Vivid Superchips
Suspension / Brakes / Chassis All suspension, brakes and chassis discussions.
Old 12-22-2009, 10:48 AM   #1
caverman
caverman's Avatar
Drives: '69 SS Convertible
Need some help deciding on Spring/Sways
I’m trying to get somewhat of a budget together and decide what mods I can afford and in which order I want to do them. Lowering the car is going to be a MUST! A good stance changes the look of the car.
This is going to be my DD and I don’t plan on doing any more than the occasional run at the drag strip. I’m mostly going for the looks department and of course price is an issue. Coilovers look like they will be overkill and way out of my price range. So I’ll be sticking to Springs and maybe Sway bars.
In the past I’ve used Eibach and Hotchkis and had no problems with either. Looking at some pics I think the 1” drop of Eibach is not going to be enough. Haven’t seen any Hotchkis for the 2010 Camaro yet. I really like the DSE setup but they only sell the Springs/Sway Bar combo for about $950. I don’t want to drop that kind of money all at once and will probably just do Springs for now and Sways later on. After DSE I like either Pfadt or Pedders. Both of those sell just springs, look about the same ride height, and seem to be very knowledgeable and reputable companies.
Does anyone have any Pros/Cons over using either of these Springs? Where is the best place to purchase the Pfadt or Pedders springs?
Now for the Swaybar questions. I’m sure they would be nice to have but I’ve never had a car with updated Sways. Will they really make a noticeable handling difference? Won’t just the upgraded Springs make it handle better? I’m assuming if I can handle the Spring install that I should be able to handle the Sway install as well? I know an alignment is needed after the Spring install but what about after the Sway install? I’m assuming it doesn’t really need an alignment for just the Sways.
TIA for any comments or suggestions you can give.
Build Journal
Old 12-22-2009, 05:43 PM   #2
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
Personally I am a huge fan of BMR products. You would be hard pressed to find better products for the price you can get BMR for.
I woudl use their new drop springs whihc would lower you 1 inch all around. They will be available early in January.
As for your questions on sway bars. YES they can make a huge difference in handling. They are also adjustable depending on which ones you buy. SO you can set it up to be very stiff for track days, for drag racing, or even for regular driving.
Sway bars and drop springs are an excellent upgrade for the Camaro.
If you have any questions or just want to chat abotu this feel free to send me a PM or call, or email...I am always here to help.
ZZcamaro is offline   Reply With Quote
Old 12-22-2009, 11:33 PM   #3
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm
hotchkis has adjustable sway bars currently available, springs will be available in late jan. as well as a bunch of other components that will be available shortly afterward. hotchkis has been developing a complete line of suspension pieces that are currently being tested. hotchkis may not be the first to market but they always bring a quality product thats throughly tested before it goes to sale to the public.
urr2slo is offline   Reply With Quote
Old 12-23-2009, 12:13 AM   #4
d69chris
Florida C5
d69chris's Avatar
Drives: 2010 Camaro 2SS Vortech L99 IOM
Send a message via Yahoo to d69chris
You should be able to get some drop springs and sway bars installed for around $900 w/ alignment.
Alignment might not be a must with only 1" drop.
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
d69chris is offline   Reply With Quote
Old 12-23-2009, 12:23 AM   #5
d69chris
Florida C5
d69chris's Avatar
You should be able to get springs and sways installed for ~$900+. $250+$450+install
Eibach, Pdfat, Hotchkis, BMR are all good
Springs first for looks, then sways for handling.
Or ~$2000-2400 for coil overs
Old 12-26-2009, 12:50 PM   #6
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
Eibach springs and bars here. Removal of the factory front sway bar is a bitch. Rear is easy. Install the bars and springs at the same time. Front bar comes out the right side but takes some tweeking. One inch on my car as I measured before and one week after. Start stocking up on parts before your car gets here. Good Luck
ADM built Silver 2SS/RS Man/6
1.9 L, ZL-1 Blower, ADM LSA Heads
CTS-V front 6-Piston Calipers, ADM Dual Fuel Delivery
ADM/LPE Dual-Disc Clutch, GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Need Help Deciding Between 18" Winter Rims for 2SS/RS y2jdmbfan Wheels and Tires Talk Sponsored by The Tire Rack 17 12-12-2009 03:56 PM
I need some helping deciding on wheels daphatgrant Wheels and Tires Talk Sponsored by The Tire Rack 27 11-10-2009 08:35 PM
Need help deciding interior color kellertxgen5 5th Gen Camaro SS LS LT General Discussions 1 07-17-2009 12:13 AM
thinkin about a bike... need some help deciding CamaroSpike23 Off-topic Discussions 20 11-25-2008 01:09 PM
Something to think about when deciding on wheels.. DARK AGE 53 Wheels and Tires Talk Sponsored by The Tire Rack 0 11-18-2008 12:40 AM
