| Suspension / Brakes / Chassis All suspension, brakes and chassis discussions. |
Thread Tools |
#26 | |
Rice Cooker
Drives: Avalanche Z/71, 2010 Camaro2SS Join Date: Jun 2008
Im not a tough guy behind a keyboard, just calling out a jerk when i see one. |
#27 | |
Banned
Drives: 2010 Camaro 2SSRS and a 09' Deluxe Join Date: Oct 2009
"Try to have a little more class and humble your self" This is something you may try... |
#28 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
Because we have not officially launched our coilovers yet, there is not a tremendous amout of details out there on them. I'll try to fill in a few of the high points of what is coming. Those of you who made it to SEMA could see the package, but that has been the only real public showing. I've added some info below in regards to the features of the Pfadt coilovers and why they are a bit more expensive as a result. The main features of our Pfadt Coilovers: Inverted monotube design in on the front strut. This provides that really large shaft section that you see with our front coilover. That is important because the front strut takes cornering loads in these cars and the stiffer the tube, the better. This has the effect of placing the adjuster knob on the bottom of the strut for easy access. It is a click style adjuster with 20 clicks that are very positive and easy to feel. It is a simple matter of reaching around the front tire and making a couple of twists to change your damping.* Inverted body design on the rear damper. This reduces unsprung mass (a good thing) and also places the adjuster at the bottom of the damper where you can reach it. It is also a click style adjuster wrapped around the shaft section just below the spring perch.* Our dampers in both the front and rear feature single point adjust-ability which controls both compression and rebound damping together. This is a design that we have found to be very flexible and user friendly in our Corvette offerings. Basically, you do not need to be a damper engineer to be comfortable making adjustments and it is easy to switch from a 'street' setup to a 'track' setup with just a few clicks.* Our damper are mono-tube design and feature a separate internal gas chamber, which in the industry is referred to as 'non-emulsion' design. Mono-tube non-emulsion shocks are what you find on most every production based race car everywhere. It is the best design and provides the most consistent and reliable operation. Many of the other offerings for the Camaro are not, ask the manufacturer if you are curious.* The final feature about our coilovers that I will share today is that our coilovers take a 'standard' flat ground race spring. Many other use a custom spring to fit the Camaro specifically. Using a standard spring size allows extreme flexibility in spring rate choice. You can call up any race supplier and order springs in 25 lb/in increments that will work on our coilovers. We provide a set with our coilovers that will work well for most people, but the flexibility is there for those who want it. |
#29 |
![]() Drives: 2010 Inferno Orange SS Join Date: Sep 2009
I don't remember the part numbers but they are the one inch (smallest) drop springs....
2010 Camaro SS, M6, MTI shifter and sway bars, GM quarter flares, Corsa catback, Roto-Fab CAI, 30% tinted windows, Lloyd's custom mats, Hawk ceramic pads, Pedders lower coils, Magnuson supercharger with 3.6 pulley, BMR trailing arms & toe rods, Kook's LT's1 7/8 w/cats, Lingenfelter/SLP billet pedals, KW V'3 Coilovers, RevExtreme catch can, ---Ordered--- IconZ LS7 9 & 11" polished wheels!. Dyno'd 563.05 HP, 543.86 Torq.
#30 |
Yes, with a ride height change the alignment should be re-set. Both the camber and toe will change.
#31 |
One Lucky Guy.
Drives: #22 Tom Henry Racing 2010 2SS/RS Join Date: Dec 2007
Closed.
I don't car how informative this thread is. Personal attacks will get threads closed. Also, please negotiate with vendors privately
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
| Thread Tools | |
| Hotchkis: Tuned Suspension Setups | Springs | Chassis Brace | Sway Bars | FREE S&H | AJ@ECSMotorsports | Suspension / Chassis / Brakes | 80 | 11-17-2010 02:28 PM |
| Maximize Your Suspension ~ Hotchkis Swaybars, Springs and Chassis Braces! | Circuit Motorsports | Suspension / Chassis / Brakes | 99 | 05-24-2010 04:21 PM |
| Want to Lower Your Camaro? Step Inside! Eibach Springs and Sways Now Shipping! | Kris@BMCPerformance | Suspension / Chassis / Brakes | 20 | 01-15-2010 09:09 PM |
| Springs or coilovers? Eibach or BWoody? | G.E. | Wheels and Tires Talk Sponsored by The Tire Rack | 1 | 09-08-2009 09:07 PM |
| Pedderizing the Nickey Camaro! Pedders coilovers / suspension fitted & tested. | DallasMike | Wheels and Tires Talk Sponsored by The Tire Rack | 57 | 06-15-2009 04:36 PM |
