B&M Racing
Old 12-12-2009, 07:02 AM   #1
Carlos Garza
Carlos Garza's Avatar
Drives: 2010 Camaro SS RS
MP 2300 vs TVS 2300
Since I want to install one of these babies in my car, Iíve been doing some research about the manacharger and came up on the "new and improved" version of the TVS which is the MP 2300 also by mangnuson. Supposedly, the MP is the exact same thing that's on the ZR1 Vette (LS9 engine). I'm leaning more for the MP, but most of the success stories we have seen in the forum are with the TVS...
So which one is the best option for the Camaros LS3 engine?
Should I go with the new and improved MP or the old reliable and proven TVS?
http://www.magnusonproducts.com/mp23006thgen.htm
Carlos Garza is offline   Reply With Quote
Old 12-12-2009, 08:37 AM   #2
8ty8 ls1
Resident Engineer
8ty8 ls1's Avatar
Drives: 2010 Camaro SS, 1988 GMC S-15
to me, it looks like you'd want the MP just for efficiency. its my understanding that with the 180 degree twist with 4 lobes means you won't have to spin it as fast to make as much boost. so technically it would create boost easier and just be an overall more efficient system. since the supercharger wont be spinning as fast, you won't be making as much heat, making the whole intercooling process easier. i don't know if easier is the right word, but yeah, there is a reason why GM performance division went with this type of supercharger for the zr1 and not a 3 lobe.
12.68 @ 109: LSR cai, Borla S-type axle-back, Tunes
8ty8 ls1 is offline   Reply With Quote
Old 12-12-2009, 08:38 AM   #3
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
I could be wrong but I believe the MP and TVS are the same Blower.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 12-12-2009, 08:42 AM   #4
8ty8 ls1
Resident Engineer
8ty8 ls1's Avatar
yes jannetty is correct. they're the same. which is why the tvs rocks!! lol
http://www.magnacharger.com/sc-camaro.htm look at the bulleted section. says "front inlet MP2300 tvs supercharger"
Old 12-12-2009, 09:07 AM   #5
sweaver
sweaver's Avatar
Drives: 10' CAMARO SS2 LIVERNOIS BUILT
Yes they are just dif marketing names,
sweaver is offline   Reply With Quote
Old 12-12-2009, 09:15 AM   #6
1320junkie
Drives: The Imperial Army
LOL thanks for that I was searching and thought I was going crazy..
Old 12-12-2009, 10:11 AM   #7
Carlos Garza
Thanks for the heads up... my bad
Old 12-12-2009, 11:16 AM   #8
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I think, just to be clear, it should be pointed out it's the rotors, if I'm not mistaken, that are shared with these blowers; the cases are propriatary, if you will. Eaton makes the rotors for GM and Magnuson, but GM and Magnuson (as well as Edelbrock) actually cast their own rotor cases. I was confused about this for the longest time...
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 12-12-2009, 12:18 PM   #9
ffrcobra_65
good to know even the mods get confused now and then
Old 12-12-2009, 03:04 PM   #10
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
If I ever claim I have nothing to learn from anyone here, call me on it. There's so much to learn here it's crazy. That doesn't mean I'm always open to learn, lol , but that doesn't mean I know more than any of you
Old 12-12-2009, 03:40 PM   #11
freemaSSon
Pat @ ADM PERFORMANCE
freemaSSon's Avatar
Drives: CGM SS/RS M6
MP2300 is Magnuson's Magnacharger model number. TVS refers to the actual rotor assembly which is Eaton's parts.
The TVS 1900 and TVS 2300 are internals that are manufactured by Eaton and sold to other supercharger manufacturers that engineer their own housings and use Eaton's internals.
The Eaton TVS1900 Blower is the actual system on the CTS-V and the Eaton TVS2300 Blower is the actual system on the ZR1.
"old age and treachery will always overcome youth and ambition"
author unknown
"There are two types of racers: cheaters...and losers."
Smokey Yunick
freemaSSon is offline   Reply With Quote
Old 12-12-2009, 03:58 PM   #12
Carlos Garza
Awesome info... Now what's the difference between the ls3 engine and the engine on both the CTS V and the ZR1, besides the SC?
Old 12-12-2009, 04:54 PM   #13
JICPerformance
Here to make you faster
Drives: 2005 GTO supercharged 2009 GXP
pistons, forged internals I believe on the ZR1, heads, accessory brackets, they both use the truck style throttle bodies, they both use separate supercharger belts versus the magnacharger kits using a single drive belt for all accessories and the supercharger....a LOT
MORE INFO:
The 2010 Camaro SS's 376-cubic inch, LS3 uses the same case as the Corvette ZR1's LS9, except for the "SC" engine's larger head bolt threads, piston oilers, forged steel main caps and its deck plate honing process. Other than that, everything done for the LS9 block carries into the new Camaro's LS3.
JICPerformance is offline   Reply With Quote
Old 12-12-2009, 04:56 PM   #14
JICPerformance
ZR1 engine, LS9, exploded view
Speed Inc Customer Car - Magnuson TVS 2300 603rwhp 543rwtq talwell Forced Induction - V8 24 05-02-2011 06:23 PM
MagnaCharger TVS 2300 - What fuel injectors & pulley are supplied on standard model? thenaz Forced Induction - V8 7 11-03-2009 11:23 PM
21st Century Muscle Cars TVS 2300 results 21STCENTURY Forced Induction - V8 2 09-25-2009 10:26 AM
G-Force TVS 2300 L99 Camaro SS Mike TexaSS USA - Texas 10 09-10-2009 11:20 AM
G-Force TVS 2300 L99 Camaro SS Mike TexaSS Forced Induction - V8 0 09-09-2009 10:32 AM
