SDTW Custom Wheels & Tires
Old 12-29-2009, 12:08 AM   #1
jrpxxii
jrpxxii's Avatar
Need pics of Pedders Bushing install
I have Pedders Drag bushing kit and need pics of someones car underneath who has done install so I have reference pics to look at during install. I have seen pics on here of some close ups of bushing installs but can't find them.
Old 12-29-2009, 01:23 PM   #2
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
Here is a link for the rear diff bushes on a G8 which are similar to the camaro.It is the second link in this post with the pics you need.
http://forums.peddersusa.com/showthread.php?t=757
Bruce@raymondsperformance is offline   Reply With Quote
Old 12-29-2009, 09:45 PM   #3
tbss1
More then meets the eye!
tbss1's Avatar
Drives: 2010 Camaro 2SS/RS 426 hp
[IMG][/IMG]
2010 2SS/RS, OBX l/t headers, with high flow cats, MBRP full 3" exhaust, modified air intake (CAI), Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidampr 25% upd, MGR shifter, VTC, and tune by Jannetty Racing. MRR M228 rims, phantom grill, vinyl wrapped hood and rear spoiler.
tbss1 is offline   Reply With Quote
Old 12-29-2009, 10:04 PM   #4
markssylver
markssylver's Avatar
Drives: 95 bbb impala ss
i just installed my pedders basic drag package this past sunday its pretty straight forward just make sure to only put the grease on the bushings were the ferrule slides into it and when cutting out the stock bushings be careful not to cut into your subbframe the front cradle bushings were very easy to do the rears were a little more time consuming because of the nipples that stick out of the frame i had to preinstall the ferule in the top bushing and pull down on the cradle to squeeze it in the bush will go in easy without the ferule but its such atight fit i couldnt get it in once the bush was on the car i wanted to get some pics but it was cold outside and i was in a rush to finish it i didnt get to the diff bushes yet or the alignment kit
10.56@134mph
ADM BUILT AND TUNED CGM 2SS RS
ADM/LPE 417 with ported heads/inconel vavles gt11 cam
ADM ported maggie with 14 rib rear 10 rib front pulleys
ADM fuel system and race air intake
ADM/LPE ZR1 clutch /pedalreturn spring
ADM billet aluminum valve covers /RPM LEVEL 6 TR6060
LPE HD 241mm diff with 3:45 gears HD axles and d/s
ADM widened wheels with 315nitto nt05s Bogart 17 dragwheels CTS-V front 6 piston brakes
Pedders HD subframe/differential bushings alignment kit 27/32mm sways Supercar coilovers
683RWHP/650RWTQ
markssylver is offline   Reply With Quote
Old 12-29-2009, 10:10 PM   #5
markssylver
i guess if you take it completely apart like the last poster its pretty easy i just put mine up on the lift removed the rear tires loosend my exhaust and lowered the cradle down by loosening the 4 cradle bolts and letting it hang down
10.56@134mph
683RWHP/650RWTQ
Old 12-29-2009, 10:35 PM   #6
SButler
SoCal C5 Family Member
Drives: 2LT/RS CGM
jrpxxii, I have the Xa Track eXtreme system installed on my car, I have everything except the sway bars. So PM me and I'll send you whatever pics you need.
SButler is offline   Reply With Quote
Old 12-29-2009, 11:20 PM   #7
jrpxxii
jrpxxii's Avatar
Thanks guys. This site is awesome as everyone is so helpful. I have coil springs and sway bars installed and am getting my front driveshaft safety loop and subframe connectors this week so I am going to go at all at once and this helps out alot.
Old 12-30-2009, 01:16 PM   #8
BMR Sales
BMR Sales's Avatar
Drives: Race Car
TBSS1, those are not pedder bushings, those are the BMR Fabrication rear cradle bushings and those are pics of when I installed them on our 2010 shop car. I have some other pics if you guys would like to look at them for reference, but they are all from out bushing line.
Thanks,
Kyle
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 12-30-2009, 01:34 PM   #9
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
There is no need to remove the cradle or subframe assembly to do the subframe or diff bushings.
Mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 12-31-2009, 05:06 AM   #10
tbss1
tbss1's Avatar
Thanks,
Kyle
sorry. How much are your bushings?
Old 12-31-2009, 09:34 AM   #11
BMR Sales
BMR Sales's Avatar
Drives: Race Car
I haven't got complete pricing available for them but we will just say they will be very affordable compared to some of the other options out there.
T.C. Davis
813-986-9302
Old 01-01-2010, 07:49 PM   #12
jrpxxii
jrpxxii's Avatar
Hey Kyle, would you please post pics of your car with all bushings installed? I would definitely had gone with you but they aren't available yet and I am impatient when it comes to new mods. I have bought everything you do have available so far and am waiting for the new goodies. Thanks.
Old 01-04-2010, 12:44 PM   #13
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Let me see if I can dig some up for you.
T.C. Davis
813-986-9302
Old 05-21-2012, 09:22 PM   #14
ActNup NY
ActNup NY's Avatar
Drives: 2011 1LT Black Camaro
Kyle can you post a picture with all the bushings installed. Im looking for a guide line to follow. Thxs ! For the rear and front would be helpful. But if only one is permitted I'd like to see the rear thxs !!!!!!
The DREAM is free... It's the HUSTLE that is sold seperately
ActNup NY is offline   Reply With Quote
Pics of our Coolingmist Methanol system install on street brawler package JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 73 11-29-2011 11:09 AM
My Camaro Pedders Coilovers (xa adjustable), w/ PICS E85LSX Suspension / Brakes / Chassis 139 10-29-2009 04:36 PM
Detroit Speed vs. Pedders usmcjlp Wheels and Tires Talk Sponsored by The Tire Rack 35 07-22-2009 01:14 AM
pics of ground effects install arabicame Camaro Photos | Spyshots | Video | Media Gallery 8 05-12-2009 04:16 AM
Zeta (Camaro/Commodore/G8) suspension details Gatecrasher Wheels and Tires Talk Sponsored by The Tire Rack 66 04-16-2009 02:11 PM
