Old 12-28-2009, 06:10 PM   #1
voyager77
voyager77's Avatar
Drives: 2000 T/A
Just want a round shift knob!
I've done a ton of searching but haven't found a round shift knob (black or white) with the shift pattern that mates to the stock shifter shaft. I don't want the hassle, expense, or rattle issues of going to a whole aftermarket shifter. I just want a knob!
I know it is a press fit and would even entertain cutting some threads with a die but it seems the Hurst knobs have a 3/8th thread and the stock is around 1/2 in. Seems like too much material to remove with a die.
Any thoughts/suggestions? Maybe an opportunity for some business!
Thanks
voyager77 is offline   Reply With Quote
Old 12-28-2009, 06:22 PM   #2
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
barton industries makes one-search for that on the forum
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 12-28-2009, 07:45 PM   #3
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
The one that comes with the Hurst short-shifter is white and supposedly connects to the stock shifter. I have one if you want it.
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 12-28-2009, 07:57 PM   #4
Barton Industries
Barton Industries's Avatar
This is the ONLY ball that will mount directly to the factory shifter with out going to a short throw shifter. No shift pattern though.
http://bartonindustries.com/vp/JS-Li...70017649456250
Barton Industries is offline   Reply With Quote
Old 04-12-2010, 07:34 PM   #5
dickholloway
dickholloway's Avatar
Drives: 2010 Camaro 2SS/RS
so ugly would get the original shift knob before this. how hard can it be to make a white ball with the shift pattern on it?
dickholloway is offline   Reply With Quote
Old 04-12-2010, 07:42 PM   #6
MGW
Drives: 2010 CAMARO SS
Thanks
we have them ill post pics tomorrow!!!!
you have 2 options... 1 is ready the other in about a week...
the first option makes the height no taller than stock and requires you to modify your stalk a bit...VERY easy takes about 5 minutes with a saw or dremel tool...
option 2 will go right on sotck but will sit too high in my opinion...i dont like it.
stay tuned they look GREAT!!!!
george
MGW is offline   Reply With Quote
Old 04-13-2010, 12:18 PM   #7
dickholloway
george
more details, please!!!
Old 04-13-2010, 04:39 PM   #8
MGW
ok here you go...
first option which to me is the only REAL way to go if you absolutely do not want to change out your shifter but want the classic retro look...
you have to modify your stock handle by basically chopping off the top key cut area of the shaft...you can do this quite quickly with either a dremel tool or metal saw...you dont have to be exact just get close to the end of the key cut as shown. then just make sure you deburr the shaft.
this allows the ball to sit basically the same height as stock...
i will be making one that is taller that you can put on the stock shifter with NO mods but i just think it will be so tall it will not shift well at all!!!
ok here are some pics and of course you can use ANY of our shift balls you like...
regards
george
Old 04-13-2010, 04:48 PM   #9
Tysen
Tysen's Avatar
Drives: 2011 RJT 2SS/RS M6
Can you do the shift knob with a blue SS logo?
"I'm a man who discovered the wheel, and built the Eiffel Tower out of metal and brawn! That's what kind of man I am." - Ron Burgundy
My build thread
Tysen is offline   Reply With Quote
Old 04-13-2010, 04:52 PM   #10
MGW
we have blue and hugger orange in stock now also...
george
Old 04-13-2010, 05:01 PM   #11
Tysen
Tysen's Avatar
Do you have a link? Can't locate them on your site.
My build thread
Old 04-13-2010, 05:03 PM   #12
wow, there are lots of them
Old 04-13-2010, 11:25 PM   #13
CBH
VETT 4 5
CBH's Avatar
Drives: Yellow 1SS/RS w/ Clutch
Wouldn't it be easier to just make knobs fit the stock slip-fit shaft ? Why is that so difficult ?
CBH is offline   Reply With Quote
Old 04-14-2010, 07:08 AM   #14
MGW
it would be easier yes and we are making one but as i stated it will sit too high since the shaft on the stock setup is 9/16 in diameter the knobs would have to be made above that shaft as they do not have that large of a bore...
we already offer 2 knobs that fit stock on our site...the race knob and gripper knob.
george
shift knob - removed and redone oldfart1941 Cosmetics and Lighting Modification Discussions 17 06-21-2011 03:15 PM
CHECK OUT MY NEW CUSTOM SHIFT KNOB !!!! BLACK10 Cosmetics and Lighting Modification Discussions 57 02-16-2011 03:37 PM
i ordered new ss shift knob, check it out mikeSS 5th Gen Camaro SS LS LT General Discussions 8 12-22-2009 01:25 AM
New Shift Knob martman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 10-30-2009 03:31 PM
Installing new Shift Knob question. Downwithopp Cosmetics and Lighting Modification Discussions 2 10-23-2009 10:41 PM
