Old 01-02-2010, 02:33 PM   #1
jrpxxii
jrpxxii's Avatar
Bushing install help needed
I am installing the Pedders Drag Kit option 2 and can't figure how to get the 4 large stock cradle bushings out. Any advice on how these come out would be great. I have the cradle lowered but I have tried prying them out but they seem to be locked in. Thanks.
Old 01-02-2010, 04:09 PM   #2
Mr Twisty
Mr Twisty's Avatar
http://forums.peddersusa.com/showthread.php?t=626
That's on G8, should be close. They use a special tool, that basically screws the old bushing out.
Try googling G8 cradle bushings, maybe GTO as well.
Cut them out if you can, you won't be re-using them.
Just don't damage the cradle.
-- Benjamin Franklin
Old 01-03-2010, 12:20 PM   #3
Mr Twisty
Mr Twisty's Avatar
..... Update on install?
Old 01-03-2010, 02:31 PM   #4
600hp-lpe
Drives: 2010
we used an air chisel on mine to swap them.
We cut out the rubber center, and then slit the plastic outer sleeve.
Be careful not to damage the subframe.
They were a bitch to remove.
You aren't expecting them to just fall out, are you? LOL
600hp-lpe is offline   Reply With Quote
Old 01-03-2010, 03:35 PM   #5
markssylver
markssylver's Avatar
Drives: 95 bbb impala ss
I used a sawzall to cut a piece out then used air chisel to nock them out once through the rubber go slow not to cut into the metal of the subframe
10.56@134mph
ADM BUILT AND TUNED CGM 2SS RS
ADM/LPE 417 with ported heads/inconel vavles gt11 cam
ADM ported maggie with 14 rib rear 10 rib front pulleys
ADM fuel system and race air intake
ADM/LPE ZR1 clutch /pedalreturn spring
ADM billet aluminum valve covers /RPM LEVEL 6 TR6060
LPE HD 241mm diff with 3:45 gears HD axles and d/s
ADM widened wheels with 315nitto nt05s Bogart 17 dragwheels CTS-V front 6 piston brakes
Pedders HD subframe/differential bushings alignment kit 27/32mm sways Supercar coilovers
683RWHP/650RWTQ
markssylver is offline   Reply With Quote
Old 01-03-2010, 09:25 PM   #6
jrpxxii
jrpxxii's Avatar
I am going with the cutting and chiseling route since normal hand tools are too much effort.
Old 01-03-2010, 09:38 PM   #7
full of days
full of days's Avatar
Drives: Camaro GT
I've heard of guys using torches to heat the stock bushings and then whittle them out out as they wont be reused...
Post Tenebras Lux
full of days is offline   Reply With Quote
Old 01-03-2010, 10:36 PM   #8
markssylver
when cutting the stock bushing s i cut out a pie slice towards me trying not to cut into the metal then used the air chisel to finish breaking/knock out the outer sleeve also when putting in the rear bushes it is easier to preinstall the metal ferule into the bush out of the car put it in so that half of it sticks out the bottom and half out the top its a tight fit getting it in there past the nipple that sticks down from the frame i wasted about an hour trying to put the ferule in the bush once on the car and its imposible to do
10.56@134mph
683RWHP/650RWTQ
Cold Weather Blues Prevention Magnacharger Install Specials at Livernois Motorsports! Andy@Livernois Forced Induction 4 12-09-2009 06:53 AM
Rally Stripes install? HannoverFist USA - Northwest / Pacific Northwest 14 11-18-2009 10:47 PM
Cold Weather Blues Prevention Camshaft Install Specials at Livernois Motorsports! Andy@Livernois V8 Bolt-Ons & Tunes 0 11-10-2009 05:41 PM
****SALE ON STS and VORTEC INSTALLED ONLY***FREE INSTALL FOR the FRIST CAMARO!!! east TX Muscle cars Forced Induction 2 10-29-2009 04:57 PM
DIY: Here it is Dashboard ambient lighting ABL Tecca Camaro DIY & HOW-TO instructions & discussions 356 09-03-2009 10:46 AM
