Old 12-26-2009, 03:56 PM   #1
tbss1
More then meets the eye!
tbss1's Avatar
Drives: 2010 Camaro 2SS/RS 426 hp
Alingment qustion
If you use 1" drop springs to lower your Camaro, and reclock the bushings is an alingment still necessary? If you don't how bad will drivabiltiy by? Where I live there is no good alingment shop. If drivability is bad then I wom't drop it, or i'll wait till I find a shop that can do a good job. Thanks for any help.
2010 2SS/RS, OBX l/t headers, with high flow cats, MBRP full 3" exhaust, modified air intake (CAI), Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidampr 25% upd, MGR shifter, VTC, and tune by Jannetty Racing. MRR M228 rims, phantom grill, vinyl wrapped hood and rear spoiler.
tbss1 is offline   Reply With Quote
Old 12-26-2009, 04:10 PM   #2
Chris-10
Chris-10's Avatar
Drives: 2ss/rs vr 6m
yes... it's gonna change the caster & camber. if you dont get it done it will wear out your tires very quickly.
Old 12-26-2009, 04:15 PM   #3
tbss1
tbss1's Avatar
Thanks.
Old 12-27-2009, 05:37 PM   #4
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
When you drop your Camaros, that will change camber and toe. Toe can be destructive.
Any time you do major work on a suspension, you must get it re-aligned.
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 12-27-2009, 05:47 PM   #5
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
mike
dms
+1 and the same goes for changing tire height or wheel offsets
