tandtperformance.com
5th Gen Camaro SS LS LT General Discussions General 5th generation Camaro topics not covered by other subforums.
Old 07-25-2008, 05:28 PM   #1
carman
Drives: '87 IROC Z, '91 Z28
Total cost of ownership SS
With all the focus on purchase price and gas mileage, an acquaintance of mine indicated that a brake job on Brembo brakes runs 3 to 4 times the cost of more conventional brakes.
Is that correct?
Thanks.
carman is offline   Reply With Quote
Old 07-25-2008, 05:37 PM   #2
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
Realy shouldn't be that bad. Besides unless you are racing, GM brakes are lasting a long time. My parents suburban has 100k in the city and the original pads. Plus the aftermarket pads are all about the same price.(not including the Z06 with 6 pads per front wheel!)
Robert91RS is offline   Reply With Quote
Old 07-25-2008, 05:41 PM   #3
bouncertime
Miller High Life
bouncertime's Avatar
Drives: 2009 Silverado and 2007 Cobalt SS
No kidding, my '01 Blazer is at 80K miles and I am still using the original pads. I checked them the last time I changed my oil and they still have plenty of pad left. I will probably sell it before they wear out.
Jimmy
bouncertime is offline   Reply With Quote
Old 07-25-2008, 07:14 PM   #4
AnEvilPenguin
AnEvilPenguin's Avatar
Drives: 05 Impala SS 86 Trans Am
i don't think the price of replacement pads for the 4 piston calipers will be too bad, they are alot if you buy them from brembo or SSBC though, also, pad ware depends on alot of things, like how hard you are on the brakes, highway/city, the make up of the brakes, manual or automatic, how hot you run the rotors, ect. generaly GM's OEM brakes are pretty good compaired to the oems ford uses, ford likes to use a really soft compound because it is quieter and easier on the rotors. and just to continue the compairing, I had a 1979 chevy C10 truck that came with c20 brakes and rear suspension, I sold the truck in 2005 with 172,XXX miles and still the original brakes, keep in mind though, I babied the truck all it's life and it was a manual trans, so the brakes were hardly ever used to slow down.
AnEvilPenguin is offline   Reply With Quote
Old 07-25-2008, 07:25 PM   #5
Craig
Drives: '01 Z28
Pads are pads and rotors are rotors, there will be nothing "special" about the composition of these brakes compared to other cars. Repair them yourself when the time comes, it's not a tough job. Take the car to a brake shop for replacement and you'll get taken to the cleaners no matter what car you drive. I just replaced the pads & rotors (all 4 sides) on my '01 Z28 for well under $200 by purchasing the parts online and doing it myself.
Craig is offline   Reply With Quote
Old 07-25-2008, 07:53 PM   #6
CamaroSpike23
The Jalopy Jedi
CamaroSpike23's Avatar
Send a message via MSN to CamaroSpike23 Send a message via Yahoo to CamaroSpike23
Is that correct?
Thanks.
yes and no.
depending on the setup, yes, it can easily cost a lot. if you swap out a 4 piston caliper and blank disc with regular pads for 6-8 piston calipers, drilled and slotted rotors, high performance ceramic pads... then yes it can get expensive. throw in that you can swap out for larger brakes as well and the price goes up.
pads are not just pads and rotors are not just rotors. now, regular pads are regular pads and blank rotors are blank rotors, but when you start getting into ceramic pads and drilled/slotted rotors, itll take you to the bank if you arent carefull. but if you are just swapping stock for stock, then yes it will not be very expensive. but when you start going with performance stuff over stock, the price adds up.
Originally Posted by Bulldogwinters View Post
Read that link that Spike posted, it'll tell you everything you need to know.
I piss excellence
and fart awesomeness
Old 07-25-2008, 09:05 PM   #7
Craig
Drives: '01 Z28
Yes of course once you get into upgrades then the sky is the limit, I should have clarified that. But if we're talking routine maintenance then there is nothing exotic or unusual about the new Camaro's brake system that would drive up the cost. Now with 14" rotors & dual piston pads it's going to cost a little more than the brakes on mom's Camry but it shouldn't break the bank either.
Old 07-25-2008, 11:01 PM   #8
stovt001
stovt001's Avatar
Drives: 2006 Cobalt, 2004 Taurus wagon
I'll also confirm GM's long lasting brakes. My father-in-law is very belligerent towards domestic cars and tries to find something to pick on my Chevy every chance he gets. Last time I was at his house he looked at my brakes and remarked how impressed he was that the brakes had so much life left in them. Overall GM is great about having a very low overall cost of ownership.
"It's kind of fun to do the impossible" - Walt Disney
There's a great big beautiful tomorrow
shining at the end of every day
Just a dream away
stovt001 is offline   Reply With Quote
Do you want the Z28? ChrisB Camaro ZL1 Forum - ZL1 Specific Topics 1616 09-04-2010 11:49 PM
Why do you think the Z28 is the higher tier? The_Blur Camaro ZL1 Forum - ZL1 Specific Topics 181 10-14-2009 08:08 PM
Camaro LS / LT / RS / SS specs and options! CamaroScotty 5th Gen Camaro SS LS LT General Discussions 119 09-02-2008 09:46 PM
Camaro does the Nurburgring test track in 8:20 2sharp 5th Gen Camaro SS LS LT General Discussions 45 07-23-2008 03:17 PM
2010 Chevy Camaro to offer two V6s at launch; Z28 to trump SS? radz28 Camaro ZL1 Forum - ZL1 Specific Topics 51 06-23-2008 12:12 PM
