Old 12-22-2009, 03:55 PM   #43
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Not bad but then you will have to cut the wires coming in to the plug in the back and wire in some connectors and where do you put the parts to run the EL wire?
One more thing is the flasher on this car?
Old 12-22-2009, 04:06 PM   #44
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
I edited it a bit with the thought on the 194 bulb.
Connect up a 194 bulb socket Via a Scotchlock connector, put both the 194 and the 3156 bulb into the housing, seperate them by a piece of metal bent into the u shape following the afterburner shape.
Either way whatever light is used for the turn signal, it would still flash.
skuttduck is offline   Reply With Quote
Old 12-22-2009, 04:18 PM   #45
2SSRS@Gen5diy
Don't forget if you go with a LED or EL wire that the load changes and the DIC will have a problem with it.
Old 12-22-2009, 04:31 PM   #46
skuttduck
skuttduck's Avatar
This should help with that, if you go that route.
http://www.eautoworks.com/product-Led-33226.htm
Old 12-22-2009, 04:34 PM   #47
bolteon593
Drives: 2011 GT500
excellent... this will help...
bolteon593 is offline   Reply With Quote
Old 12-22-2009, 04:41 PM   #48
2SSRS@Gen5diy
I know that but it dos not work, I was tolled that it did not work by AAC , I will try it sone to.
Old 12-22-2009, 05:03 PM   #49
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
heres a pic from the film clip of the concept for whoever maybe able to photoshop or just for referance . who made the concept lights or does one exist ? i have only seen retouched pics of them and this pic of a real concept does not look so hot ,maybe if it was lit we could see whats going on in there. i have a new rs taillight in hand now if i can get the lens off without scratching it i will post pics of inside.
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++
klatterblast is offline   Reply With Quote
Old 12-22-2009, 05:32 PM   #50
klatterblast
heres a couple pics of mine from an angle , AACstyle afterburner led halos.
Old 12-22-2009, 06:25 PM   #51
Mr Twisty
Mr Twisty's Avatar
Instead of thinking 'Afterburner', think 'Eclipse'.
-- Benjamin Franklin
Old 12-22-2009, 06:39 PM   #52
CrimsonHowitzer
Drives: 2-70 Camaros,40 chev 2dr sedan
I don't have one to play with but it looks like there are three parts to the housing. The reflective can, the clear diffuser, and the red lense. Has anyone tried taking the light apart and spraying a tailight tinting paint over the clear diffuser, masking off a quarter inch around the bottom half circle. This would slow the light through the center but allow it to shine though around the edges. Might not be as dramatic as LEDs or completely blacking out the center. Sorry I don't have any cool photoshop programs to show what I am talking about.
CrimsonHowitzer is offline   Reply With Quote
Old 12-22-2009, 07:07 PM   #53
Mr Twisty
Mr Twisty's Avatar
The diffuser is normally part of the lens, molded on the inside.
Old 12-22-2009, 07:15 PM   #54
2SSRS@Gen5diy
There is three parts.
Old 12-22-2009, 07:16 PM   #55
CrimsonHowitzer
I was using this picture for reference from an older post. It appears that the clear diffuser sits in about .5 to 1 inch seperate from the red lense.
Old 12-22-2009, 07:17 PM   #56
CrimsonHowitzer
I was too slow posting that one. Thanks 2SSRS.
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Cosmetics and Lighting Modification Discussions 36 06-25-2017 10:57 AM
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Exterior Parts & Accessories 30 02-20-2013 04:23 PM
