HURST
Old 12-17-2009, 01:37 PM   #1
SSchase
SSchase's Avatar
Drives: 2010 camaro SS/RS LS3
anyone have pfadt coilovers?
hey guys im looking at getting a set of pfadt coilovers and swaybars after christmas. anyone have them on there camaros? if so if you have any pics and how they ride. ive talked to alot of vette guys that love them and swear by them.
SSchase is offline   Reply With Quote
Old 12-17-2009, 02:07 PM   #2
Stewcam
Stewcam's Avatar
Drives: 2010 Camaro SS/RS
On order. I don't think the first batch is shipping until January.
Yellow SS/RS
LMR Twisted Slayer 650 RWHP, ARH Headers, Hi-flow cats, Carbon/Organic Twin Disc/Pfadt/BMR/Hurst Shifter/D2forged VS1's
Stewcam is offline   Reply With Quote
Old 12-17-2009, 04:36 PM   #3
carriagehousecustoms
Drives: 1ss american iron
We have a set on our NASA camaro racecar. Worth the wait.
carriagehousecustoms is offline   Reply With Quote
Old 12-17-2009, 11:49 PM   #4
modern-muscle
modern-muscle's Avatar
Drives: 1964 Chevelle
You should take a look at the pedders coilover, its a solid setup. We have used them in Rick Bottoms Camaro and it is easy to say that it is a real solid piece!
modern-muscle is offline   Reply With Quote
Old 12-18-2009, 09:46 AM   #5
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
Here is a breif tid bit on the pros of the pfadt coilovers!
The main features of Pfadt's Coilovers:
-Inverted monotube design in on the front strut. This provides that really large shaft section that you see with our front coilover. That is important because the front strut takes cornering loads in these cars and the stiffer the tube, the better. This has the effect of placing the adjuster knob on the bottom of the strut for easy access. It is a click style adjuster with 20 clicks that are very positive and easy to feel. It is a simple matter of reaching around the front tire and making a couple of twists to change your damping.
-Inverted body design on the rear damper. This reduces unsprung mass (a good thing) and also places the adjuster at the bottom of the damper where you can reach it. It is also a click style adjuster wrapped around the shaft section just below the spring perch.
Our dampers in both the front and rear feature single point adjust-ability which controls both compression and rebound damping together. This is a design that we have found to be very flexible and user friendly in our Corvette offerings. Basically, you do not need to be a damper engineer to be comfortable making adjustments and it is easy to switch from a 'street' setup to a 'track' setup with just a few clicks.
-Our damper are mono-tube design and feature a separate internal gas chamber, which in the industry is referred to as 'non-emulsion' design. Mono-tube non-emulsion shocks are what you find on most every production based race car everywhere. It is the best design and provides the most consistent and reliable operation. Many of the other offerings for the Camaro are not, ask the manufacturer if you are curious.
-The final feature about our coilovers that I will share today is that our coilovers take a 'standard' flat ground race spring. Many other use a custom spring to fit the Camaro specifically. Using a standard spring size allows extreme flexibility in spring rate choice. You can call up any race supplier and order springs in 25 lb/in increments that will work on our coilovers. We provide a set with our coilovers that will work well for most people, but the flexibility is there for those who want it
Our shop is also very well known in the Vette market so your correct, pfadt puts you in the winners circle!
Finally as for ride quality, if it is like the vette coilovers, which we have installed on more cars then I can count, then this product will ride like a dream, and perform properly!
Regards
IPS Brandon is offline   Reply With Quote
Old 12-18-2009, 09:47 AM   #6
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
hey brandon how much do the struts go for? and they take the springs i bought form u guys?
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 12-18-2009, 10:42 AM   #7
IPS Brandon
They certainly do, what type of strut are you looking for? There aren't many options just yet, but by spring there should be.
Old 12-20-2009, 05:38 PM   #8
d69chris
Florida C5
d69chris's Avatar
Drives: 2010 Camaro 2SS Vortech L99 IOM
Send a message via Yahoo to d69chris
Any Xmas specials on the coils???
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
d69chris is offline   Reply With Quote
Old 12-20-2009, 05:41 PM   #9
Windy City
Windy City's Avatar
Drives: Not enough room here!
Entire Pfadt suspension upgrade on order here! Well worth any wait as winter is here and the Camaro is snug as a bug in a rug in it's heated garage!
I would suggest all there products!
BEWARE OF THE LPE BROTHERHOOD!
Remember: You can sleep in your car, but you can't drive your house!
Windy City is offline   Reply With Quote
Old 12-20-2009, 05:41 PM   #10
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
well you tell me the optionsss!!! l;et me know whats u have and prices please!
word and specials?
Old 12-21-2009, 11:14 AM   #11
IPS Brandon
word and specials?
PM me for Xmas Specials
As for options, It sounds like Koni is releasing some soon, Pfadt will have some in 3-4 months as well. Really currently strut options are about nill, for anything I would consider a quality upgrade.
Old 12-21-2009, 11:18 AM   #12
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Brandon -
You may also want to add this to your why Pfadt list:
3" O.D. Everyone else is 5" like the factory.
This comes in to play when looking to run very wide rubber.
PFADT - Drop springs & Balance bars (Pics inside) CRUSHER2SS Suspension / Brakes / Chassis 12 01-05-2010 10:12 AM
Pfadt GROUP BUY! Springs / Sways / Mounts IPS Brandon Suspension / Chassis / Brakes 18 11-23-2009 03:46 PM
Pfadt Springs and Sway Bars In Stock! *Package Deal*! PfadtRacing Suspension / Chassis / Brakes 0 10-14-2009 06:41 PM
Pedderizing the Nickey Camaro! Pedders coilovers / suspension fitted & tested. DallasMike Wheels and Tires Talk Sponsored by The Tire Rack 57 06-15-2009 05:36 PM
