Caryle Racing
Old 01-02-2010, 03:45 PM   #1
Maclain
Drives: 2LT
Servicing besides oil / tranny / differential?
Hi folks,
I drive a 2LT, which comes with the dino oil from the factory.
At 500 mi, changed the engine oil (kept dino oil in it), changed the transmission fluid, and changed the rear differential fluid.
At 1500 mi, changed the oil again, put in Mobil1 5w30.
Now at 3200 mi, about to change the oil again with Mobil1.
I've broken the engine in under load (per Darin, Motoman, etc).
My question is this:
What do I need to look at now, at 3200 miles, besides the fluids? The owner's manual says nothing about other service concerns, i.e. tightening exhaust bolts, suspension inspection / tightening etc, lubing the chassis (someone said the chassis on this does not need lubing due to sealed bearings ?), or any other things that need to be done.
What else needs maintenance?
Thanks much,
Mac
Maclain is offline   Reply With Quote
Old 01-04-2010, 12:21 PM   #2
d69chris
Florida C5
d69chris's Avatar
Drives: 2010 Camaro 2SS Vortech L99 IOM
Send a message via Yahoo to d69chris
What are you running in the tranny and diff in the way of fluids???
What qty did each take?
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
d69chris is offline   Reply With Quote
Old 01-05-2010, 01:24 AM   #3
Maclain
Drives: 2LT
I took it to the dealership and they changed the oil / tranny / diff.
Mechanic said he used the stock fluids for tranny and diff.
Old 01-05-2010, 09:50 AM   #4
Nxtr
Nxtr's Avatar
Drives: 2010 Camaro SS/RS
why don't you just follow the schedule as per the owners manual? I am sure there was a whole lot of testing done that results in the schedule that is provided...
Just my thoughts...
V/R,
Nick
2SS/RS, LS3, 6M, SIM on IO... Mods, none yet...
Nxtr is offline   Reply With Quote
Old 01-05-2010, 09:54 AM   #5
ssump29
LOL at most people here.
ssump29's Avatar
Drives: 2005 GTO,2006 M6, 2007 300 Touring
Why are you changing all those fluids so early on, man at this point you are just throwing money away. To answer your question, do nothing you are just being a little over-protective of this car I mean really changing transmission fluid and rear dif at 1500 miles equals crazy.
Number 5952. oh yeahhhhhhh
ssump29 is offline   Reply With Quote
Old 01-05-2010, 10:04 AM   #6
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
Your dealer was happy to see you coming. Don't worry about it, drive it and enjoy it.
oh, and make sure you flush out your washer fluid...might be dirty. I'd replace it with synthetic.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 01-05-2010, 04:14 PM   #7
ffrcobra_65
peace of mind (or paranoia for some) can get expensive for sure.
IMO, I think you are good to go, just follow the manufacturer's recommended schedule from this point based on driving conditions. Good luck.
Old 01-05-2010, 04:47 PM   #8
adub4185
Drives: 2010 Black 2SS RS, 1995 BMW M3
Send a message via AIM to adub4185
i dont know if it's so crazy to change the fluids after seeing this thread: http://www.camaro5.com/forums/showthread.php?t=51147
ill tell you what, at 3000 miles ill be changing all of my fluids, including my oil (first changed at 1400), diff, and tranny fluids. i think it would be a little more cost effective to do it yourself, but there will always be some break-in debris when mechanical parts are wearing on each other. nothing wrong with a little preventative maintenance when you are spending a lot on a car in the first place.
adub4185 is offline   Reply With Quote
Old 01-19-2010, 10:29 AM   #9
kentf
Drives: 2010 camaro Black/White Stripes SS
There are no lube points. It is a seald bearing system.
kentf is offline   Reply With Quote
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
Oil Changes Dave McFly Off-topic Discussions 6 05-18-2010 05:50 PM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 01:28 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
