JUICEDMOTORSPORTS
Old 12-13-2009, 12:25 PM   #1
Cruz-lo
Drives: 2010 2ss RS
Question Pedders Alignment kit??
Just ordered the basic drag pack to go with my coil overs.
No way to align the rear as is!
Any one know what has to be done to install the new camber and toe bolts in the rear? Do you have to elongagte the factory adjustment slots?
I looked on the pedders site but couldnt find anything......Thanks
Cruz-lo is offline   Reply With Quote
Old 12-13-2009, 04:45 PM   #2
Rob@WretchedMS
Drives: His Wife Crazy
you don't need to modify anything, but you will need to drop the rear cradle down a bit to get the stock bolts out. When you install the new Pedders bolts install them so you can remove them with out dropping the cradle. it's fairly straight forward.
Rob@WretchedMS is offline   Reply With Quote
Old 12-13-2009, 07:38 PM   #3
sting808
Drives: 2010 SS RS
Noob question...
Is the rear camber kit bolt just smaller to get more play for adjustments?
sting808 is offline   Reply With Quote
Old 12-13-2009, 07:57 PM   #4
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
The Pedders kit has a larger off set on the adjuster bolts is how it works.They will give about 1 degree more adjustment than the stock adjusters.
Bruce@raymondsperformance is offline   Reply With Quote
Old 12-13-2009, 09:06 PM   #5
Rob@WretchedMS
Old 12-14-2009, 04:04 AM   #6
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
We also recommend reversing the toe bolts. the normally go in front to rear. but if you put them rear to front, it is easier to adjust.
Also, use some antisieze on the eccentric.
You only have to lower the cradle down enough so there is 1 thread on the cradle bolts. Hast to be lowered due to the left tie rod . There is a fuel hose there that interferes.
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 12-19-2009, 05:14 PM   #7
Cruz-lo
Drives: 2010 2ss RS
Thanks!
Well I hope its enough....I am at -1.7 and -1.8 now with the stock adjusters maxed out.
I want max -.5 camber when im done.
5th Gen Christmas Dollar Days!! Info@PeddersUSA.com Suspension / Chassis / Brakes 36 12-20-2009 01:01 PM
Pedders Alignment kit Cruz-lo Suspension / Brakes / Chassis 0 12-13-2009 12:08 PM
SEMA, Pedders Conference, GS Camaro, New Products JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 25 12-01-2008 02:25 PM
