Old 08-08-2008, 01:54 PM   #1
Xanthos
Almost-Original Postwhore
Xanthos's Avatar
Drives: Stick
Tire Question
Anybody know anything about the Nitto Invo? I was browsing for which tires I'd like to get for my camaro, and this one caught my eye. Anybody have experience with it? Pros? Cons?
- Xanthos
Xanthos is offline   Reply With Quote
Old 08-08-2008, 02:23 PM   #2
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
http://www.thetruthaboutcars.com/nit...e-tire-review/
This was pretty close to what my friends think of them.
Old 08-08-2008, 02:44 PM   #3
Xanthos
Xanthos's Avatar
Drives: Stick
How long did the treads last for your friends? Or are they on the first set still? Thats the only part I'm concerned about - having to replace them often.
- Xanthos
Old 08-11-2008, 02:05 PM   #4
JEFF2010SSMANUAL
JEFF2010SSMANUAL
JEFF2010SSMANUAL's Avatar
Drives: IOM 2SS/RS LS3
I think I read somewhere that the SS will come with 20" Pirelli tires but I can't find where I read that???? What model Pirelli????
JEFF2010SSMANUAL is offline   Reply With Quote
Old 08-11-2008, 02:16 PM   #5
BowtieGuy
Enlightened
BowtieGuy's Avatar
Drives: Nothing Currently
You read it here http://www.camaro5.com/forums/images/camarospecs.pdf
The new Camaro is coming with pretty bad a Pirelli's (even on the V6) I can't imagine why you'd change them any time soon.
If you believe it is your right to speak freely no matter the content, relevance, or intelligence of statement, then it is my duty to the powers that be to set you straight.
People have to talk about something just to keep their voice boxes in working order. So they'll have good voice boxes in case there's ever anything really meaningful to say.
Kurt Vonnegut
BowtieGuy is offline   Reply With Quote
Old 08-11-2008, 02:19 PM   #6
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
You might have read it in one of web chats done on the 22nd. Doug Houlihan did not confirm P-Zero tires, just that Pirelli was the supplier for the 20's.
ws6w72:
i noticed the red car shown in the press photos has Pirelli P-Zero P245/45ZR20 tires- is Pirelli the chosen tire supplier?
DougHoulihan:
Yes, Perelli is the supplier for the 20s
rolnslo is offline   Reply With Quote
Old 08-11-2008, 03:13 PM   #7
Xanthos
Xanthos's Avatar
Drives: Stick
The P Zero has a lower treadwear rating and a lower traction rating than the Invo and cost almost twice as much when it comes time to replace them. And unless I'm mistaken, they can't be rotated side to side - only front to back. Which would seriously hamper the ability to rotate my tires.
- Xanthos
P.S. - Honestly speaking, the traction rating is the most important part. It rains a LOT here, and I really need the best wet weather tires I can get, seeing how this will be my daily driver. I also plan on swapping the 9 inch rears when I find somebody willing to trade me for their 8 inch fronts. Easier to rotate all around, and the slightly thinner tire will cut through snow more easily.
Old 08-11-2008, 03:22 PM   #8
a12ozbottle
Drives: 2006 GMC Yukon
You can't rotate them front to back either, because the backs are a different size than the fronts.
a12ozbottle is offline   Reply With Quote
Old 08-11-2008, 03:40 PM   #9
Txturbo
Keeper of the Faith
Txturbo's Avatar
Drives: 2001 Z28 Agressively
Why would you want to rotate them? I DON'T want all four wearing out at the same time!
2010 Camaro SS R6P
2001 Camaro Z28
1969 Camaro SS clone
Txturbo is offline   Reply With Quote
Old 08-11-2008, 06:45 PM   #10
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
generally speakin, you want to rotate your tires, but its getting more and more common for people to get uni-directional tires. if i wasnt running a staggared stance (17s/18s) id rotate mine front to back, but i run thru rears more often than fronts... burnouts and such ya know
I piss excellence
and fart awesomeness
Old 08-11-2008, 07:20 PM   #11
Xanthos
Xanthos's Avatar
Drives: Stick
If you'd read my post, you'd have seen that I plan on replacing the 9 inch wheels on the back with 8 inchers. And the Invo's can be rotated side to side, as well as back to front. The point of rotating them is not so they all wear out at once - its so they take longer to wear out. You use them till they get close to wearing out, then replace them, and still get the extra life out of them. You just have to make sure you check the tread depth every time you rotate them, which I was going to do every 3500 miles when I changed the oil.
- Xanthos
Old 08-12-2008, 03:49 PM   #12
a12ozbottle
Wasn't really commenting on your situation. I was just adding that if it is true that they cannot be rotated side to side, then they cannot be rotated at all because of the size difference on a stock setup. Like most people I am also aware of the benefits of rotating tires.
Old 08-12-2008, 05:41 PM   #13
Beelzebubba
cheap plastic member
Beelzebubba's Avatar
Drives: Mazda6s
In a nutshell,
Nittos. Stick good. Wear fast.
IMHO They stuck better and wore longer than my Bridgestone Potenza RE050s
Beelzebubba is offline   Reply With Quote
Old 08-13-2008, 12:48 AM   #14
stovt001
stovt001's Avatar
Drives: 2006 Cobalt, 2004 Taurus wagon
I have Nitto Neo-Gens on my Cobalt. So far they're wearing better than I expected, though I'm not pushing them that hard. When I do push them, they reward. The many canyon roads near my apartment and freeway cloverleaf ramps are a LOT of fun!
When I get my Camaro I plan to either be carpooling/vanpooling like I am now, or live a lot closer to work, so wear and rotation aren't especially important to me. I have not heard good things about run-flats, and that worries me more.
"It's kind of fun to do the impossible" - Walt Disney
There's a great big beautiful tomorrow
shining at the end of every day
Just a dream away
stovt001 is offline   Reply With Quote
Tire Reviews Stroker Wheels and Tires Talk Sponsored by The Tire Rack 12 08-22-2012 05:02 PM
Stripe Question 405vette Cosmetics and Lighting Modification Discussions 57 08-03-2008 08:38 PM
KnightRider is back, AND HE'S A MUSTANG! LSxcellent General Automotive + Other Cars Discussion 139 05-15-2008 08:49 PM
Noob Camaro Question goose7919 5th Gen Camaro SS LS LT General Discussions 13 09-23-2007 09:26 PM
Car Law- i.e. tire size, exhaust noise Kyle.Gilmour General Automotive + Other Cars Discussion 11 08-06-2007 12:09 PM
