Old 12-07-2009, 10:46 PM   #1
Chris-10
Chris-10's Avatar
Drives: 2ss/rs vr 6m
camber bolt ?
had the car lowered this week at a local speed shop, installed h&r springs. went today to get the alingment done & there saying i need camber adjustment bolts, which happen to cost $110. do these bolts have to stay there or would any bolt that fits in there to adjust the camber,adjust, tighten & then remove work ? i'm talking about the front, the rears are something different.
Old 12-08-2009, 12:00 AM   #2
JICPerformance
Here to make you faster
Drives: 2005 GTO supercharged 2009 GXP
The top hole on the front struts is elongated to allow for camber adjustment. A M10x1.5 threaded bolt may be inserted in the knuckle just above the top strut bolt to aid in setting the camber with a load on the car. There is a threaded hole already there that will allow for the insertion of this bolt.
If the shop is unable to reach the proper adjustment, the strut holes may be elongated slightly more to achieve their setting. DO NOT elongate the knuckle hole
JICPerformance is offline   Reply With Quote
Old 12-08-2009, 12:08 AM   #3
Chris-10
Chris-10's Avatar
if you look through the front of the top wheel you can see a threaded hole, thats what they are saying is used to adjust the camber.
i think i'm getting hosed, the more i think about it ,that is to just to do the adjust.
Old 12-08-2009, 08:04 AM   #4
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
We have lowered a few new camaro's the front is elongated from the factory,so far we have not needed any more adjustment than what is there.The threaded hole in the spindle is for installing a bolt to help make the front camber adjustment but is nothing special.The rear how ever may need a larger camber\toe adjuster kit depending on how low you go.We are using the pedders cam kit when needed which gives more adjustment range.
Bruce@raymondsperformance is offline   Reply With Quote
Old 12-08-2009, 11:13 AM   #5
BLACK10
BLACK10's Avatar
Ive lowered three camaros and all off them were aligned to factory spec with no other parts needed
Old 12-08-2009, 04:46 PM   #6
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
You don't need that, the front has the top hole is elongated for the camber alignment, I lowered the front 2" and did not have this BS.
Old 12-08-2009, 04:53 PM   #7
Luvpilot
Luvpilot's Avatar
Drives: GM
Hey anyone have the alignment specs?
None of the local shops have anything on the car yet.
Luvpilot is offline   Reply With Quote
Old 12-08-2009, 05:00 PM   #8
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Yeah... that's what I've run into... local shop does an amazing job doing alignments but they are waiting to get the specs too...
Also, $110 for camber bolts is a bit extreme... yikes! You should be able to get a set of camber bolts for under $40!
scrming is offline   Reply With Quote
Old 12-08-2009, 05:04 PM   #9
Luvpilot
Luvpilot's Avatar
Drives: GM
I did find these..
http://www.gminsidenews.com/forums/f...t-specs-69389/
I went over to the local shop with them and we're going to try it tomorrow.
Be nice to have the bonafides though
Old 12-08-2009, 06:55 PM   #10
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
Pedders offers 3 alignment kits for the Camaro:
PDUSACAMFULL CAMARO REAR EXTENDED CAMBER, TOE ADJUSTERS,
FRONT CASTER ECCENTRICS & CAMBER ADJUSTERS
PDUSACAMFNT CAMARO FRONT CAMBER & CASTER ALIGNMENT KIT
PDUSA5420 ZETA REAR CAMBER AND TOE ALIGNMENT KIT
The PDUSA5420, allows you to get your rear cambers to an ultimate setting that is just getting into specs. This is a great setting to reduce understeer. It does this by making a thicker eccentric with the mounting hole in a different location, to give the eccentric more throw.
PDUSA5420 The importance of this kit is to make your casters adjustable, while increasing them at the same time. We did throw in a camber adjustable bolt. But if this is all you need, just buy one at the hardware store and install it. BE CAREFULL!!!!! NO ONE TOLD MONROE IN THE USA THAT THEY NEEDED A BLOCK FOR AN ADJUSTABLE BOLT. SO IF YOU APPLY TOO MUCH PRESSURE, YOU CAN DENT TOE STRUT ASSEMBLY
PDUSACAMFULL contains both sets.
thanks
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 12-08-2009, 06:58 PM   #11
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
I have 2 pages for the alignment from GM and I'll scan them and post them this evening...
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 12-08-2009, 07:47 PM   #12
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
100 bucks for camber bolts is crazy-if i had them cheaper then id think about it
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 12-08-2009, 08:05 PM   #13
Luvpilot
Luvpilot's Avatar
Drives: GM
That would be GREAT!
Thank you.
Old 12-08-2009, 08:07 PM   #14
Michael_Js
Michael_Js's Avatar
Damn! The installer kept the 2 sheets I received from the Chevy Dealer!
Sorry, my fault I guess!! My dealer just printed me out the pages on the alignment as well as the specs. I suggest just going to your dealer and getting the info. I'll have to remember to get the papers again next time I stop in...
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 09:25 PM
PWA "The Lounge" DGthe3 Off-topic Discussions 143773 11-06-2010 12:00 PM
AIRAID Intake System For 2010 3.6L V6 Camaro Airaid Filters Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 362 02-26-2010 09:35 PM
9 bolt vs 10 bolt wilnot 3rd Generation Camaros 2 09-30-2009 05:22 PM
