HeadlightArmor
Old 12-28-2009, 06:13 PM   #1
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
Texas Speed & Performance 427 LS3 Rotating Assy
Hey guys like it says up top i was wondering how much work would it take to build a 427 out of the ls3. Im not to sure about alum blocks and how you would bore out the cylinder walls. Im kinda stuck between building a stroker motor or just cammin/bolt on's. So any input would be awesome
WICKEDSS is offline   Reply With Quote
Old 12-28-2009, 06:35 PM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
i don't think you can get a 427 out of a LS3, its a 416 or 418 CI but get the new 454 lsx that is how you will make power LSX7 heads All forged motor and 6 bolts heads.
Old 12-28-2009, 06:40 PM   #3
WeeZee
Drives: SuperSport's
^^^+1 i think u can go 416 but 427 is not an option. U can but a LS7 from any dealership though
2002 Chevy CamaroSS MN6
'08 Chevy TBSS AWD "DD"
Plans : 2013 CamaroSS 1LE
WeeZee is offline   Reply With Quote
Old 12-28-2009, 06:46 PM   #4
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
Oh i wonder why they have that on there web site.. Oh well guess its bolts on and a cam. Not sure if i would have the money for the LSX7 im sure its up there. Is there any other places that sell good cam's i see most of them are around $500.00 for the cam or i can get the kit for $800.00 im not worried about install i have the hook up with all my techs................This is what is on there web site
Item Detail
Name:
Texas Speed & Performance 427 LS3 Rotating Assy.
Item#:
25-TSP427LS3
Texas Speed & Performance rotating assemblies offer the best durability with the best pricing available! Our 427 cid LS3/L92 rotating assemblies come standard with a forged 4.100" stroke Callies Compstar crankshaft, Eagle H-Beam 6.125" connecting rods with ARP 8740 rod bolts, and your choice of Wiseco forged pistons that come standard with a steel top/napier second piston ring set! All of the Wiseco piston sets are built to accept any LS1, LS2, LS3, LS6, LS7, and L92 cylinder heads! You can choose from a variety of upgrades for the crankshaft, connecting rods, and pistons! Bearings are not included in the base price but can be added to your rotating assembly package. Give us a call, and we will be happy to spec out a rotating assembly that will match your needs!
Old 12-28-2009, 06:53 PM   #5
2SSRS@Gen5diy
If i do the numbers yes you can do a 427 on a LS3 but that is bore out the cylinder walls to 4.070 that is a lot if you don't re sleeve it, You are beter off going with a 418 and not bore out the cylinder walls.
Old 12-28-2009, 07:25 PM   #6
thedak
416ci - LS3 - 537/501
thedak's Avatar
Drives: 2006 Pontiac GTO
Send a message via AIM to thedak
This makes no sense.
A 418 has a 4.070 Bore.
A 416 uses a 4.065 Bore.
OP,
You can definately do a 427 LS3.
All you need is this.
Callies Compstar #APU317-CS Forged Crankshaft
thedak is offline   Reply With Quote
Old 12-28-2009, 09:25 PM   #7
MKS
Drives: SS
Sounds good but id rather get built a short block and just sell the stock one
MKS is offline   Reply With Quote
Old 12-28-2009, 09:35 PM   #8
OrangeChevyII
Drives: 2010 RS/SS2
You dont need a stroker motor to go fast or make power
2010 SS/RS SIM
First to run 11's (11.83)on a stock long block.
First to run 11's cam only
First to run 11's all motor
First to run 10's (10.96) and did it with a 100% bonestock long block and a power adder (nitrous)
First to run 10's (10.55) on motor in 2010 Camaro
First to break into the 5's (5.97) 1/8th mile
First to cut a 1.5X sixty foot
First to cut a 1.4x sixty foot
First to car to cut a 1.3x 60ft
OrangeChevyII is offline   Reply With Quote
Old 12-28-2009, 11:27 PM   #9
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
Proline makes a 427 out of a stock LS3 block as well. It is easily done.
Nationwide Turf
"artificial turf factory"
lawdogg149 is offline   Reply With Quote
Old 12-28-2009, 11:45 PM   #10
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
You can definitely get a 427. They are all crankshaft stroke. Also you should not boost one too much, as most builders will tell you the rings are too high on the piston. (but some others will do it all day long). Just voicing my opinion.
ZZcamaro is offline   Reply With Quote
Old 12-28-2009, 11:49 PM   #11
lawdogg149
lawdogg149's Avatar
Right on ZZ. Im going to be boosting the 418 though. Maybe 15 psi or so. Coming soon to a track....
Nationwide Turf
Old 12-28-2009, 11:51 PM   #12
ZZcamaro
The 418 is the way to go for boost, there is no doubt. I may be doing the sam ehere very soon. It all depends on my sponsorships...I cant afford to do it on my own right now, business has been down.
Old 12-28-2009, 11:54 PM   #13
lawdogg149
lawdogg149's Avatar
Im figuring the 418 and some head work with a good cam and my turbo is worth say 1000 hp.....
Nationwide Turf
Old 12-29-2009, 12:05 AM   #14
ZZcamaro
It could be....now get a drivetrain that can handle it, and stick it to the ground and you are good to go!!! LOL
I will nto be going that high in HP, but it will not be too far behind.
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
Performance upgrades to LS3 / SS option camaro9899 5th Gen Camaro SS LS LT General Discussions 65 08-02-2008 11:08 AM
Chevy High Performance - LS3 talk KILLER74Z28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 09-01-2007 03:04 PM
