| Suspension / Brakes / Chassis All suspension, brakes and chassis discussions. |
Thread Tools |
Florida C5
Drives: 2010 Camaro 2SS Vortech L99 IOM Join Date: Jul 2009
What Brake fluid R U using??
I bought a set of braided stainless lines to replace the rubber hoses on my Camaro. Installing a set of drilled slotted Racing brake rotors.
I figured this might be a good time to upgrade the brake fluid. Not building a pure track/race car, but will be tracking and drag racing for fun. Not my daily driver. Input please......................
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
On a list for a 2014 Z28
![]() Drives: 2010 Camaro 2SS M6 Join Date: Oct 2008
If you like spending $ buy the Castrol SRF.
Florida C5
I don't like spending money on brake fluid.
![]() Just figured while the system was open, I would upgrade. ![]() What about super blue or Motul RBF600? I read about shelf life on brake fluid. I don't want something I have to change every six months either. ![]() I like spending it on go fast and stay together stuff!
![]() Drives: Corvette ZO6 CSR edition #47 Join Date: Apr 2009
Wildwood 570 in my ride.
Nationwide Turf
"artificial turf factory" |
![]() Drives: Z06, 69 Camaro Join Date: Oct 2009
Motul RBF600 FTW.
#6 |
![]() ![]() ![]() ![]() Drives: 10 Camaro, 10 GT500, 09 GT-R, etc Join Date: Dec 2009
Motul RBF600 or we also carry 3 different AP Racing fluids.
Dan
JT - STILLEN Performance Specialist stillen.com | email: jtang(at)stillen.com 3176 Airway Ave., Costa Mesa, CA 92626 - We do installs! (714) 540-5566 x174 Authorized Dealer - PFADT | KW | Eibach | JBA | Magnaflow | Stainless Works | Kooks | K&N | Airaid | AP Racing | Hawk | Magnuson | Whipple | Edelbrock | Vortech | RKSport | Seibon | ACT | Street Scene |
#7 |
Florida C5
Don't know if I want full racing fluid.............
On the Motul RBF600 is there a shelflife where you need to change the brake fluid at different intervals like your oil? Dan, What do you think of Super Blue?? Can you PM me some prices? I would like better fluid, but don't want to become a bigger slave to this car than I already am. Thanks for the feedback
#8 |
High on "The Camaro Life"
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam Join Date: May 2009
Motul RBF 600....I've been running it in my camaro since August,
I love it. But do it right and flush all the factory DOT3 out.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
#9 |
![]() Drives: 1969 Corvette Join Date: Dec 2009
any reason not to go with standard DOT 4 from any local parts store? If you're not spending that much time on a road course track it might not make sense to pay the premium for race fluid. JMHO
#10 |
Florida C5
What....not spend money on my camaro....rediculous.
Will check out some other DOT 4's at Autozone, just always looking to improve the car where I can.
#11 |
awesome!
Drives: 07 Jetta WB, '92 GTI 16vT, '76 LUV Join Date: Sep 2009
#12 | |
You will notice that the Motul RBF600 is more than 100 degrees higher than the rest.
#13 |
![]() ![]() Drives: Getting 2010 Camaro Join Date: Jul 2008
How long will the Motul last before it needs to be changed out?
#14 |
Florida C5
Good question.......any takers???
#15 |
At least as long as the oem DOT3 fluid.
#16 |
#17 |
Florida C5
Was it about 2.5 liters to change out the fluid?
#18 | |
Drives: Several Join Date: Nov 2009
If you are committed to flushing the brake fluid anyway, it would be a great time to upgrade to stainless steel braided brake lines. You'd get a huge improvement in pedal feel for a moderate cost. Chris |
#19 |
#20 |
Florida C5
Thaks for the input Chris, got my stainless lines, just need to get the fluid.
#21 |
Motul RBF600 is our fluid of choice for street/track cars
-594 degree dry boiling point - 421 wet The higher dry boiling point helps prevent vapor lock and brake fade under harder braking and demands, but still has good recovery for excellent pedal and brake modulation. As for fluid life, just inspect the fluid periodically and check the color as the fluid darkens you will want to flush and re fill. |
#22 | |
Here's the problem(s)....what do you do on the 2nd flush when you're replacing blue fluid with blue fluid? Another potential problem is that the blue dye that's added tends to dye everything...like the plastic reservoir. I would certainly be upset if the brake fluid reservoir on my brand new car was permanently dyed blue. IMO you're better off going with one of the non-dyed high quality fluids like AP Racing or Motul. Dan
#23 |
Florida C5
Thanks Dan, Motul it is!
| Thread Tools | |
| DBA Brake Rotors, Hawk Brake Pads, and Motul Fluids! | AJ@ECSMotorsports | Suspension / Chassis / Brakes | 49 | 11-13-2010 03:57 PM |
| Brake fluid leak | twintailf14 | Suspension / Brakes / Chassis | 14 | 07-23-2010 10:50 PM |
| Hawk Performance Brake Pad "Updated" | KILLER74Z28 | Suspension / Brakes / Chassis | 33 | 03-06-2010 04:32 PM |
| LEAKING BRAKE FLUID | twintailf14 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 4 | 11-29-2009 12:38 AM |
| How many Quarts of Brake Fluid? | SSOOCH | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 15 | 07-30-2009 09:13 AM |
