ADM PERFORMANCE
Old 12-14-2009, 02:24 PM   #1
SilverIce1
Silver Ice
Drives: 2010 SIM 2LT Automatic
Trailing Arms - Downsides?
So, I intend to replace the factory trailing arms because I hate the wheel hop. But, I need to know if there are any downside side effects of this modification. Please advise. Thanks!
SilverIce1 is offline   Reply With Quote
Old 12-14-2009, 02:31 PM   #2
2010 2-Tone
2010 2-Tone's Avatar
Drives: 2010 RY 2SS with Custom Stripes
None that I know about, but hell, what do I know????
2010 2-Tone is offline   Reply With Quote
Old 12-14-2009, 03:27 PM   #3
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
Nope!!!
If you do get into arms that are solid rod ends then you can lose some ride quality....but i only saw one set of BMR toe rods that are like that.
You will be happy with the upgrades.
ZZcamaro is offline   Reply With Quote
Old 12-14-2009, 03:51 PM   #4
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
Only down fall at all is about 4 lbs of weight. Well worth it if you want to help stop wheel hop. Great deal on the BMR's best I have seen and used out in the market to date. The upper toe rods work well too. Car will stay more planted in accel.
Nationwide Turf
"artificial turf factory"
lawdogg149 is offline   Reply With Quote
Old 12-14-2009, 04:52 PM   #5
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
The 2 primary bushing upgrades to reduce wheel hop are the subframe or cradle bushing movement and the rear diff bushings. Adding just trailing arms or the inner bushing is only a partial fix. There are 2 bushings per trailing arm. But bushings should be replaced if you want to upgrade trailing arm bushings for additional rear support.
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
BMR Fabrication Launches New Product - 2010 Camaro Trailing Arms (TCA026) BMR Suspension Suspension / Chassis / Brakes 89 03-05-2010 08:02 AM
LMPerformance, Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Polyurethane Bushing LMPerformance V8 Bolt-Ons & Tunes 3 10-19-2009 03:33 PM
LMPerformance, Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Delrin Bushings LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 02:05 PM
LM Performance, Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Spherical Rod Ends LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 01:59 PM
LM Performance, Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Del-Sphere Pivot Join LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 01:34 PM
