| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
Pfadt Race Engineering releases new Camaro V8 Engine Mounts
![]() At Pfadt, we believe in engineering-driven products that provide solutions to common limitations of performance cars. As a result of this, I wanted start a thread regarding the launch of our new Camaro V8 Engine Mount Kit, which upholds this ideal in every way. My intentions are to give everyone a brief overview, and highlight the DIY aspect of this important upgrade, with comprehensive install instructions. Our new Camaro Engine Mount kit is certainly a must for all of you who currently have, or plan on having, power adders for your 5th-gen Camaro. Just like in a suspension, soft rubber-based mounting solutions can wear out quickly, lose their effectiveness under load, and lead to problems when upgrading other components on your Camaro. Engine isolation is no exception. This is often overlooked when building a powertrain, because it is commonly a “secondary” consideration. It is no longer a problem lacking a complete solution, however, because we are currently shipping sets of our new Camaro V8 Engine Mount kit. The kit consists of a 6061 T6 aluminum upper component (with an anodized finish), a zinc plated steel lower component, graphite-impregnated polyurethane hat bushings, and all hardware necessary for installation on both sides. This kit will give you the engine restraint that your Camaro is desperately in need of. And as you will see below, it is incredibly easy for customers of all experience levels to install. As always, please do not hesitate to contact us if you want more information, or are in need of clarification on installation. Camaro V8 Engine Mount Installation Tools Needed: 3/8" drive ratchet 24" long 3/8" extension torque wrench 15mm socket 18mm deep socket 3/8" drive universal screw jack This procedure is best performed on a vehicle lift, however it is possible to install these mounts using a floor jack and jack stands. The pictures below are to show the stock mount (black rubber part), with the OEM pedestal (silver component above the black mount), and its relation to the engine and front subframe. And this picture is to illustrate exactly which component we are replacing. Removal: Open hood and using a long extension on a 3/8 ratchet with a swivel, remove the upper engine mount nuts on both sides of the engine (18mm hex) Raise the car on the lift (or lift the car and safely support on jack stands). If using jack stands, it will be necessary to remove the front tires. Using the 18mm socket, remove the nuts from the lower stud of the engine mounts. Using the screw jack and a protective block of wood, raise the engine off of the engine mounts by lifting on a structural portion of the oil pan. Use care to not damage the cast aluminum oil pan. The upward travel of the engine will be limited by the exhaust contacting the underside of the body. Stop when contact occurs, you will get the extra room required by removing the engine mount pedestals from the engine block. Using the 15mm socket and universal on a long extension, remove the four bolts holding the engine mount pedestals to the engine block on each side. ![]() One at a time move the pedestals out of the way enough to remove the stock engine mounts. Installation: Install the Pfadt engine mounts in place of the stock mount being sure to orient the mounts correctly. The tab on the lower steel portion of the mount will engage a slot in the Camaro subframe. Re-install the pedestals to the engine block using the original bolts. Torque bolts to 37 lb-ft Align the upper studs on the Pfadt engine mounts with the holes in the pedestals and carefully lower the engine down onto the mounts. Using the crush nuts from the factory mounts, start the nuts on the studs of the Pfadt mounts (upper and lower). Torque the lower nuts to 37 lb-ft Lower the car to the ground. Using the long extension again, torque the upper engine mount nuts to 37 lb-ft. |
One Lucky Guy.
Drives: #22 Tom Henry Racing 2010 2SS/RS Join Date: Dec 2007
Nice write up guys.
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
LVL 50 Troll Stomper
Drives: 2010 Camaro Join Date: Feb 2008
How far out are you guys on the transmission mounts?
Drives: 2010 Camaro 2ss L99 A6 Join Date: Jan 2009
Very nice product and details. What is the price and availability?
#5 | |
No problem at all!
Currently, we do not have them available, but most likely we will have them ready later in 2010. We do, however, have our differential mounts available currently, and we believe that is a more important upgrade for customers right now. Quote:
Let me know if you have any further comments/questions! Thanks guys! |
#6 |
![]() Drives: VStar 1100 Classic, 2010 CGM 2SS/RS Join Date: Mar 2009
I love it when products include a tutorial online. Lets me see if it can be done in any garage, more like done by me.
#7 |
214-228-8782
![]() Drives: 2013 ZL1 #138 Join Date: Oct 2008
We use these
We have all their products on our 1000+ hp car......No movement what so ever ..amazing stuff guys!!!!
Andy |
#8 |
We inventory these products and these mounts in particular for a while now, they have been very popular among my track racers, and 500+ horsepower customers. Once you drive the car with stock mounts, and then drive our car with Pfadts engine mounts, its an easy sell.
Regards |
#9 |
Thank you for commenting, guys. It is certainly appreciated.
#10 |
![]() Drives: 2010 SS/RS M6 Join Date: Nov 2009
It doesn't look very "Beefy".
![]() Along those lines, wonder why it wasn't designed as a one piece unit? Adjustibilty isn't a must and rigidity would be improved. Mav
SS/RS M6, SIM, CGM stripes, Barton S/T, BMR trailing arms, ADM Race intake(no scoop), Texas Speed 1 7/8" headers and full 3" exhaust, RMCR custom tune.
#11 |
Hi MadMav,
What we found out in doing the structural analysis of this product, is that it actually is sufficiently "strong" or "beefy" (whichever you choose) for the application. I have posted some FEA results below. These are plots of FoS (Factor of Safety) for both the upper aluminum component, and the lower steel component. The loading that was applied for these cases were "worst case" scenarios of simultaneous 1500 ft*lbs of torque, engine mass, 1.2g cornering force and 1.75g braking/acceleration force. You will see in the results below that the minimum Factor of Safety that we saw with this simultaneous loading was 1.8 which occurs in the steel lower bracket. Let me know if you have any further questions about these. We are here to help! Thank you. ![]()
#12 |
Very nice data sir!
You say that the miniumum FoS is the lower steel brackets( I would like to see them have a thicker steel, but what about the mounting bolts? Upper and lower, and the joining bolt? How much rubber is being used? Or is it poly? What is the breakdown rate for that material? Thanks, Mav
#13 |
Hi again MadMav,
Well, to start with, take a look at photo I posted below, it is an exploded view of one side of the Engine Mount Kit assembly. This may clarify future questions. No, this is not a solid mount, you can see you are correct when assuming that the polyurethane bushings in the kit are being used to isolate the connection between the top and bottom main components. The bushings are the black "hat-like" pieces being shown to the left and right of the orange upper component. These are a 'street-able' solution for firming up your powertrain and holding it in place better. We could certainly make a 1 piece unit (and you could install it just fine), but the car would buzz and vibrate like mad. Good for a race car maybe, but not for street use. The FoS in the lower is nearly identical to the upper (certainly within the tolerances of the analysis). When we did the design, we saw that increasing the thickness of the steel bracket beyond .125", did not change the FoS in the lower bracket portion because the limit was the contact force against the frame section. The strength of the fasteners (OEM and the ones we provide) exceeds the strength of the other components in these mounts. The poly we use is a 70D and the bushings are the same parts that we have used in our Corvette engine mounts for many years. They do not degrade in any meaningful way. Hope this clears some stuff up about the design. Thanks for inquiring! |
#14 |
Very impressed with your answers and attitude! Thank you sir. I'm positive you guys are much smarter than I, and I'm going to have to say that you have done your homework and have the data and facts to back that up.
Very pleased, and thank you again. What is the weight on these vs. the factory ones? Probably a slight weight savings as well. Mav
#15 | |
FYI a set of OEM Camaro V8 engine mounts weighs in at 7.1lbs and a set of our Pfadt mounts tips the scale at 3.3lbs. Good point worth mentioning, thanks for bringing it up! |
#16 |
![]() ![]() Drives: 2012 Challenger SRT8 Auto Join Date: Sep 2009
Aaron, thanks for the write-up, any chance you may do a similar type write-up on the rear diff mounts as well. Have been conversing with Brandon at IPS the past couple days and the engine mounts and rear diff mounts are on my DIY list.
"When the people find they can vote themselves money, that will herald the end of the republic." - Benjamin Franklin ![]() LS3 Camshaft Swap Do-It-Yourself Instructions - 2010 LS3 gone but not forgotten!!! |
#17 |
You're welcome for the write up, we are glad to be providing them.
In regards to the rear diff bushing install instructions, I will make it a point to post them in this thread when they are ready. Look for these in the next week or two. Its a priority to make sure customers are clear on install procedures, so thank you for asking about them! |
#18 | |
Every pound counts! Thanks sir. Mav
#19 |
#20 |
These mounts are in stock and ready to ship! Contact us or your local Pfadt dealer for more info.
#21 |
Thanks for the heads up.. (ehem)... (cough)... COILOVERS.. did I just say that? I meant to say (ehem)... COILOVERS... dammit, there I go again
![]() Looking forward to Pfadttening things up a bit
#22 |
Hi robertway,
We read you loud and clear |
#23 | |
As an aside, to anyone that just read this last line, I am not saying anyone else has rushed something to market so please don't turn this into a pissing match.
#24 | |
Thanks in advance, Robert
#25 |
Hi robertway, 37 lb-ft is the correct torque value you are looking for.
| Thread Tools | |
| Supercharger / Turbocharger Results (INFO) Thread | radz28 | Forced Induction - V8 | 205 | 05-15-2013 09:30 PM |
| V8 Camaro Performance Upgrades List | Milk 1027 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 79 | 03-04-2013 09:25 AM |
| GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 07:33 PM |
| Official Camaro Convertible CONCEPT Press Release | Tran | Camaro Convertible Forum | 12 | 11-18-2009 07:05 PM |
| The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 106 | 10-19-2009 06:08 PM |
