sjm autoprod
Old 01-02-2010, 07:46 PM   #1
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
Racing Brake 2 pc Rotors Installed
I installed my Racing Brake 2 piece rotors with open slots, Stainless steel braided brake lines and Hawk HPS brake pads today. The rotors save about 6 lbs of weight each. I already had Motul RBF600 brake fluid in the car. To replace the lines it only took about 6 ounces of fluid to bleed the new lines.
To break in the new pads, it took about ten 35 mph moderate pressure stops and another ten 55 mph hard stops to get the temps up. It was only about 25degrees outside at the time.
The brakes have a very firm feel now compared to stock.
Stock Rotor. The new thickness is 32mm. Minimum thickness is 30mm.
Stock brake line.
New Stainless Steel Braided line installed on front.
Racing Brake 2 pc rotor, SS line and Hawk pads installed.
Racing Brake 2 pc rotor with open slots. New thickness is 30mm. Minimum thickness is 28mm.
Rear stainless steel line installed.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 01-02-2010, 10:03 PM   #2
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
Those look great! Do you have a pic with the wheels on?
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 01-02-2010, 10:59 PM   #3
mtcwby
mtcwby's Avatar
Here's some more pics
Front rotor on car.
Name:  Racing Brake 020.jpg
Front Rotors, SS brake lines, Front and Rear Pads.
Name:  Racing Brake 001.jpg
Pic of the rotor venting.
Name:  Racing Brake 006.jpg
Old 01-02-2010, 11:49 PM   #4
Craig
Drives: '01 Z28
I can see this becoming a popular mod considering these cars' weight issues. 24 pounds is even more impressive considering that it's all rotating mass. Who did you get those rotors from?
Craig is offline   Reply With Quote
Old 01-02-2010, 11:54 PM   #5
Doc
Doc's Avatar
That's a good looking setup; those rotors look so much better than the stock ones. Besides the firmer feel, do they seem to grip better?
1SS/RS LS3 M6 IBM
Old 01-03-2010, 12:56 AM   #6
mtcwby
mtcwby's Avatar
They are from Racing Brake. http://www.racingbrake.com/CAMARO_SS...138-381-01.htm
Yes they grip great. The Hawk HPS High performance Street pads are softer than stock and really grip, and no dust!!
Old 01-03-2010, 09:43 AM   #7
flyby
Drives: 2010 Silver SS
Nice write up. How much weight loss?
flyby is offline   Reply With Quote
Old 01-03-2010, 01:06 PM   #8
2010_5thgen
2010_5thgen's Avatar
Drives: 2012 Porsche Panamera 4
Those rotors look bad ass. Where did you get them and how much ?
http://www.gofundme.com/n7ne44
2010_5thgen is offline   Reply With Quote
Old 01-03-2010, 03:42 PM   #9
d69chris
Florida C5
d69chris's Avatar
Drives: 2010 Camaro 2SS Vortech L99 IOM
Send a message via Yahoo to d69chris
I am putting mine on this week, can't wait! Will post pics.
What is the useful life on the Motul RBF600? Any idea of mile interval before you need to change it?
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
d69chris is offline   Reply With Quote
Old 01-03-2010, 04:37 PM   #10
Stewcam
Stewcam's Avatar
Drives: 2010 Camaro SS/RS
Looking good. Can't wait to receive mine also!
Yellow SS/RS
LMR Twisted Slayer 650 RWHP, ARH Headers, Hi-flow cats, Carbon/Organic Twin Disc/Pfadt/BMR/Hurst Shifter/D2forged VS1's
Stewcam is offline   Reply With Quote
Old 01-03-2010, 07:13 PM   #11
mtcwby
mtcwby's Avatar
6 lbs per rotor.
Post #6 in this thread.
At least as good as your oem fluid. I haven't seen a cut and dried change interval. Maybe call Motul and see what they recommend.
Old 01-03-2010, 07:33 PM   #12
Bentley78
Rice Cooker
Bentley78's Avatar
Drives: Avalanche Z/71, 2010 Camaro2SS
Those look fantastic!!! 24lbs loss of unsprung weight is AMAZING!!! Great job.
This is next after i get my headers and tuner.
Bentley78 is offline   Reply With Quote
Old 01-03-2010, 10:09 PM   #13
d69chris
Florida C5
d69chris's Avatar
Better be quick, not sure how long racing Brake is holding the Camaro5 discount!
They are working on the rear step currently.
Old 01-03-2010, 11:44 PM   #14
markssylver
markssylver's Avatar
Drives: 95 bbb impala ss
i put my rb rotors on last week i got the pedders stainless brake lines also and it brakes alot firmer now and looks better
10.56@134mph
ADM BUILT AND TUNED CGM 2SS RS
ADM/LPE 417 with ported heads/inconel vavles gt11 cam
ADM ported maggie with 14 rib rear 10 rib front pulleys
ADM fuel system and race air intake
ADM/LPE ZR1 clutch /pedalreturn spring
ADM billet aluminum valve covers /RPM LEVEL 6 TR6060
LPE HD 241mm diff with 3:45 gears HD axles and d/s
ADM widened wheels with 315nitto nt05s Bogart 17 dragwheels CTS-V front 6 piston brakes
Pedders HD subframe/differential bushings alignment kit 27/32mm sways Supercar coilovers
683RWHP/650RWTQ
markssylver is offline   Reply With Quote
Stoptech 4/6 POT Front/Rear BBK, Brake Lines, and Pads - Best Prices! AJ@ECSMotorsports Suspension / Chassis / Brakes 45 11-13-2010 04:55 PM
Lingenfelter 650 hp build mws444 Forced Induction - V8 546 12-26-2009 12:23 PM
Warping brake rotors Angrybird 12 Suspension / Brakes / Chassis 13 12-18-2009 03:45 PM
Vengeance Racing 3 year Anniversary/Customer Appreciation Day September 26th 2009!!!! Ron@Vengeance USA - Southeast 12 10-01-2009 02:19 PM
Are the SS Brakes Drilled? Scott@Bjorn3D Wheels and Tires Talk Sponsored by The Tire Rack 19 11-16-2008 05:47 PM
