ModBargains
Camaro DIY & HOW-TO instructions & discussions All DIY projects & discussions
Old 01-02-2010, 11:48 AM   #1
jbsrace1
jbsrace1's Avatar
Drives: 2010 2ss
Glove box light
I use my glove box allot and wanted a light in it.
So when I got a Oracle LED light kit for Christmas & only changed the dome light I had a extra cool LED light. So I decided to do a glove box light mod.
Other than the a little wire and a light bulb you only need 2 parts.
A switch and a light socket. I used a door jam switch for a 94 Chevrolet truck & a marker light socket. Less then $10. @ Advance auto parts.
The part numbers are s1067 for the switch and 8581608598 for the socket.
My camera is crappy so forgive the bad pictures.
The switch has 3 terminals but you only need the outside 2. ignore the one in the middle. You may can order a pigtail or get one out of a salvage yard but I just used 2 small spade connectors and some epoxy to hold them in the switch.
Hot melt glue would also work.
Wires for the switch
Wires installed in switch
Then I removed the glove box door and drilled a hole for the switch. (A 5/8 drill bit was just a hair to small. I used a box cutter to trim just a little more for the switch to fit).
Above the glove box is a plastic cover that is held in by 5 torx head screws. 3 in the front along the opening of the glove box and one on each side close to the rear. At the rear on each side it has fittings that snap into place. After you remove the screws just give it a little pull and it will pop lose.
Again with the 5/8 drill bit I drilled a hole for the light socket.
The plastic is real soft so I warmed it up a little with a heat gun and pushed the light socket in. Once it cooled it locked in real tight.
Here it is with the LED bulb installed
I was going to run a separate wire to the fuse panel but after looking around there is a constant 12 volt power wire directly above the glove box. In the harness that runs above the glove box you can see 2 large red wires. One has a black stripe and is larger the other is just red. I spliced into the smaller one without the stripe.
I am running it straight to the light socket so I am not really worried about it shorting out so I did not put a fuse on it. (A fuse would not hurt)
I ran one wire from the switch to the light socket and the other I ran up and over the glove box with the factory harness to a ground on the other side.
This is basically how I have it wired.
Here it is without the glove box door
Put the glove box door back on and it is good to go
You have to lay in the floor and look up to see the bulb but it lights up the glove box Great and is up high enough I don't believe anything will ever contact it.
Here you go.
It is not that hard and makes it real nice finding stuff in the glove box at night
Last edited by jbsrace1; 03-06-2010 at 04:19 PM. Reason: Corrected switch part number
jbsrace1 is offline   Reply With Quote
Old 01-02-2010, 01:54 PM   #2
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Nice work, I believe there were some other members lamenting about the lack of a glove box light a while back. This will help.
The Few, The Proud, The Aqua Blue Metallics 709 of 3903 New England Camaro5 . My Camaro Journal
Heritage Grill, Cold Air Inductions Intake, Elite Engineering Catch Can, BMR 1" Lowering Springs, Sway Bars and End Links, Clear Image Jet Hot Ceramic Coated headers and High Flow Cats, Hurst Billet 2 Shifter, LSR Billet Strut Washers, DynoMax Axle Back Exhaust, JANNETTY MAGIC!
Old 01-02-2010, 02:20 PM   #3
FRKNlo
FRKNlo's Avatar
Drives: VStar 1100 Classic, 2010 CGM 2SS/RS
Very good DIY instructions!
FRKNlo is offline   Reply With Quote
Old 01-02-2010, 03:41 PM   #4
infamous00827
Heartless-1
infamous00827's Avatar
Drives: 2008 nissan altima coupe
awesome work, i need a light in there also
"When A Man Gains The World, What Good Is His Profit If He Loses His Soul?"
infamous00827 is offline   Reply With Quote
Old 01-03-2010, 06:23 PM   #5
BumbleBeeSS2009
BumbleBeeSS2009's Avatar
Drives: Rally Yellow 2SS/RS
any pics at night so we can see it in action?
#52325 Delivered 11/07/2009
BumbleBeeSS2009 is offline   Reply With Quote
Old 01-03-2010, 08:42 PM   #6
jbsrace1
jbsrace1's Avatar
Drives: 2010 2ss
Here you go.
Old 01-03-2010, 08:54 PM   #7
Superfly1
Superfly1's Avatar
Drives: 2010 Camaro 2LT #2197
Very helpful mod, I do think this will be going into my Camaro
CAI intake | Flowmaster AT Exhaust | Trifecta Tune | Konig Airstrike Wheels | Drake Shifter
Custom Sub Box | Footwell Lighting | Custom Engine Cover, Fuse Cover & Underhood Bowtie
Superfly1 is offline   Reply With Quote
Old 01-03-2010, 08:55 PM   #8
FRKNlo
FRKNlo's Avatar
Wow! Very bright.
Old 01-03-2010, 09:21 PM   #9
Waco
Layla
Waco's Avatar
Drives: '10 2SS/RS, LS3, CGM/IO
great mod, love it. so you don't know what the power source is for the wire you tapped into? Or where it leads?
Waco is offline   Reply With Quote
Old 01-03-2010, 09:44 PM   #10
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
nice... good job.
Magnaflow Cat back / ROTO-FAB Intake / Whipple Kit / RDP Tune.
580hp - 650Tq
franknbeans is offline   Reply With Quote
Old 01-03-2010, 11:21 PM   #11
ssrsheaven
ssrsheaven's Avatar
Drives: 92 firebird,2010 camaro
MY CONCERN WAS NO LIGHT IN THE ENGINE AREA.WAS SHOWING THE CAR TO FRIENDS AT NIGHT AND THEY WANTED TO SEE THE ENGINE,OPENED THE HOOD AND NO LIGHT.WISH THEY COULD HAVE PUT ONE THERE.
ssrsheaven is offline   Reply With Quote
Old 01-04-2010, 06:28 AM   #12
jbsrace1
jbsrace1's Avatar
Drives: 2010 2ss
I believe it to be the power feed for the blower speed control but it was getting cold and I did not take the time to trace it out. The LED pulls such a small load I wasn't worried about it. If I get some time this afternoon I will try and see exactly what it feeds.
Old 01-04-2010, 06:37 AM   #13
Mark A Collier Sr
Retired Army, 101st ABN
Mark A Collier Sr's Avatar
Drives: 2 SS/RS w/sunroof
I am sold! I like it and will add it to my "To Do" list! Thanks!
"BABY" is a Summit White, 2SS/RS, My Tribute to the 13 years I served in the 101st Airborne Division!!!
ORDERED: 18 JUL 09 #NMMS88,
BORN ON 4 NOV 09 at 12:26pm VIN:63460~ HOME on 18 NOV 09!
"101BABY"
Mark A Collier Sr is offline   Reply With Quote
Old 01-04-2010, 06:46 AM   #14
jbsrace1
jbsrace1's Avatar
Drives: 2010 2ss
There are all kinds of under hood light kits around. Or you can go to any salvage yard and pick about any 80 or 90's chevrolet truck and get one that only requires running a power wire to it.
Old 01-04-2010, 09:28 AM   #15
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
Nice mod, well done, great instructions!
HeavyD is offline   Reply With Quote
Old 01-13-2010, 02:15 PM   #16
CamaroSpike23
The Jalopy Jedi
CamaroSpike23's Avatar
Send a message via MSN to CamaroSpike23 Send a message via Yahoo to CamaroSpike23
nice writeup
Originally Posted by Bulldogwinters View Post
Read that link that Spike posted, it'll tell you everything you need to know.
I piss excellence
and fart awesomeness
Old 03-06-2010, 03:45 PM   #17
Don O
Camaro and Vettehead
Don O's Avatar
Drives: 2SS/RS IOM L99 69 427/400 Vette
Good write up. Minor correction, the switch part number is S1067 (an "S" not a 5). I'm going to add one too using a blue LED.
http://shop.advanceautoparts.com/web...archTerm=s1067
I also found one on eBay too.
Don O
Nothing sucks more than that moment during an argument when you realize you're wrong.
Don O is offline   Reply With Quote
Old 03-06-2010, 04:20 PM   #18
jbsrace1
jbsrace1's Avatar
Drives: 2010 2ss
Don O
Thanks Don O
I corrected the part number in the first post
Old 03-09-2010, 02:46 AM   #19
FRKNlo
FRKNlo's Avatar
Thanks for the tutorial!
Old 03-18-2010, 12:54 PM   #20
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: THRSS #2 / CGM#1
Heck yeah...I have the extra bulb as well. I will run and get the two parts, a fuse, and give it a go! Thanks!
The build of THRSS #2
Old 03-18-2010, 07:52 PM   #21
TxPlates
TxPlates's Avatar
Drives: 2010 2SS/RS - TE
Nice job!
TxPlates is offline   Reply With Quote
Old 03-18-2010, 08:28 PM   #22
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
If you don't want to drill the glove box, look on the left hand side. There is a hole in there already. You can fit a 5mm LED holder in there
skuttduck is offline   Reply With Quote
Old 03-20-2010, 08:42 PM   #23
FAF
Member
FAF's Avatar
Drives: 2010 Camaro, 2008 Tundra
good Idea thanks
[/SIGPIC]2010 Camaro 2LT / RS - IMO, CF5, M6
1100 1/29/09, 6000 6/22/09 ; sunroof; Airaid CAI; Corsa Performance CAT Back; Hurst Short-throw shifter; LoJack; Dash ABL Mod; Subthump; AACStyle LEDs; calipers red covers;
FAF is offline   Reply With Quote
Old 03-20-2010, 08:45 PM   #24
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
Seems like a lot of work for something GM should have done in the 1st place
Fishdadddy is offline   Reply With Quote
Old 03-21-2010, 07:32 PM   #25
jnd14401
jnd14401's Avatar
Drives: black automatic 1ss #182,771
hey jbsrace1 thanks for the write just finished mine as well with your help and the interior dome light and footwell lighting all in blue.
jnd14401 is offline   Reply With Quote
DIY - Footwell LED lighting In tune with Dome Light markmass Camaro DIY & HOW-TO instructions & discussions 52 09-03-2010 08:00 PM
NO fog light switch..... strobi Exterior Parts & Accessories 16 12-16-2009 05:27 PM
no light in the glove box Chris-10 5th Gen Camaro SS LS LT General Discussions 43 11-22-2009 01:24 PM
Anyone have their engine light come on and stay on...Advice please (Pic) DCJ Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 38 09-07-2009 05:26 PM
New 4.5 L Duramax Diesel V8 for light duty pickups Scotsman General Automotive + Other Cars Discussion 8 12-01-2008 06:21 PM
