Old 12-27-2009, 04:03 PM   #1
walnuty
Drives: 2SS
HID questions, need help.
I have a 2SS RS model with the DRL and 4300K low beam HIDs. I want to change out the stock HID 4300K to 6000K low beam and add in a Non-RS HID fog light kit also in 6000K. Here are my 2 questions-
1. What is the bulb Model number for the stock RS OEM HID Low Beams? I would like to change the stock 4300K HIDs out for 6000Ks. Is this just a bulb replacement to go to the 6000K?
2. If I change out the stock RS DRL housing to the Non-RS Fog light housing can I just run the 5202 HID kit as a plug and play kit? Will this plug right into the RS DRL harness or will I have to "splice in" a new plug for the 5202 kit? Any pics of the RS harness and what plug I would need for the 5202 kit?
Thanks!
walnuty is offline   Reply With Quote
Old 12-28-2009, 05:23 PM   #2
walnuty
Drives: 2SS
Anyone? How about what are the stock HID low beam bulb number/model?
Old 12-29-2009, 01:15 AM   #3
SNV
SNV's Avatar
Drives: 2014 RRM 2ls
I think the bulb is a D1S. Found the info here http://www.camaro5.com/forums/showpo...7&postcount=20
Looks like it should just be a bulb swap.
2010 IBM 1LT out. 2013 BRM 1LS in. It's like having a blank canvas once again. Modding has started! Now on to a 2014......
SNV is offline   Reply With Quote
Old 12-29-2009, 05:04 AM   #4
Wileytrigger21
Wileytrigger21's Avatar
Drives: 2010 CGM 2LT / RS, Blk 1SS/RS
Remember that there are limits to what bulbs are legal.
Wileytrigger21 is offline   Reply With Quote
Old 01-04-2010, 04:29 PM   #5
walnuty
Drives: 2SS
Thanks guys!
Old 01-14-2010, 03:29 AM   #6
sales@spencershids.com
Drives: 2008 silverado, 2006 Impala
the fogs wiring should be the same as long as you get ones that are plug and play. some others do not slide into your factory wiring and recommend scotch locks. (do NOT use scotch locks!). if your going to be splicing at all be sure to use heat shrink.
sales@spencershids.com is offline   Reply With Quote
V6 Questions I'd Like Answered The_Blur Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 36 07-14-2012 11:44 AM
DIY - Install BFxenon HID Fog Light kit - RS and non-RS package BFxenon.com Camaro DIY & HOW-TO instructions & discussions 46 04-25-2011 12:04 PM
5202 (H16 ; 9009) Slim HID Kits !!! 09-Up Camaro Fog Light HID kits !!! HID_Guy Exterior Parts & Accessories 19 09-08-2009 02:07 AM
2010 Camaro Fog/DRL Light 5202 HID kits .... HID_Guy Exterior Parts & Accessories 1 09-07-2009 01:19 PM
HID temperature questions... Evotion 5th Gen Camaro SS LS LT General Discussions 1 10-19-2008 12:12 AM
