Old 12-16-2009, 08:51 PM   #1
My First Camaro!
My First Camaro!'s Avatar
Drives: 03Dakota4.7 1SSLS3RS
TR6060
Is their anything special you need to do when draining and filling? Thanks.
My First Camaro! is offline   Reply With Quote
Old 12-16-2009, 08:55 PM   #2
1CAMSS
1CAMSS's Avatar
Drives: 2010 1SS CAMARO/GBA/M6- sold.
make sure you fill with correct fluid?
1SS @ home. 12/14/2009
1CAMSS is offline   Reply With Quote
Old 12-16-2009, 08:58 PM   #3
My First Camaro!
Old 12-16-2009, 09:00 PM   #4
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:155 ban
Old 12-16-2009, 09:08 PM   #5
1CAMSS
1CAMSS's Avatar
lol! yeah but still - what is the correct fluid? and how much? till it starts seeping out the fill hole?
Old 12-16-2009, 09:25 PM   #6
My First Camaro!
Fluid should be in the owners manual. If it like any other transmission then yes, fill until you get a little over spill. I just want to making sure their isn't a kanuter valve to purge or a flux capacitor to reset.
Old 12-16-2009, 09:27 PM   #7
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
DO NOT forget to replace the drain plug.
Hey, it's been done.
Old 12-19-2009, 10:32 AM   #8
2SSjack
2SSjack's Avatar
Drives: 2010 2SS Camaro;
Assuming you have the MANUAL transmission, Dexron III is the correct fluid, not Dexron VI. It will take about 3.6 quarts to re-fill and when I did mine I took a plastic funnel with a flex spout, added a 3 foot piece of clean fuel hose and snaked it down on the driver's side of the engine to the fill hole. It worked fine!
2SSjack is offline   Reply With Quote
Camaro team's response to concern about Transmission Output Shaft Failure Mr. Wyndham Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 389 07-09-2011 12:09 PM
aftermarket parts for the TR6060 boostedyards86 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 11-09-2009 04:46 PM
TR6060 thrashy sounding? Ringo V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 09-25-2009 05:43 PM
Tremec TR6060 6-speed Manual Transmission Splitter V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 7 03-22-2009 01:17 PM
4th gen with a tr6060? boxmonkeyracing 4th Generation Camaros 3 12-19-2008 05:19 PM
