Old 12-31-2009, 01:37 PM   #1
Jekyll-N-Hyde
I put the FU back in FUN
Jekyll-N-Hyde's Avatar
Drives: 1969 SS 396 , 2010 Camaro SS
Factory Alarm in 2010 Camaro SS rate it ?
OK guys before I know it my car will be here Sad to say my luck over the past 24 hours has been bad with theft so it leaves me wondering since I got a escort 9500ix radar detector for christmas. Is the Factory Alarm good enough to use or will I be better off buying a different/aftermarket one?
I know my car already has automatic start and probably wont have shock sensor since most factory alarms dont however when its set and you open the doors will it go off ?
Any help would be Great if you know anything about this alarm
Thanks
Jekyll-N-Hyde is offline   Reply With Quote
Old 01-01-2010, 02:49 AM   #2
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
I think it will be some time before these cars are "stealable", being able to simply break in is another method.
HeavyD is offline   Reply With Quote
Old 01-01-2010, 03:24 AM   #3
Coldpants
Nerdy one
Coldpants's Avatar
Drives: #000000 & #FF8000 2010 Camaro
I would rate the factory alarm D- no shock sensor, no tilt sensor, no glass break sensor. I got a new alarm with that and more. If your in a car with a car theft problem upgrade as soon as u can.
Dave McFly:
Modern cars are awash in “It-goes-to-11” ergonomics. No one asked for it. It’s just in your car because—like black mold or a carjacker with herpes—it can be.
SHORT FAT ROUND NINJA
Coldpants is offline   Reply With Quote
Old 01-01-2010, 01:54 PM   #4
SS Drifter
Drives: 2010 2SS/RS L99
Factory alarm score - I (for incomplete)
I tested the alarm by rolling down a window, locking doors with remote and then opening the driver door with the inside handle. The first time it did nothing, the alarm had not armed. To arm, the remote lock button must be pressed with the door open or pressed twice with door closed. The same test the second time around sounded the alarm with short-soft pulses of the horn. I would not call this attention getting.
The factory remote start works great. I've used it to 200 feet with a clear view of the car, much less if operating through buildings. I doubt that an aftermarket remote start will work any better.
As disappointing as the factory alarm is, I will not opt for an aftermarket alarm until someone makes a kit that doesn't require butchery of the wiring harnesses. I don't like the crimp lock wire taps they damage wire strands. Unfortately, this seems to be the normal method of installation.
SS Drifter is offline   Reply With Quote
Old 01-03-2010, 04:46 AM   #5
BlackZCamaro
No 3rd Gen Lovin.
BlackZCamaro's Avatar
Drives: Seven and counting......
Three aftermarket things are necessary for safe keeping of a 5th gen.
1. Garage (This is a must. No exceptions.)
2. Take your iPod/Zune/TomTom/Garmin/Passport/etc. OUT of the car. It's not that hard, and you may be able to stash it somewhere out of sight in the car. Out of sight = Out of mind. Maybe in your pocket/purse, whatever is necessary.
3. Your common sense. Alarm systems are for personal attackers/assault/passive ATS. Seriously, why do you think you get a panic button on the FOB? It's not to scare the guy who's under the dash trying to hotwire the car, its for everyone else to see you are in danger.
Peace of mind starts with proactive safety.
1967 SS 396/375, 1969 327/350, 1969 427/450, 1970 350/360 LT1, 1971 LT1 FI/?, 2000 383 FI Z28, 2002 1SC Z28.
BlackZCamaro is offline   Reply With Quote
Old 01-03-2010, 06:52 AM   #6
TheLazyBrownDog
Drives: 98 S10, 97 4Runner
There are much better alarms out there, I have a CompuStar on my 4Runner with a pager that has a range of a little over a mile. Factory alarms are about useless unless YOU are in range to hear it, as most people will ignore alarms anyway thanks to improperly set shock sensors (think the boy who cried wolf). If you are worried about it I would reccomend one that can notify you.
TheLazyBrownDog is offline   Reply With Quote
Old 01-04-2010, 02:16 PM   #7
Kendell347
Doc
Kendell347's Avatar
Drives: BLACKOUT & Fifty
Unfortunately, I don't have my camaro yet, but the camaro should come with just a keyless entry, I would not consider keyless entry an alarm. Granted a keyless entry may provide a horn honk if something happens, but nothing to the extent of a 6 tone siren or full alarm system. Usually dealers try to sell an alarm to you during the checkout / final process. Thats how they make $$$$.
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 128Mods: CAI CAI, Emblempros Dash Plaque, R/C Lic. Plate, Fbodfathers signature, AAC SMD SML, AAC P13 LED DRL, TF center console, Full dash ABL, Noweed Exhaust Diverters, Heritage Grille, Door Projectors, 20watt LED reverse lights with strobe features, S.S. black billet grille with air scoops, custom designed engine cover, custom designed "BLACKOUT" cross drilled / slotted rotors, Borla S-type exhaust, Elite Engineering oil catch can, Nitto Invo Tires WWW. NY5THGEN.COM
Kendell347 is offline   Reply With Quote
Old 01-04-2010, 02:53 PM   #8
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
I agree with the low grades & Incomplete. I don't want my Baby broken into at all, or towed away...the alarm will do nothing in these cases. Mine is well protected, but, anything can be stolen...Wish I had her in a garage :(
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 01-04-2010, 07:51 PM   #9
viper1cobra
Member Club Elite #131
viper1cobra's Avatar
Drives: 2017 50th Anniversary H50 2SS
All of the comments are correct. However there is stilla layer of defense that is embedded in the key itself. The fact that it is a laser cut key, and unique to only your car plus a proximity switch that is embedded in the remote.
Small consolation if it is towed away, but it is another layer of defense.
viper1cobra is offline   Reply With Quote
Old 01-05-2010, 06:04 PM   #10
dr1ven
Drives: '10 CGM
Any alarm recommendations ?
2SS/RS CGM. Black Int. Black Stripes. Grnd Effects.
1100: 09/1/09
3800: 12/18/09
Picked Up at the Dealership: 1/4/10
dr1ven is offline   Reply With Quote
Old 01-05-2010, 06:11 PM   #11
Our1stCamaro
Our1stCamaro's Avatar
Drives: VR 2ssRs
Just have onstar on speed dial if they take the car.
Our1stCamaro is offline   Reply With Quote
Old 01-06-2010, 12:37 AM   #12
SS Drifter
Removed my post cocktail post. It was in bad taste.
Chevrolet Camaro SS to pace 2010 Indianapolis 500 ljustin293 5th Gen Camaro SS LS LT General Discussions 123 09-07-2011 12:07 PM
