Old 12-15-2009, 04:18 AM   #1
salohi
salohi's Avatar
Drives: 90 Black Camaro, 02 Sable
160 thermostat for LS3/L99 help ???
hey guy's
can any one help me with how to change the 160 degree thermostat
with pic or vid please
thanks
2SS/RS
Black/Black
6Spd. Aut.
salohi is offline   Reply With Quote
Old 12-18-2009, 11:58 PM   #2
salohi
salohi's Avatar
NO answer ,
come on guy's
2SS/RS
Black/Black
6Spd. Aut.
Old 12-19-2009, 12:08 AM   #3
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
take out old one install new one
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 12-19-2009, 12:44 AM   #4
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
Why do you want to change the thermostat to 160? The engine is designed to run at 190 to get the best combustion, leave it alone, it won't improve your performance. Haven't you noticed how rough your car runs until it warms up properly? If you want to do something with cooling, have the fan turn on temp dropped by 20 degrees.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 12-27-2009, 09:33 PM   #5
wysokowski1963
Drives: Acura NSX
Changed out mine to a 160. Now runs at 10 0r 11 degrees cooler than the 192 it ran before.
wysokowski1963 is offline   Reply With Quote
Old 12-27-2009, 09:37 PM   #6
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2017 A10 ZL1
Yep... that's what a 160 deg Tstat will do... question is, why did you do it...
Old 12-27-2009, 10:03 PM   #7
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
yeah, on a stock motor and stock tune, unless you live in a really HOT climate, no reason to do it. If you do live in a HOT climate, you should also get a tune to turn your fans on at a lower temp.
To answer the question...unbolt the thermostat housing...(located at the end of the upper radiator hose...get ready for a lot of coolant to drain out)...remove and replace. Refill radiator, purge the system, done.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 12-28-2009, 10:53 AM   #8
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
Correct return the 160 and get your money back. These engines need to be at the 190 to perform there best.
Nationwide Turf
"artificial turf factory"
lawdogg149 is offline   Reply With Quote
Old 12-28-2009, 11:27 AM   #9
rodimus prime
Drives: Cargo van.
Not really. Running a bit cooler will let you pull a bit
more timing without knock. It won't hurt to run a cooler thermostat, but it's just going to be open constantly without having the fans set.
rodimus prime is offline   Reply With Quote
Old 01-19-2012, 04:52 PM   #10
jwithers2005
Drives: 2010 2SS L99/A6
I have to disagree. heres why...
I just installed TSP full exhaust and CAI on my L99 Camaro..i literally just got home from the dyno from having it retuned for the new parts. the first pull after the initial tuning yielded 362.2 hp with the car at normal temp operating range. the dyno session sheet says temp was 191 @ the beginning of the pull, and 194 at the end...with the fans blowing on it for a few minutes, it cooled to 178 at the start of the pull and was up to 180 by the end ..the tune was not modified at all and the car made 368.8hp on the cooler run...the 3rd pull back around the 190 mark was again down in the lower 360 range...
it is my belief that it will help to run a cooler thermostat BUT, I think a 170 or 180 would be a better choice if it is available...a 160 will stay open constantly and struggle to keep the engine that cool in very hot weather..you could be looking at overheating problems if the water continuously cycles through the system because the thermostat never closes any..the coolant wont run slow enough through the radiator to cool down, especially at slower speeds with minimal amounts of airflow through the radiator. ive had it happen...less chances of this being a problem with a 170 or 180..I don't think it is a lost cause trying to cool it down a little, but my results may not be typical..
jwithers2005 is offline   Reply With Quote
Old 01-19-2012, 09:05 PM   #11
alcal1084
Drives: 2012 45TH AE SS
i had similar results on my last dyno run's... as far as a cooler thermostat the car has a 186 in it stock so a 180 or 170 wont do anything, but like the guy said earlier a 160 will have you run about ten degrees cooler. if the car is your DD then im not sure if you should run a 160 but if its a track car or weekend car the a 160 would be good.
alcal1084 is offline   Reply With Quote
160 Degree Thermostat and Car Issues.... EAkrish Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 203 05-17-2012 02:34 PM
160' t-stat??? JHart Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 11-24-2009 01:28 AM
Help - cooling (thermostat) RickyTheStorm Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 09-08-2009 04:47 PM
160 Thermostat My First Camaro! Tuning / Diagnostics -- engine and transmission 18 08-07-2009 11:52 AM
160 degree thermostat rforbes Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 07-07-2009 03:34 AM
