ModBargains
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 12-14-2009, 11:56 AM   #1
robertway
robertway's Avatar
Drives: 2012 Challenger SRT8 Auto
One more Roto-Fab CAI Install
This is a bit of a re-post from a prior CAI thread but I finally installed my Roto-Fab on my LS3 2SS over the weekend, after breaking the car in pretty hard for the first 1000 miles I did a quick oil/filter change, changed the fluid in the rear end and then popped the hood for the CAI. The install was SUPER easy, if you can change a light bulb you can install this CAI, the packaging was very good, the instructions were very clear and simple to follow. Even putzing around and taking my time itr was less than an hour from opening the hood to closing it. I did pull the 5/20 fuses overnight just to give the car a fresh start to learn with the Roto-Fab on there. The one additional thing I may do is pick up another small piece of rubber stripping to totally close off the back right corner of the heat shield from the engine compartment, while I am not sure just how much heat can get in through there and if I am being too paranoid it gives me something to do.
I went with the Roto-Fab for the following reasons;
1. I like the looks (personal preference)
2. I like the ease of installation as posted by many on this forum. (others are easy as well)
3. Based on the testing by Ted Jannety, which I have full faith in as it is related to an apples to apples, controlled environment test, I most liked the very consistent IAT's (air temp readings) as well as the fuel trims being reasonable (as others were as well).
http://www.camaro5.com/forums/showthread.php?t=48202
4. I like that the unit has a few "relief" points to allow the engine to move around and the unit to "give a little".
5. I really like the investment Roto-Fab has in getting the unit right and their investment in this community, evident by some of the praise they have gotten here in the forums as well as their immediate reaction to Ted's testing and their immediate effort to see if they still had room for improvement once they got feedback from Ted, evident in this thread;
http://www.camaro5.com/forums/showthread.php?t=48992
6. The price point, there are good deals to be had, you just have to pick up a phone and reach out to shops to find them, but my guess is this holds true for most of the units. Got mine from Brandon at IPS Motorsports
I was not concerned with 2-3hp difference between units, I was most concerned with a solid all around package IN MY EYES that served as a good starting point in allowing the engine to breath better on the intake side and not be a bottleneck when I upgrade the exhaust side of things with long tubes, hi-flow cats, and less restrictive exhaust later on.
For me, there were quite a few I would have gone with based on performance alone but taking all the other things into consideration I went with Roto-Fab.
Hope this helps anyone contemplating a CAI, just make sure you choose the one YOU want.
"When the people find they can vote themselves money, that will herald the end of the republic." - Benjamin Franklin
LS3 Camshaft Swap Do-It-Yourself Instructions - 2010 LS3 gone but not forgotten!!!
robertway is offline   Reply With Quote
Old 12-14-2009, 12:45 PM   #2
Looks awesome
Old 12-14-2009, 01:07 PM   #3
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
Nice and clean!!!
HeavyD is offline   Reply With Quote
Old 12-14-2009, 01:14 PM   #4
Inferno2SSRS
Jim
Inferno2SSRS's Avatar
Drives: 2010 Camaro 2SS/RS Orange
Send a message via AIM to Inferno2SSRS
I just installed mine on Saturday and the sound difference from the engine is worth every penny. Also the look the under the hood is so much cleaner looking. I'll post some pics up later.
ARH 1 7/8 with Cats, Corsa Cat-back, Roto Fab CAI, and Jannetty Tune, L99
Inferno2SSRS is offline   Reply With Quote
Old 12-14-2009, 04:22 PM   #5
MrGazinya
MrGazinya's Avatar
Drives: Aggressive
Just installed mine as well, Got tired of waiting for Vararam... I love this intake, butt dyno can feel a difference and it sounds like a monster at WOT.. Great intake Roto-Fab, could not be happier
Black 2SS RS LS3 Inferno Int. Plastidipped 20's {MODS} KOOKS LT: Borla S-Type: Roto-Fab CAI: Hurst ST.: Diabloed by Jannetty Racing: PFADT Stage 2, Trailing arms, Tie Rods:
MrGazinya is offline   Reply With Quote
Old 12-14-2009, 06:15 PM   #6
BLKnCHRME09Deluxe
Banned
Drives: 2010 Camaro 2SSRS and a 09' Deluxe
I just put mine in not too long ago....
Cons...
I have noticed that my average mpg. has dropped...it was 16.9 city now its 15.4 city....No biggy...i could just have a heavier foot now.
Also maybe Roto Fab should have included some kind of cover or something for the back stock box mount. Because Roto Fabs box only uses one box mount.
And finally with the dry filter it sits almsot too close to my fluid resivoir...Another No biggy...as long as when the motor is moven it don't knock into it.
It looks like they covered everything else though....
PROS...
I have to agree with the OP about everything he posted. Well made unit, not to mention IMO it's the best looking in appearence. I went with the dry filter also....
As the OP has stated there are great deals to be found out there. It only took me a month to find such a deal. I purchased mine NEW for super cheap.... $265.00 shipped for unit and dry filter.
Great job Roto Fab...
here's another pic....
BLKnCHRME09Deluxe is offline   Reply With Quote
Old 12-14-2009, 06:36 PM   #7
navyblueSS
Drives: 2002 Camaro SS
Very clean, looks good!
2010 M6 SS/RS SW w/IOM Stripes - Futral Motorsports Custom Cam & Tune 483rwhp - 449rwtq
navyblueSS is offline   Reply With Quote
Old 12-14-2009, 07:03 PM   #8
g-townmach
I FARTED
g-townmach's Avatar
Drives: 2010 2SS/RS
Why'd you pull the fuses? I thought on the LS3's the fix was just the battery disconnect. Thats what the sticky says doesn't it?
g-townmach is offline   Reply With Quote
Old 12-14-2009, 07:09 PM   #9
Garrett
G-Man
Garrett's Avatar
Drives: 2ss Aqua Blue Mettalic
Here is mine. I have had it a couple of months and I love it.
G-Man
Garrett is offline   Reply With Quote
Old 12-14-2009, 07:17 PM   #10
lee
lee's Avatar
Drives: 2010 2ss/rs
when i get one it will be a rotofab
lee is offline   Reply With Quote
Old 12-14-2009, 07:31 PM   #11
Slim2SS
Black Thunder
I also installed mine on Saturday and I am well pleased with it. Bought mine from Brandon @ IPS also during his black friday sale.
Slim2SS is offline   Reply With Quote
Old 12-14-2009, 08:52 PM   #12
RJ's SS
RJ's SS's Avatar
Drives: 2010 Bumble Bee SS/RS L99/A6
Install mine a week ago and have to say I love the looks and how much it cleans up the engine room(sic).
Great product and the sound is awesome. It is not load until you get on it and then it sounds like something is fixin to get stomped!
My IAT averages went from 11 - 15 deg F above ambiant to between 2 - 3 above.
RJ
RJ's SS is offline   Reply With Quote
Old 12-15-2009, 04:49 AM   #13
robertway
robertway's Avatar
Ya know G, I don't know, I thought the same thing, I had been playing with the fuse pull/battery disconnect last week once I ran through my dealer pumped tank of 87, ran through a few tanks of 91 then put a tank of 93, pulled the fuses, saw no change in punch or mpg, tried the battery disconnect and fuse pull overnight and things seemed tpo get better, more punch at partial throttle and a few mpg better. After I put the CAI in I was too lazy to pull the subwoofer enclosure out of the trunk to get to the battery so I may do it today at work. I don't mind re-indexing the windows and I only have one bluetooth device I need to pair after the battery get reconnected.
I really just want to tune the dam thing but the warranty is too valuable to me at this time
Old 12-15-2009, 04:54 AM   #14
robertway
robertway's Avatar
RJ
Did you guys notice any change in mpg? I do a TON of miles on the Interstates and even though I know mpg is not the reason we drive these cars it is nice to be getting 23-24mpg on the highway and don't want to be loosing any of that.
Old 12-15-2009, 11:48 AM   #15
SSchase
SSchase's Avatar
Drives: 2010 camaro SS/RS LS3
i didnt lose any mpg on the highway. if your easy on the gas even with the intake your not gonna lose much from what ive noticed on mine. i got 22mpg on highway before the intake and i still get 22mpg with the intake.
SSchase is offline   Reply With Quote
Old 12-16-2009, 10:02 PM   #16
BLKnCHRME09Deluxe
Banned
Update... Well i just noticed that my gas milage has dropped even more...stock intake i got 16.9 mpg...now with the Roto Fab im getting 14.6. With the same driving habits/conditions/foot...I guess more air equals more gas.
How about you guys runnen these "Roto Fab"???
Old 12-17-2009, 07:05 AM   #17
Roto-fab 1
Drives: 2012 zl1
With all other things being equal, we typically see an increase in fuel mileage with our systems. Although the Camaro hasn't been on the road long, we have an enormous amount of feedback from the G8 crowd. Roto-fab users generallly report + 2 to3 MPG with automatics (the intake works well with DOD) and appr. a 1 1/2 MPG increase with the stick cars.
The most common thing we do hear from customers concerning reduction in MPG is they tend to put their foot in it more because they like the sound!
Roto-fab 1 is offline   Reply With Quote
Old 12-27-2009, 10:54 AM   #18
Roto-fab 1
Drives: 2012 zl1
Glad to hear it! In addition to great performance and sound, you can choose from a variety of appearance options. I see there are several very nice pics on this thread. Here are a few more.
Old 12-27-2009, 02:05 PM   #19
towmoe
towmoe's Avatar
Drives: IBM 2010 Camaro
Originally Posted by Roto-fab 1 View Post
Where can I order one of these engine covers?
2SS/M6 | Imperial Blue Metallic | White Stripes | Black Int
towmoe is offline   Reply With Quote
Old 12-27-2009, 07:03 PM   #20
oachalon
Drives: 2010 Camaro 1SS
roto-fab, i currently own your cai intake and love it. In the future i plan on purchasing the edelbrock e-force supercharger kit and was wondering if you will be making a new intake tube that will bolt up to this system so i can continue to use your cai.
oachalon is offline   Reply With Quote
Old 12-27-2009, 07:12 PM   #21
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
A lot of vendors have them, I carry them. If you are interested you can send me a PM and I will see what we can work out for you.
ZZcamaro is offline   Reply With Quote
Old 12-27-2009, 10:46 PM   #22
BLKnCHRME09Deluxe
Banned
I drive the same streets daily..
Before install my Average MPG guage was reset on a full tank. Well with my stock intake i got 16.9 Average MPG and i drove it hard sometimes and normall other times.
Then after installing the Roto-Fab i drove it the same as stated above and my Average MPG was at 14.6..... Average MPG guage was reset at this point also. I thought maybe my foot just got heavier thats all.
So on my last fill-up i reset guage once again and DROVE THE CAR LIKE A SNAIL..Maybe only got on it a couple of times for a couple of seconds while entering freeways and my Average MPG went up to 15.3.
So when i hear now these intakes give you better MPG..NO i just dont believe it.
Sorry guys.. These are not G8 they are Camaros....Still am satisfied with your product...Just keepen it real.
Unofficial 1/4 Mile 2010+ Camaro Fast List Merc Dragstrip, Tracking, Autocrossing, Driving Techniques Discussions 210 06-13-2013 08:42 PM
Roto Fab CAI with IOM PAint Coop Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 09-29-2009 04:25 PM
Vector Motorsports ECM/TCM Tune & Roto Fab CAI Package ralyrat Vendor and Seller review / feedback / experiences 1 09-15-2009 11:39 AM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 09:10 PM
