Old 08-07-2008, 10:45 AM   #1
JEFF2010SSMANUAL
JEFF2010SSMANUAL
JEFF2010SSMANUAL's Avatar
Drives: IOM 2SS/RS LS3
Camaro SS LS3 gear ratios.
The Camaro SS LS3 manual has a final drive ratio of 3.45:1
The gear ratios are; 1st-3.01, 2nd-2.07, 3rd-1.43, 4th-1.00, 5th-0.84, 6th-0.57. It seams to have 2 overdrive gears-5th & 6th for fuel economy.
I just found out the Pontiac G8 GXP with the manual has the exact same trans and ratios, except the final drive rear is 3.70:1 which will make it launch off the line better.
The G8 GXP manual will weigh only 163# more then the Camaro SS LS3 manual.
Pontiac estimates the G8 GXP manual to do 0-60 in 4.7 seconds and the 1/4 mile in 13.0@108mph.
What will the Camaro SS LS3 manual do then with the higher rear 3.45:1 gear.
JEFF2010SSMANUAL is offline   Reply With Quote
Old 08-07-2008, 10:53 AM   #2
boxmonkeyracing
juggernaut
boxmonkeyracing's Avatar
Drives: VRSCF, 2011 SS vert
Send a message via AIM to boxmonkeyracing Send a message via Yahoo to boxmonkeyracing
a higher top speed? lol. we'll see once the camaro is actually being tested by car mags and such. . .then the same for the GXP
We do not want to use the Z28 moniker on a car that does not deserve this hallowed name.
boxmonkeyracing is offline   Reply With Quote
Old 08-07-2008, 11:16 AM   #3
greenrail
Comic Curmudgeon
greenrail's Avatar
Drives: 2010 Camaro 2SS-2010 VW CC Sport
Uh, I beg to differ, the higher rear gear the quicker your acceleration, but the lower your top end speed. If you have a lower rear gear ratio, your top end speed will be faster, but your acceleration will be slower.
That is one of the reasons, back in the '70's you saw very low rear gear ratios in cars to help meet federal mileage mandates.
greenrail is offline   Reply With Quote
Old 08-07-2008, 11:40 AM   #4
JEFF2010SSMANUAL
JEFF2010SSMANUAL
A 3.70:1 rear will take off the line faster then a 3.45:1 rear. The 3.45:1 rear will have a higher top speed but slower 0-60. FACT
Old 08-07-2008, 12:20 PM   #5
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Assuming the same power train. Right.
If you put more horse power behind the 3.45:1 rear end it could out perform the 3.70:1 rear end in all categories. Again, this is assuming you are using the same tranny and gear ratios on all gears?
yes?
Old 08-07-2008, 12:30 PM   #6
JEFF2010SSMANUAL
JEFF2010SSMANUAL
All the gear ratios in the Camaro SS LS3 manual 6 speed are identical to the Pontiac G8 GXP 6 speed manual, the diff is the final drive, Camaro is 3.45:1 and the G8 GXP is 3.70:1. But the Camaro has 422hp@5,000 rpm and the GXP has 402hp@6,000 rpm.
Old 08-07-2008, 12:47 PM   #7
boxmonkeyracing
juggernaut
um...that's what I said? why disagree with me when you said pretty much the same thing but more indepth?
Old 08-07-2008, 01:40 PM   #8
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
But how hard would it be to swap out the differential in the SS for the one in the GXP? Sure, you would lose some highway mileage, but would it be worth the boost in acceleration?
- Xanthos
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 08-07-2008, 01:44 PM   #9
boxmonkeyracing
juggernaut
- Xanthos
I know going from 3.23's to 4.10's are great for your 1320. . .lol.
Old 08-07-2008, 01:47 PM   #10
JEFF2010SSMANUAL
JEFF2010SSMANUAL
The 3.45 isn't bad but I would prefer a 3.70 rear more. Like 3.73:1 I had in my WS6 firebird.
Old 08-07-2008, 02:00 PM   #11
MajorTom
MajorTom's Avatar
Drives: 2005 Pontiac GTO
I wouldn't switch to the 3.70 because it won't do a ton for you. It probably won't be a value mod either because getting the gears or diff from the dealer or something will cost a lot for not much more performance.
And it might not even make that much of a difference. The Camaro is going to have 275s out back. With the right high performance tires have some decent grip.
We'll see which car is faster when they get here.
MajorTom is offline   Reply With Quote
Old 08-07-2008, 02:06 PM   #12
JEFF2010SSMANUAL
JEFF2010SSMANUAL
^^^^Why are the number estimates for the LS3 manual Camaro so much slower then the G8 GXP manual estimates 0-60 and the 1/4 1320 ???
Old 08-07-2008, 02:37 PM   #13
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I'm not sure there would be much of a benefit to go from the 3.45s to 3.70s. My brother and I had pretty much the same set-ups on our cars (Yank SS4000 converter for him and an SS3800 for me, same lids, tunes, and he actually had QTP LTs on his car (I haven't run since I've reinstalled mine) and with his 3.73s to my 3.23s, we've run pretty much the same 60's; in fact, the same. His best run on the OEM manifolds and Y-pipe wasn't really any better. Our cars both made within ten horsepower of each other, so that's about as far a comparison I could make, which is what leads me to the opinion above.
If you want a benefit, you'd have to get drastic and go with a 4-series gear probably, and deal with more noise, lower mileage, and more wear-and-tear.
I don't think the GXP is going to be a lot slower than an SS with the same trannies, so whichever is tested first, I think, will represent the other pretty closely, IMHO.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 08-07-2008, 03:54 PM   #14
greenrail
Comic Curmudgeon
greenrail's Avatar
Guess I kind of misread the tone of your message. Either way, I think we are all pretty much on the same page here.
Have a Great Camaro Day!
Camaro V6 vrs Cobalt SS??? 65bus 5th Gen Camaro SS LS LT General Discussions 76 05-10-2010 12:41 AM
Why do you think the Z28 is the higher tier? The_Blur Camaro ZL1 Forum - ZL1 Specific Topics 181 10-14-2009 09:08 PM
Automobilemag.com: 2010 Chevrolet Camaro - Q&A Scotsman 5th Gen Camaro SS LS LT General Discussions 23 10-12-2008 01:13 AM
Camaro SS and Convertible Pics - Where Are They?! carsismeZ06 Camaro Photos | Spyshots | Video | Media Gallery 8 07-23-2008 10:21 AM
