Emblempros
Old 07-29-2008, 12:46 PM   #1
96CAMaro
96CAMaro's Avatar
Drives: '02 Impreza 2.5RS
Mystery fluid
Hey guys, perhaps someone can help me figure out what type of fluid is leaking near my rear differential and drive shaft end. The 'mystery fluid' is a black oil like substance all over my floor pan and rear differential. The fluid is not leaking out of my 10 bolt. The black oil like fluid has the consistancy of motor oil as far as viscosity is concerned. Car - 1996 Z28 A4 ANy help will be greatly appreciated. Thanks.
96CAMaro is offline   Reply With Quote
Old 07-29-2008, 01:20 PM   #2
aston70
aston70's Avatar
Drives: Me Nutz!! Arrrrgh...
You're sure it's not coming out of the rear end? It sounds like a rear end seal has gone bad or a faulty vent cap if it has one.
aston70 is offline   Reply With Quote
Old 07-29-2008, 05:20 PM   #3
boxmonkeyracing
juggernaut
boxmonkeyracing's Avatar
Drives: VRSCF, 2011 SS vert
Send a message via AIM to boxmonkeyracing Send a message via Yahoo to boxmonkeyracing
I'd be willing to bet it's the rear end seal like aston said. my Z28 had the same issue. have you had a rear tq arm install recently? it could be the wrong pinion angle setup.
We do not want to use the Z28 moniker on a car that does not deserve this hallowed name.
boxmonkeyracing is offline   Reply With Quote
Old 07-29-2008, 06:34 PM   #4
96CAMaro
96CAMaro's Avatar
I have not had a rear torque arm installed lately. I'm thinking that it might be a rear pinion seal on the end of the driveshaft. Thanks for the help though, guys. My car just recently hit 116,000 miles.
To date: 1 new opti spark (2 yrs ago), 1 water pump gasket (2 yrs ago), 2 rebuilt tranny's (1 from driving it hard, 1 from the Hayden tranny cooler being hooked up wrong - oops), 1 window motor (2 weeks ago), 1 regulator (2 weeks ago), 1 window (2 weeks ago), 1 starter (2 weeks ago), 1 fuel pump (2 weeks ago)
Old 07-29-2008, 07:03 PM   #5
aston70
aston70's Avatar
Sounds like you might want to check the pinion bearing(s) too. If it's bad a new seal would probably wear out quick.
Old 07-29-2008, 08:23 PM   #6
96CAMaro
96CAMaro's Avatar
Thanks for the advice - I'll have to take a look into that.
Old 07-30-2008, 07:03 AM   #7
Txturbo
Keeper of the Faith
Txturbo's Avatar
Drives: 2001 Z28 Agressively
Since you have an auto trans, it could also be transmission fluid. Some of them blow trans fluid out the vent and it gets on the torque arm, follows it the the rear end and drips off in front of the differential. If its thin and reddish, its trans fluid.Thick and brownish, its gear lube.Gear lube also has a strong smell.
2010 Camaro SS R6P
2001 Camaro Z28
1969 Camaro SS clone
Txturbo is offline   Reply With Quote
Aftermarket cooling The_Stache Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 01-11-2010 06:40 AM
Best shot yet of the Transformers 2 mystery Vette Camaro Lives On General Automotive + Other Cars Discussion 14 07-18-2008 01:43 AM
Mystery Car stovt001 General Automotive + Other Cars Discussion 32 04-07-2008 08:35 AM
