Jason 98 TA
Old 12-13-2009, 08:44 PM   #1
riverbadboy
riverbadboy
riverbadboy's Avatar
Drives: 1SS Silver with Black rally Stripes
Send a message via AIM to riverbadboy
Can a Corsa cat back and k+n air filter cause a slow down??
After the dealer installed the corsa cat back exhaust P/N 14951 the 1SS M6 seemed slower. It did sound bitchin though. I guess what i'm getting at is the dealer did some recall stuff and i don't really know if they did a reprogram or what but it might just be my immagination? any ideas? should i get some kind of reprogrammer to make up for exhaust upgrade?
riverbadboy is offline   Reply With Quote
Old 12-13-2009, 09:16 PM   #2
Badassbird
LSX Tuner at Cincy Speed
Drives: 1988 GTA Trans Am
This is almost certainly in the tune. If this install were to throw your trims off and cause some knock retard, then yes you may be seeing that situation. This is not all that common though. I highly recommend a custom tune, you will see a much better result in HP,MPG and driveability. I have seen a loss with some of these hand held tuners BTW.
Tracey Scott
Lead GM Tech and Tuner -Cincy Speed
513-821-2221
Badassbird is offline   Reply With Quote
Old 12-13-2009, 09:34 PM   #3
MoranoRacing
Drives: 2005 GTO, 1973 Camaro
When I install parts I like to reset the computer by disconecting the battery for around 10 minutes. That way the computer is reset and it can learn the new mods. Perhaps try that if you'd like.
I predator tuner also works great when you add an exhaust or cold air intake.
Good Luck!
MoranoRacing is offline   Reply With Quote
Old 12-13-2009, 09:42 PM   #4
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
You should see basiclly no change... This car learns these type mods very quickly.
Tune will kill your warranty, but possibly the battery cable or 5/20 fuse pull may insure you are on the correct octane table.
Old 12-13-2009, 11:53 PM   #5
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Hi as we see on TAGs car after you take the back pressure out the car run fat so you will lose some power, By the way i am up in fort Mohave all the time hope to see you soon.
Old 12-14-2009, 08:24 AM   #6
Badassbird
Wow you guys are having issues with warranties and tuning? That sucks. We dont have that issue around here. The dealers nearest to us are very forgiving and have great relationships with our customers. We had a GTO with open headers and giant cam go in for a broken rear end and they didnt even ask any questions. Also with a good tuner, you can save your factory tune. Then IF something were to ever happen you could flash back to stock and go.
Tracey Scott
513-821-2221
Old 12-14-2009, 09:20 AM   #7
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
More than likely they reprogrammed the computer with the newest tune that addresses wheel hop, that means there is even more torque management than you went in with.
I can send you a predator or Trinity and solve that problem Easy.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 12-14-2009, 09:35 AM   #8
mlee
www.CamaroFans.com
mlee's Avatar
He has a catback... still has stock manifolds / cats and a Corsa resonator. TAGS is a different animal...
If he got that update then he's probably got the new OS not yet supported by Diablo, but coming soon I'm sure...
Old 12-14-2009, 10:21 AM   #9
Diablo time
Old 12-14-2009, 04:59 PM   #10
riverbadboy
riverbadboy
yes i do appriciate the help guys as i'm new to ls motor tuning. Funny, but running it more, the better it seems to run?? Could it be learning as it runs ? and yes we will prob see each other 2SSRS
Old 12-14-2009, 05:13 PM   #11
JANNETTYRACING
It will not learn out torque management, and torque management make it feel soft.
Tuning is your only solution at this point.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
magnaflow 3" comp series cat back GQ4Life Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 32 01-20-2010 02:57 PM
L/T with off road pipes or a good cat back ?? LSU/LS3 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 10-19-2009 10:12 PM
? about Cat back vs Ax back vs Muffler SS-screamer Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 10-01-2009 09:42 PM
question on install: GMPP cat back exhaust detroitboy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 04-04-2009 01:52 PM
Is aftermarket exhaust really cat back? CDBiker220 5th Gen Camaro SS LS LT General Discussions 8 02-20-2009 03:08 PM
