| Wheels and Tires Talk Sponsored by The Tire Rack Discuss issues related to wheels and tires |
Thread Tools |
![]() Drives: 2010 CAMARO SS L99 Victory Red Join Date: Jun 2009
Camaro SS / Brembo Brake 18" rim problem for winter tires
HEADS UP - Ordered tires and 18" rims for the winter from The Tire Rack but they have been informed of a "in production" brake pad change that may cause your 18" rims not to fit when you have to get new pads. Anyone else heard of this? Appears Brembo and Chev have made an on the fly change and now the new pads are larger and won't clear 18"rims! They were going to ship my tires but stopped until they figure out what is going on.
Resident Disciple
Drives: 2010 CTS-V 6MN '98 Camaro SS (Sold) Join Date: Dec 2007
If you have an SS (20" wheels), then you might have a problem regardless, just trying to fit 18" wheels over the original Brembo calipers. Usually it's the size of the calipers that prevent the use of smaller wheels.
When I did the C5 brake upgrade on my '98 SS, I determined that if my car had the original 16" wheels that came on the Z28, they would not fit over the C5 calipers. The 17" SS wheels barely clear the C5 calipers, but the donut spare does not. Best regardSS, Elie
2010 Cadillac CTS-V 6MN Thunder Gray
1998 Camaro SS # C079 SOLD |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: the 2nd amendment home Join Date: May 2008
Hey garfin
![]() CTS-V? or still waiting? ![]() Brake pad thickness won't change the rotor placement. The rotors themselves have changed tho, I believe it has to do with the weights that used to be mounted on top... there's a thread about it around here someplace.
-- Benjamin Franklin Great Racing Quotes "Never run out of real estate, traction and ideas at the same time." "I was doing fine until about mid-corner when I ran out of talent." "Don't brake until you see God, just don't meet him" |
#4 | |
Resident Disciple
Best regardSS, Elie
#5 | |
![]() Drives: Summit White 2SS RS Join Date: Oct 2009
I can't tell if the weights are part of the pad backing plate or another part of the caliper assembly. In any event, the weights appear to protrude much further than the stick on weights do. This will certainly effect the usability of 18" wheels on an SS going forward. |
#6 |
WFO all the way
Drives: Yellow 1SS/RS Join Date: Aug 2009
SS wheels 18" fits well
I bought these at tire rack and I have a lot of space for thicker pads even if the caliper moves out.
Bought these for 1450 with sensors! These are awesome in the snow. Firestone winterforce wheels msw type 12.
Mods: Knighlight, Eibach sways and 1"dropsprings, usb PDIM and steering buttons from 2SS, footwelllights, fogs AAC PW13 with jumper, Trak+ widetrack spacers, 1-4 eliminator, Pedders bushings, subthumb+10" sub with amp, flowmaster axleback and CAI, Barton short shifter, BMR trailing arms, stainless steel brake lines. Also: blue metallic painted stripes and yellow interior. ![]() ![]() |
#7 |
WFO all the way
Sorry , I meant goodyears not firestone.
#8 |
Turbos. Turbos. Turbos.
Drives: 2010 SS Yellow/Black Join Date: Nov 2009
18 in. wheels fit no problem on the SS, maybe 3/8-1/2 in. of minimum clearance.
John Spina
Caspers Electronics Inc. 1965 AC Cobra Replica FFR Spyder GT 2010 2SS/RS Yellow/Black > http://www.bummlbe.com |
#9 |
This same wheel did not fit my SS. The top of the caliper weights were rubbing against the inside of the barrel. |
#10 |
Ouch! So, did you find out if there was a change in the spec for that caliper? It's a 3rd. party component, so there must have been a reason...which makes me wonder what the "problem" was with the first run. I don't experience squeaky brakes (not yet). Had to have been a pretty big issue.
It must be a Brembo issue. It would be very interesting to see what Tire Rack comes up with. It has to have been changed after a certain VIN date. EDIT: My VIN is 53xxx. I think we should poll the list to see when that change was initiated.
John Spina
Caspers Electronics Inc. 1965 AC Cobra Replica FFR Spyder GT 2010 2SS/RS Yellow/Black > http://www.bummlbe.com Last edited by GNVenom; 12-26-2009 at 08:23 AM. |
#11 |
To play it safe I went with the 19" MSW Type 16 in black.
There was plenty of space between calaper and brake. But it was close between the Spokes and Brake Caliper. Had about 1/4-3/8" clearance. But that is enough |
#12 | |
Account Unaccounted for
Drives: Black SS Join Date: Dec 2009
I'd like to see a list generated about this.
#13 |
![]() Drives: 2013 IOM ZL1 Join Date: Feb 2009
#14 | |
Have pity on the poor SS that unfortunately crosses your path
| Thread Tools | |
| Camaro Product Manager - interview | Moose | 5th Gen Camaro SS LS LT General Discussions | 11 | 04-04-2012 06:10 PM |
| Hawk Performance Brake Pad "Updated" | KILLER74Z28 | Suspension / Brakes / Chassis | 33 | 03-06-2010 04:32 PM |
| GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 07:33 PM |
| Official Camaro Convertible CONCEPT Press Release | Tran | Camaro Convertible Forum | 12 | 11-18-2009 07:05 PM |
