Old 12-28-2009, 12:06 PM   #1
My First Camaro!
My First Camaro!'s Avatar
Drives: 03Dakota4.7 1SSLS3RS
Question Radiator Help!
To all the guys who have re-installed the radiator; how do you reconnect the transmission (TR6060) heat exchanger that is housed inside the radiator housing to it's in/out lines? The exchanger "floats" inside the housing. It looks like there is either a special tool or trick that I don't have or can't figure out, or you have to completely disassemble the radiator housing to hold the heat exchanger in place to install the bottom two lines.
I'm also trying to find the fill plug for the transmission.
Simple one day project...
Thanks Guys!
My First Camaro! is offline   Reply With Quote
Old 01-09-2010, 09:47 PM   #2
Scourage
Syntax Error
Scourage's Avatar
Drives: 2010 Camaro 2SS/RS
I'm about to remove the radiator, I was going to disconnect the lines where the tubing meets up with the hard lines instead of at tthe radiator. It looks like the same type of connection. I'm assuming whatever you used to disconnect them, you would need to reconnect
I'm still trying to figure out what tool I need to disconnect them. Never had to mess with these newer style of fittings.
Scourage is offline   Reply With Quote
Old 01-09-2010, 10:11 PM   #3
Scourage
Syntax Error
Scourage's Avatar
Just found out that you pull the clip out, a pick works nicely. Then I was told to reassemble it, just put the clip back in and then slide the connector back together.
Old 09-27-2010, 08:20 PM   #4
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
How do you lift out the radiator, mine seems to be stuck to the condensor
Ovenmitt is offline   Reply With Quote
