BeckyD @ James Martin Chevy
Old 12-08-2009, 12:40 PM   #1
Toastylicious
My car goes Vrooom.. You?
Toastylicious's Avatar
Drives: 2010 Rally Yellow Camaro LS
Car Dies Randomly
Hi Guys and Gals,
Well it seems to happen about once a month out of the blue for no reason. The first couple of times it died in my driveway and now today it has died when I was going down the road but I still had power to the radio and the blue rings around the gauge clusters I was wondering if anyone else has had this problem before or if there is a bulletin for this particular problem. I tried searching the forums and couldn't come up with anything... Im driving an LS A6 with 2200 miles on it.
Toastylicious is offline   Reply With Quote
Old 12-08-2009, 12:50 PM   #2
67 Convertible
67 Convertible's Avatar
Drives: 67 Camaro Convertible
Originally Posted by Toastylicious View Post
Hi Guys and Gals,
This has never happened to me, and I don't recall anyone on here with that issue. I would get to the dealer asap.
2LT/RS RJT, Blk Rally Stripes, Beige Interior, Sunroof
Placed order at dealer 4/24/09
1100 - 4/28/09
2000 - 5/01/09
2500 - 5/05/09
3000 - 5/05/09
3300 - 5/30/09
3400 - 6/05/09
3800 - 6/18/09
4000 - 6/18/09
4B00 - 6/18/09
4200 - 6/22/09
5000 - 7/01/09
6000 - 7/01/09 It's Home!!
0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less
67 Convertible is offline   Reply With Quote
Old 12-08-2009, 12:51 PM   #3
Chevyrocker
Weekend Rockstar
Chevyrocker's Avatar
Drives: Depends on the day...
^ What he said. Might just be an electrical issue, but that takes forever to diagnose and correct.
Shortcuts can slow you down...
Chevyrocker is offline   Reply With Quote
Old 12-08-2009, 03:59 PM   #4
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
If everything else is ok, then you are losing ignition power to the engine computer for a split second. Probably a loose pin or bad connection or a harness tied too tight and getting pulled partially apart.
HeavyD is offline   Reply With Quote
Old 12-08-2009, 04:01 PM   #5
ffrcobra_65
Old 12-08-2009, 08:25 PM   #6
Toastylicious
Ya the second time it happend while it was sitting in the driveway I took it to the dealer and they checked all the connections and they couldn't find anything or "replicate" the problem and it's getting kind of flustrating mabey I need to find another dealer.
Old 12-08-2009, 09:11 PM   #7
HeavyD
HeavyD's Avatar
I am a heavy truck tech. Believe me, I know how frustrating some of these problems can get. As a tech some of the hardest problems to find are the ones that are very intermittent! When we have a customer show up that has had a problem, but everything is ok now we will try as best as possible to find something but it can literally be looking for needle in a haystack. You also have to realize that warranty won't pay them to look all day either, they probably won't get paid at all for looking at it because they didn't do anything. The Camaro is still a new car to them, it will take time before they know all the little tricks about them. I know this sucks, but work with them, be patient. From your description the problem is happening very infrequently, it will be hard to find. You are looking at anything involved in the ignition to the engine, key switch, ECM, a bunch of relays, probably 20 feet of wiring and 10 different connections. To be honest, it would be better for it to quit and never work again, they would find the problem for sure that way! Hang in there!!!
Old 12-08-2009, 09:42 PM   #8
Toastylicious
Thanks heavyd sometimes it seems that we need to have an IT degree to fix new cars these days lol.
Old 12-09-2009, 10:46 AM   #9
DangerZL1
Drives: Future ZL1 Owner
I'm going to suggest being agressive with this problem and working with one dealer only. If they don't find it on another attempt, I'd get customer service involved. Not trying to scare you, but this problem is a safety issue and could easily cause an accident.
I had a GM car do this a long time ago and they never found the problem. It died in the middle of an intersection, and I finally traded it in.
DangerZL1 is online now   Reply With Quote
Old 12-09-2009, 10:55 AM   #10
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
Your not an early VIN range are you???
Old 12-09-2009, 12:08 PM   #11
Lineman
Drives: 04 Tahoe and 2010 2SS M6
Hi Guys and Gals,
Just a thought - check the battery cable sticky. It's for V8s but it might give you some ideas
Lineman is offline   Reply With Quote
Old 12-09-2009, 12:40 PM   #12
Toastylicious
I believe it's around 23000
Thanks Ill do that
Old 12-09-2009, 12:44 PM   #13
Camaro_Corvette
36.58625, -121.7568
Drives: Team 1LE
Thanks Ill do that
Answers my thoughts on it. I got nothing man. I figured it would be the battery cable issue, but i was under the idea that that was solved a long time ago.
Old 12-09-2009, 02:12 PM   #14
jhmurphy
jhmurphy's Avatar
Drives: Grey Beast
Had something like that happen to me the first week I had my car. When they fixed the battery cable issue at the factory they pulled to hard on the wireing harness and seperated a connection by the starter but it was still covered by the shrink sleeve. When the dealer figured out which one it was he pushed them back together until he heard a click since he could not see them through the shrink sleeve and i have not had an issue since. Not sure if your issue is them same but something to checking out
2SS/RS A6 and some go faster parts
jhmurphy is offline   Reply With Quote
What's considered a Muscle Car? SyN General Automotive + Other Cars Discussion 125 09-25-2010 01:04 AM
The first 4 months of owning my car - pics / vids included Crowley 5th Gen Camaro SS LS LT General Discussions 19 09-30-2009 02:05 PM
Sports Car???? Eduk8r 5th Gen Camaro SS LS LT General Discussions 50 09-21-2009 03:31 AM
The first week with un-pink camaro! (a review with pics) pinkcamaro10 5th Gen Camaro SS LS LT General Discussions 31 07-02-2009 08:54 PM
What makes a car a "tuner" car? Dentyneice General Automotive + Other Cars Discussion 8 05-11-2009 11:19 PM
