Old 01-04-2010, 01:12 PM   #1
Jeanius
Jeanius's Avatar
Drives: Blk/Blk LS3 SS
Q about Coilovers and alignment
When changing the ride height with a coilover, is an alignment necessary?
Does aligning matter on how much its dropped/raised?
Jeanius is offline   Reply With Quote
Old 01-04-2010, 01:25 PM   #2
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
The way I do coilovers....
Once installed, I set the ride height that I feel will be used the most. I normally set them once and leave it along anyway.
That use that height when I get it aligned. If you make a small adjustment for a track day etc... then go back to normal you are fine. If you plan to make LARGE adjustments, then you can run into issues.
The other thing I do is I use adjustable dampers in my coilovers...I set the ride height, align it, and leave it!!! I use the damper adjustments to make the changes neccessary for track days or other "spirited" driving.
ZZcamaro is offline   Reply With Quote
Old 01-04-2010, 02:39 PM   #3
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Hi Jeanius,
We always recommend to perform an alignment after adjusting the ride height on your coilover set-up. With a ride height change, both the camber and toe will change.
You can do wonders with some basic tools in your garage if you are DIY oriented. Here is a link to a fellow racer's site with a nice DIY alignment technique.
http://www.davidfarmerstuff.com/align.pdf
He does race alignments with a Lowes laser level and some tape measures.
Hope this helps!
Old 01-05-2010, 05:04 PM   #4
ssmike
Missing Big Red
ssmike's Avatar
Drives: 2006 Corvette DSOM, '13 Equinox CRT
Mark, what does a set of coilovers cost and which brand do you recommend?
Not a Camaro but it works for now!
Old 01-05-2010, 06:32 PM   #5
ZZcamaro
I like the KW, you could use a variant I or variant III. PM me for pricing.
H&R Springs Alignment specs can other members post how they set there cars up? 55Designs Suspension / Brakes / Chassis 0 10-29-2009 05:56 PM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
Pedders December Dollar Days for the 2010 Camaro and Brand X Vehicles JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 85 07-26-2009 05:20 PM
Pedderizing the Nickey Camaro! Pedders coilovers / suspension fitted & tested. DallasMike Wheels and Tires Talk Sponsored by The Tire Rack 57 06-15-2009 04:36 PM
SEMA, Pedders Conference, GS Camaro, New Products JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 25 12-01-2008 01:25 PM
