JDP Motorsports
Old 12-22-2009, 03:20 PM   #1
G.E.
G.E.'s Avatar
Drives: black on black twenty ten ss/rs
after firsr oil change, do u get it changed every 3, 5, 8, 10,000 miles?
i thought it was every 3000 miles... some dealer and others were tellin me 8-10,000 miles.. or should i not do it by mileage, instead just follow my oil percentage?
I GOT MINE! Where's yours? :(
G.E. is offline   Reply With Quote
Old 12-22-2009, 03:50 PM   #2
Dakota Kid
Dakota Kid's Avatar
Drives: 2010 2SS/RJT/L99
It is synthetic oil, therefore I will change it every 6 thousand miles. To ME, any more often than that is just a waste.
You will get a million different opinions, though.
2SS/RJT/L99
Dakota Kid is offline   Reply With Quote
Old 12-22-2009, 03:57 PM   #3
faninc
Drives: 2010 Camaro RS in SIM
Depends on your driving as well, highway or all local makes a difference.
Synthetic 6,500-7500 should be fine. Reg. oil more like 4,000-4500 should be fine. Many tests show today's oil changes at 3,000 mile intervals is just wasting money!
As mentioned, everyone will have an opinion- so do what you feel good about. Above is what I do based on all my cars in time and from reading. Never has an engine related problem in 29 cars.
best
J
faninc is offline   Reply With Quote
Old 12-22-2009, 04:41 PM   #4
Wild Bill
Wild Bill's Avatar
Drives: Camaro 2015 RS CRM
I changed mine at 500 miles. I will put only around 5000 miles per year. I will change mine twice per year erroring on the cautious side.
IOM 2SS/RS manual
1100 - 4/7/09
3000 - 5/27/09
6000 - 7/17/09
See my Thread in New York Metro Area.
http://www.camaro5.com/forums/showthread.php?t=33878
Wild Bill is offline   Reply With Quote
Old 12-22-2009, 04:54 PM   #5
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Drives: 16 Encore, 07 G6, 99 Astro, 16 VW
From what I have read, and i have done alot of reading on the oil management program that GM used in determining the oil life percentage. It uses data from engine and transmission sensors and engine run time to determing load, temperature and a few other factors and based on known oil life tests, it is fairly accurate to just go by the oil life monitor.. But you have to also factor in yourself the driving conditions such as how dusty the conditions you drive in.. Myself I usually let the Oil life go to about 50% before changing.. that is usually around 5,000-6000 miles
Owners manual in My HHR says to change oil when the oil life montor indicates it is time, or once a year whichever is shorter.. Your dealer or garage will probably tell you every 3,000 miles.. but they are there to make money.. they Want you to overchange your oil...
The Bird is the word!
Old 12-22-2009, 04:59 PM   #6
brandotron
I am the internets.
brandotron's Avatar
Drives: dangerously
If you make sure to rinse the engine out with water after your first oil change, you'll be able to go 20k on synthetic. The trick is to fill your oil pan with h2o, then start your car. The circulation will remove all of your break-in shavings.
brandotron is offline   Reply With Quote
Old 12-22-2009, 05:07 PM   #7
Angrybird 12
You can't be serious
Old 12-22-2009, 05:11 PM   #8
brandotron
I am the internets.
brandotron's Avatar
Drives: dangerously
Old 12-22-2009, 05:12 PM   #9
TommyTSquared
TommyTSquared's Avatar
Drives: RSSS
LOL did you change your title under your name after we had our little talk about 'Space Docking'!?!
And you know someone is going to take this seriously
TommyTSquared is offline   Reply With Quote
Old 12-23-2009, 01:52 AM   #10
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
Yep....I read it on the internet!
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 12-23-2009, 02:01 AM   #11
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
I remember reading the thread about the Mustang owner that did this. Please don't let let one of our Camaro's have the same fate...
Sterling is offline   Reply With Quote
Old 01-31-2010, 09:34 PM   #12
pk1225
pk1225's Avatar
Drives: '68 SS396, '02 SLP SS, 2010 2SS/RS
That only works on Mustangs, busted!
pk1225 is offline   Reply With Quote
Oil Change Confusion- Help Wanted Dr Jkel Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 32 10-03-2009 08:22 AM
Help - Oil change hasn't been done yet @ 4500 miles firstmate Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 13 08-30-2009 10:42 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
