knock Index) pump fuel is graded as (RON+MON)/2. Meaning if a fuel has a RON (Research Octane Number) of 96, and a MON ( Motor Octane Number) of 90 its AKI would be 93.
basically, you add the octane rating to the MON. so for our 89 octane the MON is roughly 90 and the MON is 88. add 3 to 88= 91
91+90=181
181/2=90.5 octane.
so in effect you are getting 1.5 points even tho the bottle says 3 pts.
here's a good writeup with MON and RON testing of octane boosters
http://volvospeed.com/Reviews/octane_boosters.html
I piss excellence
and fart awesomeness
Old 07-25-2008, 08:57 PM   #8
gunslinger
Drives: 1998 Z28 M6
ONLY 91 here in Cali, except for the Union 76 100-Octane unleadded racing fuel @ 15.00/gallon
gunslinger is offline   Reply With Quote
Old 07-25-2008, 10:49 PM   #9
CamaroSpike23
Truth Enforcer
and thats part of the pollution problem over there... that on top of the fact that there are billions of cars on the road over there...lol
I piss excellence
Old 08-03-2008, 03:00 PM   #10
cam346
CAM346
cam346's Avatar
Drives: 99 t/a
i be running the highest avail. which is 93 here. i want all my ponys acounted for.
cam346 is offline   Reply With Quote
Old 08-03-2008, 03:16 PM   #11
CamaroSpike23
Truth Enforcer
93 during the week, 112 on the weekends...lol
I piss excellence
Old 08-03-2008, 07:12 PM   #12
gunslinger
Drives: 1998 Z28 M6
How does 91 increase pollution?
Is that 112 unleaded?
Old 08-03-2008, 09:39 PM   #13
CamaroSpike23
Truth Enforcer
comparing it to 93 and the fact that with that being the highest available, most people will put 87 in their cars as it is the cheapest, lowering your emissions and performance. multiply that X's the number of vehicles on the road out there in Cali at any given pt in time, and you wonder why everything has a sticker that says "has been known to cause cancer in california" its not the product, its the shit-ton of smog created by the millions of cars on the roads over there.
and yeah, its unleaded... tho they have 113 leaded but i wont mess with that.
I piss excellence
Old 08-03-2008, 10:43 PM   #14
rcreechssr
rcreechssr's Avatar
Drives: 2006 SSR 6 speed
Cool My 2 cents worth
With the new computer controlled engines, it would appear that octane rating is not as critical to prevent pre-ignition as in older engines. These engines will self adjust and run on 87 octane. However, as stated by others in this thread, you will lose some performance and in my experience some gas mileage (1-2mpg).
Now the economics. 92 octane is generally $.20-.25 more than 87 octane. My logic says that in a typical 20 gal. fill up, I'll pay roughly $4.00-$6.00 more per tank. In my opinion, that aint bad for a tank of higher performance, and better gas mileage. Just a thought.
rcreechssr is offline   Reply With Quote
Pricing Speculation of the 5th gen - (not actual) CamaroSpike23 Camaro Price | Ordering | Tracking | Dealers Discussions 281 01-17-2009 06:22 PM
Premium!? Navy Blue Off-topic Discussions 16 04-17-2008 04:29 PM
ALERT: Lutz mentions engine options for Camaro -- 4 cylinder turbo a possibility! Scotsman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 269 03-20-2008 01:48 AM
Ford gets 5 top quality awards KILLER74Z28 General Automotive + Other Cars Discussion 5 06-13-2007 12:28 AM
Premium stereo system? c00l usmc 5th Gen Camaro SS LS LT General Discussions 8 05-09-2007 02:36 PM
