Haddad Motorsports
V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment Intake, exhaust, tunes, other bolt-ons for V8 Camaros
Old 12-23-2009, 02:53 PM   #1
tooNz213
Drives: Camaro
FS: New Venom 424cc 40lb/hr High Flow Fuel Injectors
EMAIL: MARK_HOU@YAHOO.COM OR PM ME
New in Box NEVER USED VENOM FUEL INJECTORS COME WITH 6 AND FIT MANY CARS UNIVERSAL PART #: HP-640-6
Product Features
It's 40LB and 424CC
* Precision balanced set of 6, 40 LB/HR performance injectors
* Designed to support up to 510 Horsepower
* Universal fit for grommet style, multi-port applications
* High impedance (Ohm) coil
* Used by top, professional race teams, not for street use
VENOM Performance Fuel Injectors are 100% flow tested, balanced and matched to within +/- 1.5% of their nominal flow rate. These injectors are sold in matched sets. The Fuel Injector Pintle Assemblies are matched and blueprinted to increase flow rate and fuel atomization. All internal O-rings are manufactured of an advanced polyelastamer compound which increases their resistance to fuel chemicals and also, resists damage caused by the higher temperatures performance engines create. The Electromagnetic Coils injector coils are molded of aerospace grade materials and wound with micro-meter tolerances to decrease activation time at the start of each duty cycle. The coils are encased in Kapton tape and molded to protect against electrical current leaching when under severe load. In manufacturing the Electrical Plug VENOM uses solid copper terminals to increase current flow to the coils. Also the terminals and guide pins are slightly oversized to ensure a tighter fit and lesson the chance of corrosion damage, while maintaining a solid electrical connection. The Filter Basket is a fine mesh filter designed to protect the injector internals from contaminant damage. The filter is also manufactured from a fuel/oil resistant polyelastamer. The External Injector Seals are included for each injector and are also designed to withstand the pressures and heat generated by performance applications.
I'm asking $220 FIRM PICK UP OR $235 SHIPPED USPS Priority Mail THESE SELL FOR ALMOST $500
tooNz213 is offline   Reply With Quote
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
Americans unwilling to pay for big fuel economy gains, carmakers say Scotsman General Automotive + Other Cars Discussion 7 04-18-2008 12:27 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 10:06 AM
