Old 07-27-2008, 04:10 PM   #15
SSideways
SSideways's Avatar
Drives: 99 Chevy Camaro
Originally Posted by fastball View Post
If I remember the way it works on the Cobalt SS, you can hold the gas to the floor in every gear without letting up to shift. When you stomp the clutch, it holds the revs right where they are when you stomp the clutch for a second or two while you shift.
Without it, you'd either bounce the rev limiter, or as 1973z-man said, carry your crankshaft as you walk home.
I just finished reading the new car and driver. This is exactly how they described the "no lift shift" feature. As for the launch control on the manual... "The engine computer limits revs and fiesses the throttle for traction after the clutch dump."
SSideways is offline   Reply With Quote
Old 07-28-2008, 11:29 PM   #16
topgun1
topgun1's Avatar
Drives: 10 SIM 2SS/RS LS3
It's been my experience in manuals to launch at about 2500 rpm and then dump the clutch. After alot of runs in the Acura, that was about the best engine speed I found to launch from. Of course, it will vary somewhat from car to car, but yes, launching from redline is a disaster waiting to happen.
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears....
topgun1 is offline   Reply With Quote
Old 07-28-2008, 11:41 PM   #17
boxmonkeyracing
juggernaut
boxmonkeyracing's Avatar
Drives: VRSCF, 2011 SS vert
Send a message via AIM to boxmonkeyracing Send a message via Yahoo to boxmonkeyracing
if your drivetrain can handle it then you can do it. seen a lot of racers around here launch at that high and some built up the drivetrain some didn't. the one's that didn't blew something up. lol.
my experience with the camaro 3200-3500 was pretty good and not dumping the clutch but quickly and smoothly releasing it. . .but it's so fast that it almost feels like a dump.
We do not want to use the Z28 moniker on a car that does not deserve this hallowed name.
boxmonkeyracing is offline   Reply With Quote
Old 07-29-2008, 08:43 AM   #18
o2camaross
o2camaross's Avatar
Drives: 2010 2SS/RS & 04 silvy
^ yea after i did all my mods to my 2002 SS i was launching at 4000 rpm, i was prolly pushing that weak little 10 bolt to it max but i didnt have the car long enough to break, it. it was stolen in january and im building another garage for my baby.
o2camaross is offline   Reply With Quote
Old 07-29-2008, 11:08 AM   #19
boxmonkeyracing
juggernaut
there was a guy here that put hoosier slicks on his 10 bolt and was saying he was going to drop the clutch at 5000 rpms. he also had cam+tune and bolt ons. he was lucky nothing happened to his rear end.
Old 07-29-2008, 11:37 AM   #20
SoFlaZ
SoFlaZ's Avatar
Drives: Nothing special :-(
I think it does what most you say, limit the revs after the launch so there is minimal wheelspin. OR I think it realizes when you are holding the clutch and have it sitting in 1st, when you rev it, it wont go past a certain rpm. I think it is the first idea though.
Launch control would have been great on the vette's because my last time at the drag strip, a guy with a spankin new LS3 with the paper dealer tag still on it was there and almost lost to a new tundra(had a 100 shot) because he dumped the clutch so hard he spun and barely moved till he shifted to 2nd by the light tree. Some people need these nannies because they get too excited or something. I would like it to help me get better at launching until I can do it as good as the comp can.
SoFlaZ is offline   Reply With Quote
Old 07-29-2008, 02:23 PM   #21
o2camaross
o2camaross's Avatar
yea he would deffinetly be asking for it. i had a cam ls7 clutch and nitto drag radials and i was pushing it. I maiss that car sooo much
Old 07-29-2008, 03:06 PM   #22
ckellyme3
ckellyme3's Avatar
Drives: 1986 IROC 406 stroker
Originally Posted by jdpickering View Post
It is said that the SS Camaro with the Manual Transmission will have Launch Control. How will this work? Everything I've seen on launch control is targeted toward Automatics wth pattle Shifters. You put the car in launch mode rev the motor and let off the break. It turns town Traction Control put the computer to allow the car to max out RPM's before shifting and just optimizes the shift points. Well it can't do all this on a Manual because you control the shift points and you control the clutch so what do they mean the SS Manual will have launch control?
You are badly misinformed. Launch control works in manual transmissions only. You simply select it (in the Cobolt SS and HHR SS) by hitting the traction control button twice, once to turn off the tracton control and the second time to turn on launch control. When you put it in 1st gear while holding the clutch in, you floor it and the RPM will stay right at the redline. When u release the clutch you take off perfectly. It takes all the guess work out of getting a perfect launch hence launch control and im almost positive no automatic cars have it but i could be wrong.
ckellyme3 is offline   Reply With Quote
Old 07-29-2008, 03:19 PM   #23
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
Not necessarily true. Maybe the Cobalt's "Launch Control" feature works like that, though it doesn't sound like it'd make a perfect launch at all; it sounds like all you'd do is burn off your tires. Anyway, without it, a modern car isn't going to go past redline anyway, but it might do a more sudden fuel cut resulting in "bouncing off the rev limiter" rather than smoothly holding redline.
The VW GTI with their DSG dual-clutch automated manual transmission (they don't offer a traditional "slushbox" automatic) has a "Launch Control" feature that allows the driver to launch like a high-RPM clutch dump even though there's no clutch pedal. That's what I thought of when I heard of "Launch Control" in the Camaro.
Who needs a computer to baby them for launching a manual transmission?
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Old 07-29-2008, 03:43 PM   #24
greenrail
Comic Curmudgeon
greenrail's Avatar
Drives: 2010 Camaro 2SS-2010 VW CC Sport
Gee, when I was young we didn't touch the clutch pedal when power shifting!!!
And By the way - It is "Pedal" not "Pettle"
And it is "Brake" not "Break".... You brake with your foot, you break when you wreck your car.
greenrail is offline   Reply With Quote
Old 07-29-2008, 07:33 PM   #25
wildpaws
wildpaws's Avatar
Drives: 1999 Blazer
Actually for what he was trying to say it was paddle not pedal or pettle.
Clyde
wildpaws is offline   Reply With Quote
Old 07-30-2008, 10:01 AM   #26
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
yeah, give him a "break".
(I couldn't resist!)
Old 07-30-2008, 10:55 AM   #27
jdpickering
Drives: 99 Monte Carlo Z34
Season 10 Episode 3 of Top Gear the tested a Ferrari 599 with F1-SuperFast paddle shifter with Launch control in which they put the car in first turned traction off held down the break and put in launch control. Rev'ed up the motor and let off the break. The launch control on Super Cars is all i've ever seen launch control on before. And it more or less optimized the shift points or allowed for higher RPM's before shifting.
jdpickering is offline   Reply With Quote
Old 08-02-2008, 08:05 PM   #28
pruettfan
Drives: 2010 Camaro SS / 2011 Z28
I think it is very cool that GM has included launch control on the Camaro. The great thing is you don't ever have to use it if you don't want to. Does launch control work, yep, pretty well.
pruettfan is offline   Reply With Quote
Camaro Laws ChevyNut Off-topic Discussions 107 11-09-2016 06:40 PM
I'm really disappointed from the camaro lap time in Nurburgring!!! _GTO_ 5th Gen Camaro SS LS LT General Discussions 84 11-30-2009 10:12 PM
CNN: Camaro: From sketchpad to street - The rebirth of a muscle car ... Gatecrasher 5th Gen Camaro SS LS LT General Discussions 49 10-05-2009 04:33 PM
Camaro home page is up @chevy.com!!! Engine Specs and Official Colors! ChrisL 5th Gen Camaro SS LS LT General Discussions 66 07-22-2008 01:08 PM
