Caryle Racing
Old 12-31-2009, 06:43 PM   #1
MadMav
Drives: 2010 SS/RS M6
Few Barton short shifter install tips....
Put mine in today. It was a bitch because the shifter wouldn't go into the factory housing, and it kept getting stuck/hung up on the first black o-ring no matter how hard I pushed. Called the guys up and they said go get some longer bolts to help pull the unit into the housing. I did this and after a bit, and two seperate lengths of bolts, got it in and seated properly.
To get the boot back on, lower the tranny as far as possible and start at the front of the boot and work towards the rear to get it on. Once I did this, it went right on.
The unit is nice. Quality parts. And it works great. I have no noise as of yet. And hope none show up. I did use the new Royal Purple synthec lube for install. Seems to work very well, and can be re-lubed from inside the car, and not underneath.
Mav
P.S. The bolts I had to buy to intall it were 6mm X 1.0 in 40mm and 25mm lengths.
SS/RS M6, SIM, CGM stripes, Barton S/T, BMR trailing arms, ADM Race intake(no scoop), Texas Speed 1 7/8" headers and full 3" exhaust, RMCR custom tune.
MadMav is offline   Reply With Quote
Old 12-31-2009, 06:55 PM   #2
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
the key is to get that boot back on. its a pain but its a must.
SSTony is offline   Reply With Quote
Old 12-31-2009, 08:55 PM   #3
sykb47l
sykb47l's Avatar
Drives: 73' VW Bug
The rubber boot has pull tabs on the corners. Simply push up with one hand and pull the tabs with the other and it goes right on.
sykb47l is offline   Reply With Quote
Old 12-31-2009, 09:59 PM   #4
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
It is so worth a little struggle !
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
Barton Short Throw Shifter (Post-Installation) rauhaus camaro V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 12-26-2009 03:39 PM
Hurst short throw shifter 4 sale (used about 500 miles) rcracer78 Transmission / Driveline 8 12-09-2009 06:35 PM
Short Throw Hurst Shifter Not Available Matster 5th Gen Camaro SS LS LT General Discussions 51 11-09-2009 11:03 AM
Short Throw Shifter Constrained?? josh1147 Camaro Price | Ordering | Tracking | Dealers Discussions 75 02-19-2009 01:51 PM
