IPS Motorsports
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 01-03-2010, 07:41 PM   #1
avro206
Drives: 89 Formula 350
Why use premium gas?
Let me first say---I'd use it, no question.
My friend who has a Camaro SS refuses to fill it with premium. He doesn't think it needs it and won't pay out of principal.
His idle has a slight fluctuation I have noticed.
Give me some concrete reasons why he should.
89 Formula 350 with alot of mods
avro206 is offline   Reply With Quote
Old 01-03-2010, 07:45 PM   #2
coolman
Guest
He is also killing this hp #'s by doing this. It really slows them down to run anything other than premium. If it was a v-6 then it wouldn't matter.
coolman is offline   Reply With Quote
Old 01-03-2010, 07:49 PM   #3
avro206
says he doesn't care about the 5hp he's missing.
I think GM doesn't randomly specify premium fuel engines. Big turn off to alot of people and sometimes even a deal breaker.
Old 01-03-2010, 07:53 PM   #4
coolman
Guest
Go through the threads on here and you will find that it's a lot more than 5hp lost over it. It does state to run premium in the SS or performance will be reduced.
Old 01-03-2010, 08:07 PM   #5
BLACK10
POWER TECH
BLACK10's Avatar
the price of a tank of premium is only about $3 more than a tank of regular. there's more ways to save a couple dollars than making your engine have valve clatter and detonation
Old 01-03-2010, 08:14 PM   #6
1camaro70
1camaro70's Avatar
Drives: 2010 2SS RS L99
If you go back to multiple threads, and dyno runs the low octane table loses you about 20 HP and 25 torque, just look at low dyno's verses heathy engines. At least with L99.
1camaro70 is offline   Reply With Quote
Old 01-03-2010, 08:17 PM   #7
BLACK10
POWER TECH
BLACK10's Avatar
yeah, thats how the whole fuse-pull thing got started
Old 01-03-2010, 08:19 PM   #8
SC2150
SC2150's Avatar
Drives: 2001 Camaro SS
The knock sensors are quick enough to pull timing to avoid damage, but the reduced fuel economy that will result negates any savings from useing a lower octane.
The power loss could be 20-25hp or more depending on how close the factory tune is.
These cars have a 11:1 compression ratio....premium is a must!
Bottom line is, why? We have a customer that spent the $$ for a new Z06...and he won't pay the extra for premium. Crazy!
Old 01-03-2010, 08:29 PM   #9
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
For us that have been here for a while we know that issue of filling up a L99 with low octane fuel. . . There's been many topics on this.
My 2003 SRT-4 actually pulled the boost and retarded the timing if you didn't use High test fuel.
Magnaflow Cat back / ROTO-FAB Intake / Whipple Kit / RDP Tune.
580hp - 650Tq
franknbeans is offline   Reply With Quote
Old 01-03-2010, 08:48 PM   #10
BLACK10
POWER TECH
BLACK10's Avatar
sorry , i was thinking of a car with a tune thats not pulling timing
Old 01-03-2010, 09:27 PM   #11
SC2150
SC2150's Avatar
Good point. A tuned car will still pull timing unless the knok detor settings are disabled or turned way down...and the only time we disable them is when doing a bracket tune for the drag racers that want to run the same# run after run. So you should still be safe even with a tune as long as the tuner is good. But we do see some tunes come in from a well known "traveling tuner" that disables it to cover for some tuning weaknesses he has...and have seen the melted pistons as a result.
Old 01-03-2010, 09:37 PM   #12
rodimus prime
Drives: Cargo van.
Im going to run 87 all winter. It doesnt hurt anything. Your car will just switch to the low octane table. But expect it to be slower. No damage will occur, thats just stupid.
rodimus prime is offline   Reply With Quote
Old 01-03-2010, 10:32 PM   #13
RJT-Maro
Emerald Coast Camaros
RJT-Maro's Avatar
Drives: 2010 Supercharged RJT SS!
Send a message via AIM to RJT-Maro
If his car has a manual transmission then It will do this..
It's the lope from the big engine it has lol..
Mine does it, and it tickles me to see the needle moving up and down at a stop light lol
2010 Camaro SS LS3 Supercharged RJT!
Magnuson TVS 2300 Supercharger, ARH 1 7/8 LT Headers with 3" X-Pipe, Borla S-Type Axle-Back, DMH Low Profile Exhaust Cut-Outs, MTI Racing CAI, Stage 2 Camshaft(227/239 .614/.624) with new springs, Katech C5R Z Timing Chain, LS7 Bowtie Damper, MTI Hot Spark Plug Wires, MTI Racing Lowering Springs and Swaybars, Aluminum Oil Catch Can, 160 Degree Thermostat, MTI Tune. 554RWHP 528RWTQ Built By: MTI Racing Dyno Sheet here
RJT-Maro is offline   Reply With Quote
Old 01-03-2010, 10:47 PM   #14
slicker
slicker
slicker's Avatar
Drives: Cyber Grey 1 LT / RS
ok then if it make that much diffrence in the SS. then why no difrence in the LT with a 6 under the hood. the manual says regular but i use mid grade from chevron so should i be useing regular or should i use premium
UFC as real as it gets
slicker is offline   Reply With Quote
Old 01-03-2010, 10:51 PM   #15
avro206
you have direct injection it runs fine on 87. But you can use higher if you want.
6.2L does not have DI
Old 01-03-2010, 11:10 PM   #16
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 72 GTO 07 NBS Silverado
Oh WOW!
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 01-03-2010, 11:39 PM   #17
SamSS
SamSS's Avatar
Drives: '10 Camaro SS
Originally Posted by Dire Wolf View Post
Your friend buys a Camaro SS and then refuses to put Premium gas in it out of principal?
I'm sorry but your friend sounds like a complete dick. I call 'em like I see 'em.
Do you guys use Chevron's premium, Shell's, which one? I use Shell's premium. Are they even different from one another?
2010 Camaro SS A6, Rotofab intake, Flowmaster American Thunder exhaust, JBA off-road pipes, PFADT sway bars and lowering springs, Dyno tuned by CMS
SamSS is offline   Reply With Quote
Old 01-03-2010, 11:48 PM   #18
ffrcobra_65
bottom line
If premium gas is Required, you must use premium or risk damage to the engine.
If premium is Recommended, you can get away with using regular or mid grade octane at the expense of performance.
If your car doesn't recommend or require premium but you are using premium, you are wasting money.
Old 01-04-2010, 12:21 AM   #19
hansenp
hansenp's Avatar
Drives: 2010 Camaro 2 SS/RS
I used 87 cause I didnt know any better until i came to this site with the complaint of bad knocking and pinging on hills. After using 91 it was gone. It responds so much better
hansenp is offline   Reply With Quote
Old 01-04-2010, 12:24 AM   #20
SSTony
Drives: SS Camaro
Send a message via AIM to SSTony
you should be putting premium in there and thats the bottom line.
SSTony is offline   Reply With Quote
Old 01-04-2010, 12:33 AM   #21
rodimus prime
Drives: Cargo van.
Just so you guys know, the cpu has two octane tables it runs its spark from, low and high. You can run either octane fine without the risk of damage, but with 87 you will be down on power.
Old 01-04-2010, 09:19 AM   #22
2SSRS
On a list for a 2014 Z28
2SSRS's Avatar
Drives: 2010 Camaro 2SS M6
I have been running 87 for three months now I will re dyno this munth to see if i lost power in AZ i don't think there is much deference in the two.
2SSRS is offline   Reply With Quote
Old 01-04-2010, 09:21 AM   #23
rodimus prime
Drives: Cargo van.
LOL.
Your worried about using the Vararam to get the most power for an intake, then you run 87 octane to really compliment it. Sorry man, but thats funny.
Old 01-04-2010, 09:23 AM   #24
1SSLOW
1 - 0
Drives: 2010 SS/RS w/ GFX
i always used premium...even when I would drive my old honda accord. LOL.
So, now with the SS, you get your a$$ Ima keep on using premium.
1SSLOW is offline   Reply With Quote
Old 01-04-2010, 09:30 AM   #25
Trailbreaker77
Trailbreaker77's Avatar
Drives: 2010 Transformers Edition
I use 93 all the time, it is my second vehicle so I don't have to fill it up that often. Maybe once a month.
Trailbreaker77 is offline   Reply With Quote
The new Camaro V6 might be the best model of the entire lineup! Mr. Wyndham 5th Gen Camaro SS LS LT General Discussions 101 12-21-2010 07:48 PM
Mixing Gas to get 93 Octane FarmallsForever Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 11-13-2009 09:29 PM
Hard to fill gas tank herkman 5th Gen Camaro SS LS LT General Discussions 35 11-09-2009 06:16 PM
Locking gas cap howdyguy 5th Gen Camaro SS LS LT General Discussions 25 10-09-2009 06:37 PM
Fuel pump or bad tank of gas? Boomer Sooner 4th Generation Camaros 25 01-02-2009 06:34 PM
