HeadlightArmor
Old 12-16-2009, 08:24 PM   #1
seddon
seddon's Avatar
Drives: 2017 ZL1
Help With Drop spring
Ok fellas been doing some research on drop springs. The Pfadts springs drop 1" and the H&R's drop 1.5". I need to drop about 2" for now until I get my coilover. I read that the Pfadts springs require you to cut 1" off of the bump stop but the H&R's don't require that. So can I cut the bump stop with the H&R's which should give me a lower stance.
seddon is offline   Reply With Quote
Old 12-16-2009, 09:07 PM   #2
FEN
FEN's Avatar
Drives: BLACK 2SS/RS
Cutting the bumpstops will not lower the stance.....it just helps to prevent bottoming out when you run out of travel.You need a coilover setup.
FEN is offline   Reply With Quote
Old 12-17-2009, 03:54 PM   #3
seddon
seddon's Avatar
Drives: 2017 ZL1
I am waiting for the pfadt coilovers.
Old 12-17-2009, 04:40 PM   #4
lsejlowe
lsejlowe's Avatar
Drives: 1969 Corvette
is getting it lowered so urgent that you'll buy the extra springs just for a month or two?
lsejlowe is offline   Reply With Quote
Old 12-17-2009, 05:44 PM   #5
FEN
FEN's Avatar
I would just wait and do it one time. Why spend the money or take the time to do it twice....and multiple alignments too. Mine is lowered 1" and its quite noticeable.A 2" drop is pretty low IMO.
Old 12-17-2009, 06:03 PM   #6
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
With almost all lowering springs you will want to trim the bump stops to not have the car ride on them after lowering the car.
Regards
IPS Brandon is offline   Reply With Quote
Old 12-17-2009, 07:25 PM   #7
FEN
FEN's Avatar
Regards
This was mentioned by another vendor here who was posting under an Eibach 1" spring thread. I have the Eibach 1" drop springs installed and have never had any issues w/bottoming out......large dips in roads,wash board dirt roads,you name it. I have never heard any other members who used 1" springs complaining of problems either?? Can you give any first hand experience with any problems w/Eibach 1" drop springs or any other 1" drop spring for that matter?
Old 12-18-2009, 10:30 AM   #8
IPS Brandon
I assume your using the Eibach pro kit, and if so I have them on my Audi A4 same spring, different car. I do not have any issues either with riding on the bump stops, but I trimmed them, as its common practice for installing lowering springs.
The issue is most lowering springs will cause a factory strut to travel further then before and with out trimming some manufacturers bump stops you will have a tendency to hit them to often, not in every case, as you exemplified. So in order to help eleviate this issue you trim the stop an 1" or so and add a little more travel to the shock for a less *bumpy ride, pun intended !
Regards
Old 12-20-2009, 10:26 PM   #9
racer50200
racer50200's Avatar
Drives: 2010 White 2SS/RS Camaro 6M
So should the bump stops be trimmed if using Eibach 1" drop springs??
Camaro Specs: 2010 2SS/RS SW,
6M, Eibach Spings / bars, 275's X 4,
Heritage Grill, NLP spoiler, Becky's SW
shark fin, AAC LED DRL's, Stainless Works
Headers and exhaust, Barton Flat Stick
Shifter, '69 SS emblems, ready for hp boost.....
Help your country.... Buy American Products!!
racer50200 is offline   Reply With Quote
Old 12-20-2009, 10:46 PM   #10
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Seddon, Dropping the car too far (about 1.5" +) you'll notice your Camaro's factory dampers no longer work properly, resulting in a bouncy ride. If you want to go 2" i'd suggest upgrading some more stuff. Shoot between 1" - 1.5" drop with the rest of your suspension being stock.
Best bet is just to wait until your coilovers arrive.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 12-21-2009, 06:39 PM   #11
FEN
FEN's Avatar
I have the Eibach 1" springs and did NOT have the bumpstops trimmed. I talked several times w/the tech guys at Eibach and they said that the bumpstops do NOT need trimmed w/their 1" springs.So far, i have had no problems w/bottoming out or bouncing. A couple of vendors on this site claim that they should be trimmed and maybe thev are correct if you plan on goin airborn and jumping canals Dukes of Hazzard style
Call Eibach(as i did) and ask them as they designed and tested the springs!
Old 12-21-2009, 07:24 PM   #12
seddon
seddon's Avatar
Drives: 2017 ZL1
Thanks for all the advice/insight fellas. I need to lower the my car for my new wheels so I am just gonna stick with the H&R's for now.
Coilovers will be ordered late summer so that's why I will do it twice plus the springs were an early christmas present.
Old 12-21-2009, 08:06 PM   #13
55Designs
Drives: 2010
seddon PM me if you want to check my car out. I didnt cut bumpstops and it drives great. I have H/r springs from Germany and a slight revalve of the OEM shocks. Car has no fender gaps it sits perfect. I have KW coilovers sitting in the garage and still deliberate if I will install them now.
55Designs is offline   Reply With Quote
Old 12-22-2009, 11:27 AM   #14
toehead93
Drives: 2014 2SS/1LE
How much drop are you at, 1.5"? I'm waiting to install my Pedders XA's, they been sitting in my garage for months now. I'm waiting to get new wheels in Jan.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Pedders / Eibach / H&R ????? DocHolliday Suspension / Brakes / Chassis 52 12-21-2009 07:07 AM
Who Has Drop Springs in stock 1.5" Min drop Atomic Autosports Suspension / Chassis / Brakes 12 10-30-2009 06:24 AM
Discussion of suspension tuning methodologies Tankrust Wheels and Tires Talk Sponsored by The Tire Rack 10 08-04-2009 07:39 PM
PEDDERS TAKING ORDERS FOR DROP COILS WITH OPTIONS! Info@PeddersUSA.com Suspension / Chassis / Brakes 25 08-03-2009 11:45 PM
Detroit Speed vs. Pedders usmcjlp Wheels and Tires Talk Sponsored by The Tire Rack 35 07-22-2009 01:14 AM
