HeadlightArmor
Old 12-10-2009, 10:05 PM   #1
BITCHIN CAMARO
BITCHIN CAMARO's Avatar
Drives: 2010 Camaro RS SS
Pedders EP6579 Radius Inserts
Anybody install these? I just got mine with no instructions. Are these just unbolt the radius arm insert bushings and retighten? Anything out of the ordinary?
Thanks,
Rob
BITCHIN CAMARO is offline   Reply With Quote
Old 12-10-2009, 11:10 PM   #2
69rsss383
69rsss383's Avatar
Drives: Corvettes, Camaros, Chevelles
That's all I did. It's straight forward except that I had to loosen the 2 lower bolts on the washer bottle to get the driver side radius rod bolt out.
2010 2SS/RS, SIM, Pedders coilovers & bushings, Hotchkis sway bars & chassis braces, Corsa cat back, DT shorties, ADM Race CAI, VMax CNC TB, Jannetty Racing tune.
69rsss383 is offline   Reply With Quote
Old 12-10-2009, 11:14 PM   #3
BITCHIN CAMARO
Thank You
Old 12-11-2009, 01:41 AM   #4
69rsss383
69rsss383's Avatar
One more thing I should mention. Retorqued the radius rod bolts to the factory specs once the weight is back on the car.
Old 12-11-2009, 05:13 AM   #5
ChevyThunder
Drives: pinto
You need this shirt
ChevyThunder is offline   Reply With Quote
Old 12-12-2009, 12:47 AM   #6
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
They are seriously easy. Remove the front bolt, and just pull the control arm to the rear, and the arm will come out of the fixture. Pop the old ones off with a screw driver, then pop the new ones on, the reinstall the arms, torque the bolts.
Now the ones that I have done, I had the struts out. So you may have to disconnect the front sway bar end links.
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 12-12-2009, 06:24 PM   #7
BITCHIN CAMARO
Not to bad. Took an hour and only had to loosen the windshield water bottle to get the drivers side bolt out.
Thanks for the input
Rob
Old 12-12-2009, 07:52 PM   #8
Info@PeddersUSA.com
Rob
It is interesting. On the WD40 Camaro, I did not have to loosen the water bottle. It was a SS. I wonder if they have made some kind of change?
thanks
mike
dms
Old 12-13-2009, 05:00 PM   #9
Rob@WretchedMS
Drives: His Wife Crazy
I haven't heard of any variances in them yet, but maybe your serious abilities scared the car in to releasing the arm to you! lol
Rob@WretchedMS is offline   Reply With Quote
Old 12-13-2009, 06:48 PM   #10
Info@PeddersUSA.com
SERIOUSLY? LOL
MIKE
DMS
Old 12-13-2009, 09:07 PM   #11
Rob@WretchedMS
lol
Zeta (Camaro/Commodore/G8) suspension details Gatecrasher Wheels and Tires Talk Sponsored by The Tire Rack 66 04-16-2009 02:11 PM
SEMA, Pedders Conference, GS Camaro, New Products JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 25 12-01-2008 02:25 PM
Pedders partnering with GM Racing on Camaro suspension Info@PeddersUSA.com Wheels and Tires Talk Sponsored by The Tire Rack 6 09-30-2008 01:14 PM
