01-10-2010, 02:35 AM | #15 | |
High on "The Camaro Life"
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam Join Date: May 2009
The pads are very easy to pull off, you don't have to remove the callipers. Just use a 1/8 inch pin punch and push out the 2 pins from the outside of the calipers and then the pads slip out from the outer edge of the caliper. Then just tap the pins back in from the back side of the calipers. Refer to pic below for pin locations.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
01-10-2010, 02:25 PM | #16 |
Drives: 2010 camaro rs/ss 67 camaro Join Date: Aug 2009
The brakes come with a chamfer already.But you can put disc brake quiet on the metal side of pads.
01-10-2010, 03:12 PM | #17 |
WHY WOULD ANYONE WHO KNOWS ANYTHING ABOUT BRAKES PUT OIL ON THEM.
01-10-2010, 03:58 PM | #18 |
Drives: the 2nd amendment home Join Date: May 2008
Brakes work by friction. WD40 uses mineral oil, mineral oil reduces friction.
NO brake manufacturer, Or D.O.T. would verify your advice. Some mechanics would, these are the same mechanics that I wouldn't let near my car with a tire gauge, much less a wrench.
-- Benjamin Franklin |
01-10-2010, 04:59 PM | #19 |
Drives: 2010 Join Date: Jul 2009
DO NOT LISTEN TO THE PEOPLE TELLING YOU TO USE WD40.
01-11-2010, 05:46 AM | #20 |
TRUE, do not use WD40, best product to use is: "AC Delco" Brake Cleaner.
It will dissolve and remove brake dust, grease and other contaminants from the brake parts. Just spray on brake parts and leave to run off, then air-dry or whipe it with a lint-free cloth. Case Closed. |
Thread Tools | |
Similar Threads | ||||
Hawk Performance Brake Pad "Updated" | KILLER74Z28 | Suspension / Brakes / Chassis | 34 | 05-04-2016 11:11 AM |
DBA Brake Rotors, Hawk Brake Pads, and Motul Fluids! | AJ@ECSMotorsports | Suspension / Chassis / Brakes | 49 | 11-13-2010 03:57 PM |
Stoptech 4/6 POT Front/Rear BBK, Brake Lines, and Pads - Best Prices! | AJ@ECSMotorsports | Suspension / Chassis / Brakes | 45 | 11-13-2010 03:55 PM |
Goodridge Stainless Steel Brake Lines ~ Brake Better! | Circuit Motorsports | Suspension / Chassis / Brakes | 68 | 02-26-2010 07:13 PM |
Stoptech Big Brake Kits | 6 Piston Calipers ~ Now Available! | Circuit Motorsports | Suspension / Chassis / Brakes | 5 | 10-07-2009 12:27 PM |
