JUICEDMOTORSPORTS
Old 12-20-2009, 12:23 PM   #1
drtwo
drtwo's Avatar
Drives: 2SS RS Yellow, Raptor, Vrod
DIY Ramp to change oil *****
1) I purchased 2 - 10 foot 2x10's and had an old 2x4 sitting around.
2) I cut the 2x10 in lengths:
...... 4 1/2 feet - 2 each
...... 3 1/2 feet - 2 each
...... 2 feet - 2 each
3) Used wood screws to fasten together, building from bottom up.
4) Put a 2x4 in front to prevent car from rolling off the front.
You could vary the length of the cuts from above, but this works fine for me and only need to purchase 2 of the 2x10's at $18 total.
2SS RS Rally Yellow, LS3, M6, sunroof, extra on the fast!
drtwo is offline   Reply With Quote
Old 12-21-2009, 07:39 AM   #2
tradosaurus
Drives: 2010 F150 Lariat, Candy Red
Nice job!
A few questions:
1) How heavier are these ramps and and is it hard to store?
2) Are you concerned that it would be more likely for the tires to slip off while driving on the ramp?
tradosaurus is offline   Reply With Quote
Old 12-21-2009, 08:51 AM   #3
adub4185
Drives: 2010 Black 2SS RS, 1995 BMW M3
Send a message via AIM to adub4185
Originally Posted by tradosaurus View Post
Nice job!
A few questions:
make no mistake, the wooden ramps are HEAVY. mine are very similar to the ones pictured (they have a few extra levels to bring the car up a bit more), but they are heavy regardless. if i had to guess, i would say each ramp weighs around 60-70 lbs.
i am not at all concerned about driving on them. just line them up carefully and drive up slowly. even if you are off by a bit, the care is not going to slip off. you would have to be way off line and very crooked to have the car fall of the ramps. mine are 10" wide and i have no problems with them.
adub4185 is offline   Reply With Quote
Old 12-21-2009, 02:18 PM   #4
ffrcobra_65
nice idea. I just might make a pair. Question, any possibility the ramp might tilt up and smack against the underside as the tire initially gets on the square edge of the first step?
Old 12-21-2009, 02:55 PM   #5
adub4185
no, there is zero chance of that happening. they are so back heavy that it is impossible. you can always angle the edges of the steps to make it easier for the car to roll up on like i did. check this thread out for more on this DIY: http://www.camaro5.com/forums/showth...t=32759&page=3
Old 12-21-2009, 04:02 PM   #6
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Why didn't you angle cut the leading edge of each step for an easier drive up?
Old 12-21-2009, 04:10 PM   #7
ffrcobra_65
thanks!
I sold my 1965 Cobra replica and I just sold the kwiklift since I couldn't justify it taking so much space in my garage anymore. I will be making a pair of these during my time off next week.
Old 12-21-2009, 10:33 PM   #8
savage71ChevelleSS
Drives: 2010 Camaro 1SS Imperial Blue
I made mine with 4 levels of 2x10's. Since they are only 1.5 inches tall, that only brings it up 6 inches, which is enough for oil changes. I would think three levels is too tight. I also did cut the front of each board on a 45 degree angle, it does make a difference. They are heavy, but you will never have a problem with them. They are so strong you could drive a 10 ton dump truck on them for an oil change
savage71ChevelleSS is offline   Reply With Quote
Old 12-23-2009, 01:28 PM   #9
drtwo
drtwo's Avatar
No chance of slipping off, that is why I used the 2x4's at the top end. If you use 2x10 you should have no excuse for missing the ramp!
I didn't trim off the front because it is unnecessary. It'll step up that 1 3/4 inch with no problem. If you have spare time to blow...cut away!
These weigh probably 30lb or so and I store them in front of my Blazer. I tip one on top of the other and makes a box. You could store on the wall I suppose.
Old 02-09-2010, 09:09 AM   #10
crzycicada
crzycicada's Avatar
Drives: 2SS/RS/LS3
Hey all, I was the one who posted the original thread with the link on how to build these ramps. I can totally vouch for everything drtwo is saying about their weight! They are freakin heavy. I did cut the ends at an angle just for kicks. Since you're cutting the boards why not just tilt your saw to 45 degrees? It's totally not necessary though. I also added thicker end stops on the very top piece to ensure you don't take a dive over the end. I've thought about adding casters or something to the very end so that you can pick up one end and roll them away but haven't done that yet. All in all, very sturdy ramps and much cheaper than anything you can buy that's pre-made!
Order date: 7/17/09
3000 TPW: 8/17/09
3400 status on 8/11/09
3800: 8/21/09
4200: 8/24/09 on rail car ETTX850796
5000/6000: 9/2/09
crzycicada is offline   Reply With Quote
Old 02-09-2010, 09:33 AM   #11
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
I built my ramps this weekend. Mine are 10.5" high by 60" long. I staggered my levels by 6 inches. While this is an inexpensive pair of ramps I think eventually I will be buying a pair of the race ramps.
Lessons learned from my build:
*These things are heavy as hell - 2x10 lumber weighs about 3.37 a linear foot so my ramps weigh about 85 pounds each.
*10" wide works but can have a tendancy to wiggle as your drive up them. Once I was on my ramps my tires were hanging over the side by 3 inches. I had to jack the car up and move the ramps square under the tires. 12" may be a better width.
*10.5" in height gets the camaro plenty high in the air. Jack stands on the rear would be plenty of height to do exhaust or shifter work.
*In writing this post I cant spell.
Cheers
K
Moriartii is offline   Reply With Quote
Old 11-05-2010, 08:34 AM   #12
Dr Jkel
and MR. HYDE
Dr Jkel's Avatar
Drives: 2010 2SS RJT/BLK 6Spd Man
Will these work on a lowered car?
MUSTANG...Like Bringing a Hot Dog to a Steak Dinner....There is no comparison.
Dr Jkel is offline   Reply With Quote
Old 11-05-2010, 07:56 PM   #13
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
my car is supper low .i have the razzy lower vailence and mabe 3 inch clearance.i also made this exact set this summer . i cant get a jack under the front of my car and the ramps work perfect. i have a pair of the plastic ramps from autozone and the suck .well for me anyway.
chevy 3 is offline   Reply With Quote
Old 09-22-2011, 09:51 PM   #14
94ChevyCamaroV6
Drives: 1994 Chevy Camaro V6 3.4L Car.
Im not sure If I should build this one or the other ones that were on a write on guide because this one has three levels and the link for the other one has four levels and my camaro Is stock as far as a lift kit Its a 1994 Chevy Camaro V6 3.4L Car. Im guessing It should clear both of these ones without any problems. But Im not sure which one I should build. Then. http://www.mustangworld.com/ourpics/...amps/index.htm .
94ChevyCamaroV6 is offline   Reply With Quote
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 08:51 AM
Car "waking up" after oil change..is this due to the fuse pull? CamaroFemme 5th Gen Camaro SS LS LT General Discussions 6 10-05-2009 03:44 PM
How about a barrel of oil for around $16? Blownhotrodder General Automotive + Other Cars Discussion 19 03-06-2009 07:25 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
