Old 12-26-2009, 04:26 PM   #1
markssylver
markssylver's Avatar
Drives: 95 bbb impala ss
pedders bushings ?
i recieved my drag bushing kit from pedders im trying to figure out where to put the grease that comes in the little packet also the instructions for the differential bushes says that the bushes that end in AHD go in the front and the one ending in BHD goes in the rear my issue is that i have 2 complete bushes that end in AHD and the last one half of the bush is a AHD and the other half is BHD is this the way its supposed to be
10.56@134mph
ADM BUILT AND TUNED CGM 2SS RS
ADM/LPE 417 with ported heads/inconel vavles gt11 cam
ADM ported maggie with 14 rib rear 10 rib front pulleys
ADM fuel system and race air intake
ADM/LPE ZR1 clutch /pedalreturn spring
ADM billet aluminum valve covers /RPM LEVEL 6 TR6060
LPE HD 241mm diff with 3:45 gears HD axles and d/s
ADM widened wheels with 315nitto nt05s Bogart 17 dragwheels CTS-V front 6 piston brakes
Pedders HD subframe/differential bushings alignment kit 27/32mm sways Supercar coilovers
683RWHP/650RWTQ
markssylver is offline   Reply With Quote
Old 12-27-2009, 04:25 AM   #2
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
For lubrication, you coat the inside where the ferrule go liberally, then install the ferrules, and wipe off the expert. I will check on the codes for you
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 12-27-2009, 10:34 AM   #3
g-townmach
I FARTED
g-townmach's Avatar
Drives: 2010 2SS/RS
Coat the bushings. Keeps them sqeak-free. That crap is hard as hell to wash off your hands though.
g-townmach is offline   Reply With Quote
Old 12-27-2009, 10:47 AM   #4
Rob@WretchedMS
Drives: His Wife Crazy
do not coat the bushings,
as Mike said, apply the lube to the inside of the busing where the metal ferrules go, then wipe off the extra, and install the bushings in the car.
If you have inserts they do not require lube, just install them and your good to go.
no lube goes between the bushing and the car, just the bushing and the ferrule.
Rob@WretchedMS is offline   Reply With Quote
Old 12-27-2009, 04:31 PM   #5
Info@PeddersUSA.com
Guys,
what Rob is saying is critical. You coat the outer bushing and you will have problems and no warranty! We can tell if there was lube on the outer bush. And if you by chance have coated the outer bushing, you need to remove them, clean them with denatured alchohol, and reinstall.
mike
dms
Old 12-27-2009, 05:39 PM   #6
markssylver
ok thanks for the info tomorrow i will take it all apart and wipe off the grease between the two halves of the bushes
also what alignment specs should i use for this settup i plan on drag racing and aggressive street driving
10.56@134mph
683RWHP/650RWTQ
Old 12-27-2009, 07:27 PM   #7
Rob@WretchedMS
grease between the two halves is ok, just not on the outside between the bushing and diff housing or what have you.
As for the alignment specs, two different types of alignment, you can't have both.
This is a good starting point, and will give you good street manners.
Front Toe- 0.0
Front Camber -1.0
Caster the more the better
Rear Toe 0.10
Rear Camber -1.0 (for drag racing you want 0.0 or even a little positive in the rear)
Old 12-27-2009, 10:04 PM   #8
markssylver
oh ok that saves me some time taking it back apart thanks for the alignment specs also
10.56@134mph
683RWHP/650RWTQ
Pedders December Dollar Days for the 2010 Camaro and Brand X Vehicles JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 85 07-26-2009 06:20 PM
SEMA, Pedders Conference, GS Camaro, New Products JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 25 12-01-2008 02:25 PM
Pedders partnering with GM Racing on Camaro suspension Info@PeddersUSA.com Wheels and Tires Talk Sponsored by The Tire Rack 6 09-30-2008 01:14 PM
