SDTW Custom Wheels & Tires
Old 08-04-2008, 11:14 AM   #1
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
L99 heads vs LS3/L92
the L92 and LS3 share the same head/port design, can we assume that the L99 heads will also be the same as the LS3/L92's
looking to have a set of heads ready to go for the new camaro
thanks
Old 08-04-2008, 11:23 AM   #2
jmliptak
Drives: D
Elie or one of the other disciples may know, but no one has said anything to indicate they are different, but no one may have asked the question yet....
jmliptak is offline   Reply With Quote
Old 08-04-2008, 11:49 PM   #3
gunslinger
Drives: 1998 Z28 M6
Someone posted in another thread that the rev limiter on the LS3 is 6600 RPM while the L99 is 6000 RPM.
That either has to do with keeping the RPM's down on the automatic transmission(RPM's KILL an auto trans) or that the springs on the L99 heads can't handle the extended RPM band.
gunslinger is offline   Reply With Quote
Old 08-23-2009, 05:29 PM   #4
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
Tranny RPM
2010 IOM 2SS/RS A6, Tuned by Me, ARH/NoCats, Borla Touring, Vararam CAI, G-Force 9" with 4.10's, Circle D 4500K, (Skinnies/Slicks, and Bogarts all around 24MPG
11.39 @ 118 510 DA
www.6l80tuning.com www.6l90tuning.com
Wacker is offline   Reply With Quote
Old 08-23-2009, 07:10 PM   #5
PatrickfromMD
PatrickfromMD's Avatar
Drives: Navigator/Corvette/2010 Camaro
Nope, it's the AFM, specifically the lifters. The cam is milder, sonits not making power that high anyway
***56K miles and still going strong***
2SS/RS IOM ext w/cyber grey stripes, tinted windows, IO int Auto
ProTorque prototype Converter, Chuck Mosello of Westchester Corvettes Custom Tune
T&T installed SLP Longtubes, Powerflow X Pipe, and Powerflow axle back
JL 10W3 in custom side sub box, new door tweeters, Alpine 5ch 600 watt
T&T configured ACS front Fascia w/ heritage grill, splitter, dual color halos, , led markers, taillight bezels , all accented in CGM
Gary Custom Z vented fenders. Vararam ver 2
PatrickfromMD is offline   Reply With Quote
Old 08-23-2009, 07:19 PM   #6
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
Yep your right... I found where the maximum shift sped is 6500RPM. The car stops making power well before that though.
11.39 @ 118 510 DA
Old 08-23-2009, 08:14 PM   #7
rayhawk
rayhawk's Avatar
Drives: Trailblazer SS
The LS3? It is still making just under 400 hp at 6500 rpm, I wouldn't call that not making power. It may be past peak, but it is still more power than would be available at 4500 rpm in the next gear. The L99 is limited to 6200 rpm.
Hooters, hooters, yum yum yum, hooters, hooters on a girl thats dumb.
-Al Bundy
07 2WD Trailblazer SS, LS1 E-fans, 4" FWI, pcmforless tune
rayhawk is offline   Reply With Quote
Old 08-23-2009, 08:21 PM   #8
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
We are talking about the L99.
11.39 @ 118 510 DA
Old 08-23-2009, 08:45 PM   #9
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
whats a the l99 safe stock spring redline
May your exhaust note, sing in harmony with your blower.
hot ss is offline   Reply With Quote
Old 08-23-2009, 10:14 PM   #10
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
Do me a favor, some one with an LS3 go out and see what the casting # is on your heads, then some one with an L99 go out and see what the casting # is on your heads. Someone suggested to me that the head casting # was different. We know the LS3 heads contain lighter valves...probably different valve springs also, as the LS3 cam's max lift is over .550 vs the L99 being less than .500, the LS3 CR is more, but only 0.3 more 10.4:1 vs 10.7:1.
But the new question, is...is the head design the same or different. It seems like L99's for the same mods are down more on power than just the what the drive train loss would account for. Saying that even with aftermarket mods (mods being equal...such as cam or whatever), its not right.
I emailed a couple shops that do heads, and asked if they had inspected any bare L99 castings vs LS3 but I got no replies.
Maybe its nothing...or maybe its something...it just "appears" that the L99 is down more power than what drivetrain loss will account for.
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
pharmd is offline   Reply With Quote
Old 08-23-2009, 11:46 PM   #11
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
I'll be back on friday and will post mine if no one else does. I'll I know is they use the same headers, I think.
11.39 @ 118 510 DA
Old 08-24-2009, 12:05 AM   #12
9c1ny
9c1ny's Avatar
Drives: C6 Zed-oh-six
I think I know who you talked to
yeah it appears the heads are different, I believe mine (and his) are 853s?
both L99s
9c1ny is offline   Reply With Quote
Old 08-24-2009, 07:05 AM   #13
rayhawk
rayhawk's Avatar
According to GMHTP, the heads are identical. But as you said, it is possible there are some differences in the springs or valves. I believe the CR difference is due to the valve pockets in the pistons.
-Al Bundy
Old 08-24-2009, 08:11 AM   #14
GMRULZ
GMRULZ's Avatar
Drives: 2010 SS & 2008 C6
Truth...
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s!
Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list..
GMRULZ is offline   Reply With Quote
Can a Superchagered Z28 have a lumpey CAM, and sound like a NA heads and cammed LS3 D-Unit Forced Induction - V8 12 07-29-2008 04:34 PM
L99 discussion The_Blur Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 85 07-25-2008 03:07 PM
L99 Theory, Gas Guzzler Tax pruettfan 5th Gen Camaro SS LS LT General Discussions 12 07-22-2008 02:06 PM
Parts from GM (cam and heads etc) blackgloves Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 22 06-19-2008 11:48 PM
Cylinder heads Stroker Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 06-06-2008 12:08 AM
