Cold Air Inductions
Old 01-03-2010, 02:35 AM   #1
Ant32894
Youjellybra?
Ant32894's Avatar
Drives: 95 3.4l V6
Posi Rear?
I was wondering if the 1995 3.4 v6's had posi rear. I never really knew about it. I believe my car is stock.
Animated Gif not allowed
Ant32894 is offline   Reply With Quote
Old 01-05-2010, 05:07 PM   #2
Ant32894
Youjellybra?
Ant32894's Avatar
Drives: 95 3.4l V6
I know its a stupid question, but i don't know A LOT about 4th Gens. Bump...
Old 01-05-2010, 06:16 PM   #3
Kalenn
Fan of all things Camaro
Kalenn's Avatar
Drives: '13 Mercedes-Benz C250 Sport
Jack up the rear end so the tires are off the ground. Put the car in neutral. Spin the back wheel by hand. If the opposite tire spins in the same direction you have a limited slip differential. If the opposite tire spins in the opposite direction then you have an open differential.
"Ladies and gentlemen take my advice. Pull down your pants, and slide on the ice."
"E for electricity... V For Chevy Volt and me!"
Kalenn is offline   Reply With Quote
Old 01-05-2010, 06:23 PM   #4
Blownhotrodder
Blownhotrodder's Avatar
Drives: Z06
I dont know about that, ive had a couple cars with a posi or limited slip that when you spun one tire forward the other side would spin backwards.
Blownhotrodder is offline   Reply With Quote
Old 01-05-2010, 09:11 PM   #5
Ant32894
Youjellybra?
Ant32894's Avatar
Drives: 95 3.4l V6
Yeah Posi is when BOTH spin ONEWAY, and Limited Slip is when they BOTH spin DIFFERENT ways, correct?
Old 01-05-2010, 09:12 PM   #6
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
4th gen v6 cars had an open diff
Old 01-05-2010, 09:14 PM   #7
Ant32894
Youjellybra?
Ant32894's Avatar
Drives: 95 3.4l V6
So it is Limited Slip? (Spin Different ways)
Old 01-05-2010, 09:29 PM   #8
camaro1
camaro1's Avatar
open diff = no posi
Old 01-05-2010, 10:13 PM   #9
xsofa
Drives: 96 Camaro 3800
Well what you have written is contradicting; Limited Slip or Posi traction, although they're not the same, but are often used interchangeably, keeps the wheels spinning at a similar speed. What the range of that speed differential is depends on the Diff. While open differentials, like the one in your car, let the wheels spin freely, like on a matchbox or hot wheels car. In general, Limited Slip is preferred as it keeps the back end more planted. Although for any kind of CIRCUIT racing or auto cross, it can vary greatly depending on the track.
xsofa is offline   Reply With Quote
Old 01-06-2010, 12:38 AM   #10
pv-camaro
pv-camaro's Avatar
Drives: Camaro 2001 3.8V6
hi,
I don't think this is true
I have a 2001 3.8V6 Camaro (European) and he has a slip diferential (RPO code G80)
pv-camaro is offline   Reply With Quote
Old 01-06-2010, 04:51 AM   #11
fbodyrs96
fbodyrs96's Avatar
Drives: 1996 Camaro RS convertible
yes, the V6 came with LSD if you have the G80 RPO code, or Y87 package
GU2=2.73- v8 only
GU4=3.08- open differential(means no lsd)
GU5=3.23
GU6=3.42
fbodyrs96 is offline   Reply With Quote
Old 01-06-2010, 09:11 AM   #12
Ant32894
Youjellybra?
Ant32894's Avatar
Drives: 95 3.4l V6
Thanks guys.
Old 01-11-2010, 01:55 AM   #13
CamaroAMX
CamaroAMX's Avatar
Drives: 94 Camaro,3.4L, purple pearl metali
I have the GU5 option on my 94 V6 camaro. I've left dual black marks on occasion. I also have the F41 suspension option as well as the QMT option (Z-28 spec wheels, no speed limiter), so maybe that has something to do with it. Some of my RPO codes are worn off my sticker so maybe I missed something.
CamaroAMX is offline   Reply With Quote
Old 01-11-2010, 03:51 AM   #14
fbodyrs96
fbodyrs96's Avatar
all 4th gens have the F41 RPO code..
Setting up an IRS/Drivetrain for Drag Racing Kyle2k Suspension / Brakes / Chassis 44 06-05-2010 10:17 PM
2010 Camaro SS Blue in Syracuse NY $32690 Mitsubishi in Syracuse Camaro Price | Ordering | Tracking | Dealers Discussions 0 12-31-2009 03:44 PM
2010 Blue SS for $32990 and we pay for your plane ticket! Mitsubishi in Syracuse Dealer Camaros for Sale 0 12-21-2009 01:42 PM
Steering response.... CGM2SSRS Wheels and Tires Talk Sponsored by The Tire Rack 130 10-21-2009 06:04 PM
Pfadt Carbon Rear Trailing Arms and Rear Tie Rods PfadtRacing Suspension / Brakes / Chassis 20 10-18-2009 10:46 AM
